Hey all,
Newbie programmer here. Basically I have a weird schematic I need to meter. There are two batteries wired in series together, and I have two separate identical arduino circuits connected to both batteries (see attached schematics). The code is identical in both of these arduinos and works fine on its own. However, when I connect my circuit my voltage readings go berserk, showing 112Vs and .25 Voltage (offset this indicates 0 Volts) on my output and input meters, respectively. Does anyone know what’s going on here and how to fix? Amps is reading fine.
Ultimately I need to compare the behavior of both of these batteries during charging/discharging cycles. To do this I need to measure volts, amps, and watts so I can use these data points to make graphs.
Thanks in advance!
/* 0- General */
int decimalPrecision = 3; // decimal places for all values shown in LED Display & Serial Monitor
/* 1- DC Voltage Measurement using Voltage Divider Method */
int VoltageAnalogInputPin = A1; // Which pin to measure Voltage Value (A0 is reserved for LCD Shield buttons function)
float voltageSampleRead = 0; /* to read the value of a sample*/
float voltageLastSample = 0; /* to count time for each sample. Technically 1 milli second 1 sample is taken */
float voltageSampleSum = 0; /* accumulation of sample readings */
float voltageSampleCount = 0; /* to count number of sample. */
float voltageMean; /* to calculate the average value from all samples*/
float moduleSupplyVoltageV = 5; /* maximum measuring voltage , default 5V*/
float R1 = 47000; //30000.0; // Input resistance value for R1 (in ohm) based on Voltage Divider Method
float R2 = 2200; //7500.0; // Input resistance value for R2 (in ohm) based on Voltage Divider Method
float finalVoltage = 0; /*shows the final voltage reading*/
/* 2- DC Current Measurement */
int CurrentAnalogInputPin = A2; // Which pin to measure Current Value (A0 is reserved for LCD Shield buttons function)
float mVperAmpValue = 100; // If using ACS712 current module : for 5A module key in 185, for 20A module key in 100, for 30A module key in 66
// If using "Hall-Effect" Current Transformer, key in value using this formula: mVperAmp = maximum voltage range (in milli volt) / current rating of CT
/* For example, a 20A Hall-Effect Current Transformer rated at 20A, 2.5V +/- 0.625V, mVperAmp will be 625 mV / 20A = 31.25mV/A */
float moduleMiddleVoltage = 2500; /* when there is no reading, the voltage is at middle Vcc. For 5V power supply, the middle voltage is 2500mV;*/
float moduleSupplyVoltage = 5000; /* supply voltage to current sensor module, default 5000mV*/
float currentSampleRead = 0; /* to read the value of a sample*/
float currentLastSample = 0; /* to count time for each sample. Technically 1 milli second 1 sample is taken */
float currentSampleSum = 0; /* accumulation of sample readings */
float currentSampleCount = 0; /* to count number of sample. */
float currentMean; /* to calculate the average value from all samples*/
float finalCurrent; /* the final current reading without adding offset value*/
float finalCurrent2; /* the final current reading*/
/* 2.1- DC Current Offset */
int OffsetRead = 0; /* To switch between functions for auto callibation purpose */
float currentOffset =.22; // to Offset deviation and accuracy. Offset any fake current when no current operates.
// Look into serial monitor to add or minus the value.
// 0.26 means add 0.26A to all current measured value.
/* if you have LCD Display Shield, this offset can be automatically adjusted by pressing SELECT button */
float offsetLastSample = 0; /* to count time for each sample. Technically 1 milli second 1 sample is taken */
float offsetSampleCount = 0; /* to count number of sample. */
/* 3- DC Power Wattage calculation */
float PowerValue = 0; /* Initial calculation Power Value */
unsigned long startMillisPower; /* start counting time for power */
unsigned long currentMillisPower; /* current counting time for power */
const unsigned long periodPower = 1000; // refresh every X seconds (in seconds) Default 1 = 1 second
/* 4- DC Watt-hour calculation */
float wattHour = 0; /* Initial calculation Energy Value */
unsigned long startMillisEnergy; /* start counting time for Energy */
unsigned long currentMillisEnergy; /* current counting time for Energy */
const unsigned long periodEnergy = 1000; // refresh every X seconds (in seconds) Default 1000 = 1 second
float FinalEnergyValue = 0; /*shows the final Energy reading*/
/* 5 - LCD Display */
// #include<LiquidCrystal.h> /*Load the liquid Crystal Library (by default already built-it with arduino solftware)*/
// LiquidCrystal LCD(8,9,4,5,6,7); /*Creating the LiquidCrystal object named LCD */
// unsigned long startMillisLCD; /* start counting time for LCD Display */
// unsigned long currentMillisLCD; /* current counting time for LCD Display */
// const unsigned long periodLCD = 1000; // refresh every X seconds (in seconds) in LED Display. Default 1000 = 1 second
void setup() /* The Codes only run 1 time only when Arduino started.*/
/* 0- General */
Serial.begin(9600); /* In order to see value in serial monitor */
startMillisPower = millis();
startMillisEnergy = millis();
// LCD.begin(16,2); /*Tell Arduino that our LCD has 16 columns and 2 rows*/
// LCD.setCursor(0,0); /*Set LCD to upper left corner of display*/
//startMillisLCD = millis();
void loop() /* The Codes run repeatly over and over again.*/
/* 0- General */
if (millis() >= voltageLastSample + 1) /* every 1 milli second taking 1 reading */
voltageSampleRead = analogRead(VoltageAnalogInputPin); /* read the sample value */
voltageSampleSum = voltageSampleSum + voltageSampleRead; /* accumulate value with older sample readings*/
voltageSampleCount = voltageSampleCount + 1; /* to move on to the next following count */
voltageLastSample = millis(); /* to reset the time again so that next cycle can start again*/
if (voltageSampleCount == 1000) /* after 1000 count or 1000 milli seconds (1 second), do the codes below*/
voltageMean = voltageSampleSum / voltageSampleCount; /* calculate average value of all sample readings taken*/
finalVoltage = 0.25+((voltageMean * moduleSupplyVoltageV) / 1024) / (R2 / (R1 + R2)); /* Calculate the expected monitoring votlage */
Serial.print("V : ");
Serial.print(finalVoltage, decimalPrecision);
Serial.print(" V ");
//byte finalVoltage = 0; // declare the variable "color"
//..finalvoltage =; // set the variable to any value in the range [0-255]
//Serial.write(finalVoltage); // transmit the byte-variable "color"
// Serial.println();
// Serial.print('\t');
// Serial.print(" / ");
voltageSampleSum = 0; /* to reset accumulate sample values for the next cycle */
/* to reset number of sample for the next cycle */
if (millis() >= currentLastSample + 1) /* every 1 milli second taking 1 reading */
currentSampleRead = analogRead(CurrentAnalogInputPin) - ((moduleMiddleVoltage / moduleSupplyVoltage) * 1024); /* read the sample value */
currentSampleSum = (currentSampleSum + currentSampleRead); /* accumulate value with older sample readings*/
currentSampleCount = currentSampleCount + 1; /* to move on to the next following count */
currentLastSample = millis(); /* to reset the time again so that next cycle can start again*/
if (currentSampleCount == 1000) /* after 1000 count or 1000 milli seconds (1 second), do the calculation and display value*/
currentMean = currentSampleSum / currentSampleCount; /* calculate average value of all sample readings taken*/
finalCurrent = (((currentMean / 1024) * 5000) / mVperAmpValue); /* calculate the final RMS current*/
finalCurrent2 = -(finalCurrent + currentOffset)/2;
Serial.print("I : ");
Serial.print(finalCurrent2, decimalPrecision);
Serial.print(" A ");
currentSampleSum = 0; /* to reset accumulate sample values for the next cycle */
currentSampleCount = 0; /* to reset number of sample for the next cycle */
/* 2.1 - Offset DC Current */
if (OffsetRead == 1) {
currentOffset = 0; /* set back currentOffset as default*/
if (millis() >= offsetLastSample + 1) /* offset 1 - to centralise analogRead waveform*/
offsetSampleCount = offsetSampleCount + 1;
offsetLastSample = millis();
if (offsetSampleCount == 2500) /* need to wait first offset take into effect. Delay 2.5 seconds */
{ /* So this code is to delay 2.5 seconds after button pressed */
currentOffset = -finalCurrent; /* to offset values */
OffsetRead = 0; /* until next offset button is pressed*/
offsetSampleCount = 0; /* to reset the time again so that next cycle can start again */
currentMillisPower = millis(); /* Count the time for power */
if (currentMillisPower - startMillisPower >= periodPower) {
PowerValue = finalCurrent2 * finalVoltage;
Serial.print("P : ");
Serial.print(PowerValue, decimalPrecision);
Serial.print(" W ");
startMillisPower = currentMillisPower; /* Set the starting point again for next counting time */
currentMillisEnergy = millis(); /* Count the time for current */
if (currentMillisEnergy - startMillisEnergy >= periodEnergy) {
wattHour = PowerValue / 3600 * (periodEnergy / 1000); /* for smoothing calculation*/
FinalEnergyValue = FinalEnergyValue + wattHour;
// Serial.print("E : " );
//Serial.print(FinalEnergyValue,decimalPrecision);
//Serial.print(" Wh ");
//Serial.println(" / ");
startMillisEnergy = currentMillisEnergy; /* Set the starting point again for next counting time */
