Where can I find a 1:1 Nano Every pinout
In a moment of brilliance, I decided I want to printout the pinouts for my Nano Every and then punch its headers through the paper and into my breadboard so I can easily see what’s what.
…but where can I find one that’s actual size? Thanks.
Search "arduino nano every pinout" https://docs.arduino.cc/hardware/nano-every/
The way you seem to be describing it, wouldn't the label be underneath the Nano, and therefore out of sight? Or are the labels supposed to be on the outside of the pins?
Edit: if the latter, print out the pinout at the link @xfpd provided at 52% and Bob's your uncle.
Like this:
The pinout is the same as for the classic Nano: https://upload.wikimedia.org/wikipedia/commons/e/e4/Arduino-nano-pinout.png
I have an Every on a breadboard project on my desk at the moment and I hold a classic Nano beside it to work out the pin numbering.
If using that drawing, be aware that the ICSP header details, upper right hand corner, contain some incorrect information. In particular, the pin numbers(1,17,18,19) are wrong. The labels (RST, MOSI, MISO, SCK) are correct.
Well spotted. I use that picture because it is a clean, high resolution image as opposed to the burred, low resolution images that usually turn up on a google image search. Getting one which has both a high quality picture and accurate information would be just ideal.
Also, the Nano Every has no ICSP header.
An even better point, which, if I had looked on the shelf above my head, I would have realized. DOH!
In my defense, they actually do, sort of, provide the ICSP interface, though it's unlabeled. See the board bottom image:
See those six dots? I am presuming these are used at some point during manufacturing to program the Every with the bootloader.
Those "dots" appear to be the UPDI interface to the SAMD11 processor, and are shown on the last page of the pinout.
https://docs.arduino.cc/resources/pinouts/ABX00028-full-pinout.pdf
sigh. Wrong again, then. Thanks!
A SAMD11 doesn't use UPDI.
It looks like the 6dot array has both SWD to the SAMD and UPDI to the 4809.
Since the SAMD11 implements a UPDI programmer, the 4809 on a Nano Every will not normally have any bootloader.
even though this thread is a bit old, I've created a template to stick on. On my printer, I also set the scale to 95% for printing, and then the RM 2.54mm dimensions fit pretty well.
Pinout
Excelfile
NanoEveryPinoutPaper.zip (7,7 KB)
