i am confuse the where is the Arduino library suppose to be keep. When I try to compile a program with LiquidCrystal.h, it shows somehow my library is not installed. I try to installed and then recompile, the error display as below:-
Multiple libraries were found for "LiquidCrystal.h"
Used: E:\Arduino-MyProgram\libraries\LiquidCrystal
Not used: E:\Arduino1.8.2\arduino-1.8.2\libraries\LiquidCrystal
Using library LiquidCrystal at version 1.0.7 in folder: E:\Arduino-
exit status 1
Error compiling for board Arduino Uno.
In my preference, mysketch book location is E:\Arduino-MyProgram.
Where is the directory the library store and where can i find this directory ?
hamisu-anguan:
Libraries should be installed under the libraries subfolder of the sketchbook.
hamisu-anguan:
That's too vague a statement for us to do anything with. The only output you posted clearly shows you have two copies of the library installed.
hamisu-anguan:
That's just telling you there are two libraries on your computer that contain a file named LiquidCrystal.h. One is the LiquidCrystal library that comes with the Arduino IDE, the other is another library of that name you have in your sketchbook. If you just take a second to read, instead of just jumping to the conclusion that it's an error, that should be quite clear. This is just a helpful informational message provided by the Arduino IDE. As long as it shows that the intended library was used, there is nothing to worry about and you can just ignore it.
For some reason you decided to put the irrelevant part of the output in your post and the real error is buried in the txt file you attached. This output shows you are using a very outdated version of Arduino AVR Boards. Do this:
Tools > Board > Boards Manager
Wait for downloads to finish
Click on "Arduino AVR Boards"
Click "Update"
Wait for update to finish
Click "Close"
After doing that the problem will likely be fixed.
hamisu-anguan:
It provides the path right in the message you posted.
