where to put buzzer code
where to put my buzzer in this code after led will high and led will low please for my thesis project
[code]/*By Roee Bloch - Version 4
 * This includes: Latch Mode, Momentary Mode (selected by A5 input), and also feedback to Transmitter that the Receiver got transmission OK - by LED on Transmitter
 * Controls 4 logic output at 2 modes: Latch (each press change output ON/OFF), Momentary (output on just when button is pressed)
*HC-12 Moule Transciever Same code is for Transmitter and Receiver, setup through A4 Input
*Tested on Arduino Nano
* This SW is for Transmitter & Receiver, the choise is done by reading A4 & A5 inputs (analog inputs)
* A4=1=> TX, A4=0=>RX
 * A5=1=>LATCH (Default mode), A5=0=>Momentary the stting now is via variable latch_logic if 1=> latch if 0=> momentary
 * NANO connections to HC-12 As follows:
 * ARDUINO NANO                                        HC-12-MODULE
 * _________________________________________________________________________
 * 5V            -> 1N4148 Anode, 1N4148 catode ->     HC-12/Pin-1 (VCC)
 * GND                  ------->                          GND
 * D11                  ------->                          RXD
 * D10                  ------->                          TXD
 * NANO (TX MODULE)                              NANO (RX MODULE)
 * ______________________                    ________________________________
 * D2 --> SW --> GND (SW1)                   A4 --> GND
 * D3 --> SW --> GND (SW2)                   D2 --> OUTPUT 1
 * D4 --> SW --> GND (SW3)                   D3 --> OUTPUT 2
 * D5 --> SW --> GND (SW4)                   D4 --> OUTPUT 3
 *                                           D5 --> OUTPUT 4
 *  FEEDBACK back will light Led on Trnasmitter for 100mS
 *  See connection Diagram here:
 *  https://goo.gl/photos/qog8gWPKpSDPgZen7
#define P1 2
#define P2 3
#define P3 4
#define P4 5
#define F1 6 // feedback back to transmitter
//#define latch_logic 1 // if 1 then latch if 0 momentary
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
char latch; // , if latch=1 then Latch
int read_A4, read_A5, i, read_P1, read_P2, read_P3, read_P4;
int TX_CODE, RX_READ, mode, TX_CODE_OLD; //if mode= 1 then TX
int RP1, RP2, RP3, RP4;
volatile byte SW1 = 0, SW2 = 0, SW3 = 0, SW4 = 0;
boolean S1, S2, S3, S4;
byte TEST;
char TXTOSEND,feedback;
int FLAG=1,latch_logic;
  mySerial.begin(9600);
  Serial.println("Hello HC-12 TX and RX SW, A4-Low=TX A4-HIGH=RX A5-LOW=Momemtary A5-HIGH=LATCH");
 // mySerial.println("Hello HC-12 TX and RX SW, A4-Low=TX A4-HIGH=RX A5-LOW=Momemtary A5-HIGH=LATCH");
  // This is for internal pull ups resistors on A4 and A5 Inputs
  pinMode(A4, INPUT_PULLUP);
  pinMode(A5, INPUT_PULLUP);
  read_A4 = analogRead(A4);
  read_A5 = analogRead(A5);
  if ((read_A4) > 500) {
    mode = 1;
    Serial.println("TX Mode");
    mode = 0;
    Serial.println("RX Mode");
  if ((read_A5) > 500) {
    latch = 1;
    latch_logic=latch;
    Serial.println("LATCH Mode");
    latch = 0;
    latch_logic=latch;
    Serial.println("Momentary Mode");
  if (mode == 1) // TX
    pinMode(P1, INPUT);           // set pin to input
    digitalWrite(P1, HIGH);       // turn on pullup resistors
    pinMode(P2, INPUT);           // set pin to input
    digitalWrite(P2, HIGH);       // turn on pullup resistors
    pinMode(P3, INPUT);           // set pin to input
    digitalWrite(P3, HIGH);       // turn on pullup resistors
    pinMode(P4, INPUT);           // set pin to input
    digitalWrite(P4, HIGH);       // turn on pullup resistors
    pinMode(F1, OUTPUT);           // set pin to input
    digitalWrite(F1, LOW);
    pinMode(P1, OUTPUT);           // set pin to input
    digitalWrite(P1, LOW);       // turn on pullup resistors
    pinMode(P2, OUTPUT);           // set pin to input
    digitalWrite(P2, LOW);       // turn on pullup resistors
    pinMode(P3, OUTPUT);           // set pin to input
    digitalWrite(P3, LOW);       // turn on pullup resistors
    pinMode(P4, OUTPUT);           // set pin to input
    digitalWrite(P4, LOW);       // turn on pullup resistors
  if (mode == 1) //TX Mode
    TX_MODE();
    RX_MODE();
void TX_MODE()
  while (1)
      read_P1 = digitalRead(P1);
      read_P2 = digitalRead(P2);
      read_P3 = digitalRead(P3);
      read_P4 = digitalRead(P4);
      TX_CODE = 64 + (read_P1 * 1) + (read_P2 * 2) + (read_P3 * 4) + (read_P4 * 8); // converting TX to one char
      TXTOSEND = TX_CODE; // conver to char for sending OK
      if (FLAG==0) // skip first time on FLAG=1
          if (latch==1)
              if ((TX_CODE != TX_CODE_OLD)&&(latch_logic==1))  // transmit only on change
                Serial.print(TX_CODE, BIN);
                mySerial.print(TXTOSEND);
              delay(100);
              TX_CODE_OLD = TX_CODE;
                delay(100);
      else FLAG=0;
    feedback=mySerial.read();
    if (feedback=='R')
    Serial.println("Data_Sent_OK"); // feedback to serial port
    digitalWrite(F1, HIGH);    // Ligjt Led Back on Transmitter
    delay(80);
void RX_MODE()
  while (1)
    if (mySerial.available()) {
      // read the incoming byte:
      RX_READ = mySerial.read();
      TEST = RX_READ;
      RP1 = (TEST) & (1);
      RP2 = (TEST) & (2);
      RP3 = (TEST) & (4);
      RP4 = (TEST) & (8);
      mySerial.flush();
      // When button is pressed (logic 0) toggling the apropriate LED Latch mode only
      if ((latch==1)&&(latch_logic==1))
        if (RP1 == 0) SW1 = ~(SW1);
        if (RP2 == 0) SW2 = ~(SW2);
        if (RP3 == 0) SW3 = ~(SW3);
        if (RP4 == 0) SW4 = ~(SW4);
         mySerial.print("R"); // This is feedback back to transmitter
          else // Momentary mode ON only when button is pressed continously
        if (RP1 == 0)
          SW1 = 1;
        } else SW1=0;
        if (RP2 == 0)
          SW2 = 1;
        }  else SW2=0;
        if (RP3 == 0)
          SW3 = 1;
        } else SW3=0;
        if (RP4 == 0)
          SW4 = 1;
        }  else SW4=0;
//convert to bit for Digital-Out from Arduino
       S1= SW1 & 1;
       S2= SW2 & 1;
       S3= SW3 & 1;
       S4= SW4 & 1;
       digitalWrite(P1, S1);
       digitalWrite(P2, S2);
       digitalWrite(P3, S3);
       digitalWrite(P4, S4);
      delay(100);
      Serial.print("S1=");
      Serial.print(SW1);
      Serial.print("  S2=");
      Serial.print(SW2);
      Serial.print("  S3=");
      Serial.print(SW3);
      Serial.print("  S4=");
      Serial.println(SW4);
}[/code]
When do you want the buzzer to sound ?
How long should the buzzer sound for ?
Does it matter if the program stops doing anything else whilst the buzzer sounds ?
Is it an active buzzer that makes a noise when power is connected or does it need to be driven by a signal to produce a tone ?
Did you write the program ?
i want the buzzer sound together with the led output when it is high..and the buzzer will turn off if the led output turn to low.....
It should turn off together with led output turn low..
No I just copy the program.. Can you help me please
I suspected as much.
Do you know how to write a small program that sounds the buzzer for 1 second then turns it off for one second then repeats ?
beginners123:
beginners123:
Then, I assume some other aspect of the project is your original work and the code is just ancillary to it?
