Connected a SX1262 to a ESP32C6_Dev_Board
using RadioLib library SX126x_Transmit_Interrupt example
// ESP32C6_Dev_Board SX1262 LoRa P2P Transmit_Interrupt
// File>Examples>RadioLib>SX126x>SX126x_Transmit_Interrupt
// EDITs:
// radio.begin frequency set to 868.0
// transmitting byte array and printing it
RadioLib SX126x Transmit with Interrupts Example
This example transmits LoRa packets with one second delays
between them. Each packet contains up to 256 bytes
of data, in the form of:
- Arduino String
- null-terminated char array (C-string)
- arbitrary binary data (byte array)
Other modules from SX126x family can also be used.
For default module settings, see the wiki page
https://github.com/jgromes/RadioLib/wiki/Default-configuration#sx126x---lora-modem
For full API reference, see the GitHub Pages
https://jgromes.github.io/RadioLib/
// include the library
#include <RadioLib.h>
// ESP32C6 GPIOs to SX1262 has the following connections:
// MOSI: 19
// MISO: 20
// SCK: 21
#define NSS 18
#define DIO1 10
#define NRST 11
#define BUSY 15
SX1262 radio = new Module(NSS, DIO1, NRST, BUSY); // SS DIO1 NRST BUSY
// or detect the pinout automatically using RadioBoards
// https://github.com/radiolib-org/RadioBoards
#define RADIO_BOARD_AUTO
#include <RadioBoards.h>
Radio radio = new RadioModule();
// save transmission state between loops
int transmissionState = RADIOLIB_ERR_NONE;
// flag to indicate that a packet was sent
volatile bool transmittedFlag = false;
// this function is called when a complete packet
// is transmitted by the module
// IMPORTANT: this function MUST be 'void' type
// and MUST NOT have any arguments!
#if defined(ESP8266) || defined(ESP32)
ICACHE_RAM_ATTR
#endif
void setFlag(void) {
// we sent a packet, set the flag
transmittedFlag = true;
delay(2000);
// initialize SX1262 with default settings
Serial.print(F("\n\nESP32C6 [SX1262] Initializing ... "));
int state = radio.begin(868.0);
if (state == RADIOLIB_ERR_NONE) {
Serial.println(F("success!"));
Serial.print(F("failed, code "));
Serial.println(state);
while (true) { delay(10); }
// set the function that will be called
// when packet transmission is finished
radio.setPacketSentAction(setFlag);
// start transmitting the first packet
Serial.print(F("[SX1262] Sending first packet ... "));
// you can transmit C-string or Arduino string up to
// 256 characters long
transmissionState = radio.startTransmit("Hello World!");
// you can also transmit byte array up to 256 bytes long
byte byteArr[] = {0x01, 0x23, 0x45, 0x67,
0x89, 0xAB, 0xCD, 0xEF};
state = radio.startTransmit(byteArr, 8);
// counter to keep track of transmitted packets
int count = 0;
// check if the previous transmission finished
if (transmittedFlag) {
// reset flag
if (transmissionState == RADIOLIB_ERR_NONE) {
// packet was successfully sent
Serial.println(F("transmission finished!"));
// NOTE: when using interrupt-driven transmit method,
// it is not possible to automatically measure
// transmission data rate using getDataRate()
Serial.println(transmissionState);
// clean up after transmission is finished
// this will ensure transmitter is disabled,
// RF switch is powered down etc.
radio.finishTransmit();
// wait a second before transmitting again
// send another one
Serial.print(F("[SX1262] Sending another packet ... "));
//String str = "Hello World! #" + String(count++);
//transmissionState = radio.startTransmit(str);
static byte byteArr[] = { 0x01, 0x23, 0x45, 0x67,
0x89, 0xAB, 0xCD, 0xEF };
for (int i = 0; i < sizeof(byteArr); i++)
Serial.printf("%d ", byteArr[i]);
transmissionState = radio.startTransmit(byteArr, 8);
byteArr[0]++;
ESP32C6 transmitter output
ESP32C6 [SX1262] Initializing ... success!
[SX1262] Sending first packet ... transmission finished!
[SX1262] Sending another packet ... 1 35 69 103 137 171 205 239 transmission finished!
[SX1262] Sending another packet ... 2 35 69 103 137 171 205 239 transmission finished!
[SX1262] Sending another packet ... 3 35 69 103 137 171 205 239 transmission finished!
[SX1262] Sending another packet ... 4 35 69 103 137 171 205 239 transmission finished!
[SX1262] Sending another packet ... 5 35 69 103 137 171 205 239 transmission finished!
[SX1262] Sending another packet ... 6 35 69 103 137 171 205 239 transmission finished!
[SX1262] Sending another packet ... 7 35 69 103 137 171 205 239 transmission finished!
[SX1262] Sending another packet ... 8 35 69 103 137 171 205 239 transmission finished!
[SX1262] Sending another packet ... 9 35 69 103 137 171 205 239 transmission finished!
Heltec LoRa V3 receiver output
Heltec LoRa V3 [SX1262] Initializing ... success!
[SX1262] Starting to listen ... success!
[SX1262] Received packet!
[SX1276] Data: 1 35 69 103 137 171 205 239
[SX1262] RSSI: -35.00 dBm
[SX1262] SNR: 10.75 dB
[SX1262] Frequency error: -664.56 Hz
[SX1276] Data: 2 35 69 103 137 171 205 239
[SX1262] RSSI: -34.00 dBm
[SX1262] SNR: 11.25 dB
[SX1262] Frequency error: -668.44 Hz
[SX1276] Data: 3 35 69 103 137 171 205 239
[SX1262] RSSI: -33.00 dBm
[SX1276] Data: 4 35 69 103 137 171 205 239
[SX1262] SNR: 10.50 dB
[SX1276] Data: 5 35 69 103 137 171 205 239
[SX1262] SNR: 11.00 dB
[SX1276] Data: 6 35 69 103 137 171 205 239
[SX1276] Data: 7 35 69 103 137 171 205 239
[SX1276] Data: 8 35 69 103 137 171 205 239
[SX1276] Data: 9 35 69 103 137 171 205 239
photo of ESP32C6
