Hi. I am using liquid nitrogen for cooling my experimental setup (it's a thermal based project). So, I was wondering what sensor I can use for measuring temperatures as low as -196 C?
(I know from theory it can be a T type thermocouple; but on searching online, I am not able to find it or any other sensor)
Hey. Like I guess I'm using google India, so all the sensors available in Indian market is being shown. Also, for some T type thermocouples, the minimum temperature is nowhere near -196 C.
Yeah... but it's like the liquid nitrogen is being used to cool down a system, but I need to see what exactly is the final temperature of cooled air at some distance from this cooling chamber.
We used thermocouples in the Water Resources department to monitor motor bearings etc.
Practice there was to use the iron/constantan wiring to the thermocouple AND the use of the same metals terminal blocks.
Any other metals will throw your results in the rubbush bin.
T Copper (+) vs. Constantan (-)
MAXIMUM TEMPERATURE RANGE
Thermocouple Grade
– 328 to 662°F
– 200 to 350°C
Extension Grade
– 76 to 212°F
– 60 to 100°C
LIMITS OF ERROR
(Whichever is greater)
Standard: 1.0°C or 0.75% Above 0°C
1.0°C or 1.5% Below 0°C
Special: 0.5°C or 0.4%
COMMENTS, BARE WIRE ENVIRONMENT:
Mild Oxidizing, Reducing Vacuum or Inert; Good
Where Moisture Is Present; Low Temperature
and Cryogenic Applications
TEMPERATURE IN DEGREES °C
REFERENCE JUNCTION AT 0°C
I used Type T extensively for cryogenic work including plenty of LN (Liquid Nitrogen). The IndiaMart seems to have plenty of Type T Thermocouples available in India.
You need to decide exactly which thermocouple design you want? Grounded or ungrounded, sheath material if you want a sheath, sheath diameter, how fast response time and the list goes on.
This may be worth a try. The below pdf describes how to make accurate cryogenic measurements using a 1N914 diode and an LM317 regulator as a current source
