While loop is not working
Hi iv been trying to get my while loops to work on this code but whenever I use serial monitor the rate at which it prints the values in the loop while the conditions are met. when i add a small serial print out off the loop you can see it being printed how could i fix this
const int M11 = 6;
const int M12 = 5;  // RIGHT WHEEL
const int M21 = 9;  // LEFT WHEEL
const int M22 = 10;
int const IRB = A0;  // labeling front and back sensor for IR
int const IRF = A1;
int const TRIG1 = 2;
int const ECHO1 = 3;
int const TRIG2 = 7;
int const ECHO2 = 8;
long distance;
long distance1;
  pinMode(TRIG1, OUTPUT);
  pinMode(ECHO1, INPUT);
  pinMode(TRIG2, OUTPUT);
  pinMode(ECHO2, INPUT);
  pinMode(M11, OUTPUT);
  pinMode(M12, OUTPUT);
  pinMode(M21, OUTPUT);
  pinMode(M22, OUTPUT);
  pinMode(IRF, INPUT);
  int IRFR;                 // front IR sensor value
  int IRBR;                 // back IR sensor value
  long ULTRAF;
  long ULTRAB;
   ULTRAF = ULTRASONICF(TRIG1, ECHO1);
   ULTRAB = ULTRASONICB (TRIG2 , ECHO2);
   IRFR = IRCHECKF();
  while ( ULTRAF>30 && IRFR == 1){
        Serial.println ("666666");
        IRFR = IRCHECKF();
  while (1<= ULTRAF && ULTRAF<=30 && IRFR == 1) {
        Serial.print("SALMON");
          IRFR = IRCHECKF();
          ULTRAF= ULTRASONICF(TRIG1, ECHO1);
          STOP();
        while ( 1<= ULTRAF && ULTRAF <= 30 && IRFR == 0){
            IRFR = IRCHECKF();
            Serial.print("cat");
            STOP();
        while (IRFR == 0 && ULTRAF >30){
            Serial.println ("WOOOOOOOOOOOO");
            IRFR = IRCHECKF();
            STOP();
void FORWARD(int SPEED1, int SPEED2)  // drivers motors forward
  analogWrite(M11, SPEED1);
  analogWrite(M12, 0);
  analogWrite(M21, 0);
  analogWrite(M22, SPEED2);
void BACKWARD(int SPEED1, int SPEED2)  // drives motors backwards
  analogWrite(M11, 0);
  analogWrite(M12, SPEED1);
  analogWrite(M21, SPEED2);
  analogWrite(M22, 0);
void STOP()  // stops motors
void TURNLEFT() {
void TURNRIGHT() {
void TURN50() {
  analogWrite(M11, 100);
  analogWrite(M21, 100);
int ULTRASONICF(int pingPin, int echoPin) {
  long duration, inches, cm;
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(10);
  pinMode(echoPin, INPUT);
  duration = pulseIn(echoPin, HIGH);
  cm = microsecondsToCentimeters(duration);
  return cm;
int ULTRASONICB(int pingPin, int echoPin) {
  return cm;
 int IRCHECKF(){
 int IRFR;
  IRFR = digitalRead(IRF);
  return IRFR;
 int IRCHECKB(){
 int IRBR;
 IRBR = digitalRead(IRB);
 return IRBR;
long microsecondsToCentimeters(long microseconds) {
  return microseconds / 29 / 2;
if i add this outside off all the while loops
Serial.print("nah");
this constantly prints out as shown in this photo
Others can probably catch a coding error, I cannot.
However to troubleshoot I would print IRFR and ULTRAF just before the while loop.
I have done that and the values are still the same as needed for the clause however it keeps leaving the loop and treating the while loop as an if clause
To address the issue with your while loop's timing in your code, ensure the loop condition is correctly set, avoid blocking code, use serial debugging to pinpoint issues, check setup and initialization, and simplify your code if necessary.
will have a look thanks
Sorry, I didn't understand - why do you think this shouldn't happen?
Your code loops in one while twice and then finishing the loop().
What's wrong with it?
Hi @sherryghory12
welcome to the arduino-forum.
Well done posting your code as a code-section in your very first posting.
Your text is too short to be understandable
what is the rate ? Is it
  • too fast?
  • too slow?
  • does not print at all?
what conditions are met? Of which while-loop?
  • every while loop?
  • one particular one?
How can you fix exactly what?
You should describe in detail what behaviour you want.
As a general advice:
You started this thread 3 hours ago.
There is no solution yet.
If you would have taken 20 minutes of your precious time to post a detailed description
the problem would already be solved
trying to be quick by writing a short posting in 2 minutes delayed the solution now for 180 minutes.
Not very efficient.
So please take the time to describe the wanted behaviour in detail by writing down ALL the details that occur.
If I write ALL i mean ALL details.
Starting with
front-ultrasonic measures a distance of "X"
variable ULTRAF contains value "Y"
IR-sensor front detects nothing which means variable "IRFR" contains "what value?"
ect. etc. etc.
It might well be that you are doing the ultrasonic "pings" to fast after each other.
Sound has a speed of 340 m/second. For travelling a distance of 2x50 cm the time is
1 m / 340 m = 3 milliseconds. But you have multiple echoes. Before creating the next ping you should wait at least 50 milliseconds that the former ping-echoes have faded away.
If you are pinging too fast all the still active echoes disturb the measurings.
Here is a code-version with two added things:
  1. macros that do serial debugging in different ways
    print only once if a value has changed etc.
  2. has a non-blocking timing-function "TimePeriodIsOver()" which does two things:
a. keep the loop looping very fast
b. execute a ping only once every 100 milliseconds
you can adjust this time by modifying the value of constant myWaitTime
const unsigned long myWaitTime = 100; // milliseconds between ultrasonic pings
change baudrate in the serial monitor to the modern value of 115200
// MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START * MACRO-START *
// a detailed explanation how these macros work is given in this tutorial
// https://forum.arduino.cc/t/comfortable-serial-debug-output-short-to-write-fixed-text-name-and-content-of-any-variable-code-example/888298
#define dbg(myFixedText, variableName) \
  Serial.print( F(#myFixedText " "  #variableName"=") ); \
  Serial.println(variableName);
#define dbgi(myFixedText, variableName,timeInterval) \
    static unsigned long intervalStartTime; \
    if ( millis() - intervalStartTime >= timeInterval ){ \
      intervalStartTime = millis(); \
      Serial.println(variableName); \
#define dbgc(myFixedText, variableName) \
    static long lastState; \
    if ( lastState != variableName ){ \
      Serial.print( F(#myFixedText " "  #variableName" changed from ") ); \
      Serial.print(lastState); \
      Serial.print( F(" to ") ); \
      lastState = variableName; \
#define dbgcf(myFixedText, variableName) \
    static float lastState; \
// MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END * MACRO-END *
unsigned long MyTestTimer = 0;  // Timer-variables MUST be of type unsigned long
const byte    OnBoard_LED = 13; // onboard-LED uno, mega
  if ( TimePeriodIsOver(MyTestTimer,1000) ) {
unsigned long MyPingTimer = 0; // Timer-variables MUST be of type unsigned long
const int M11 = 6;
const int M22 = 10;
int const IRF = A1;
long distance;
long distance1;
  Serial.println("Setup-Start");
  PrintFileNameDateTime();
  //Serial.begin(9600);
  BlinkHeartBeatLED(OnBoard_LED, 250);
  long ULTRAF;
  long ULTRAB;
  // print variable NAME and variable-VALUE
  // only in case the value has CHANGED
  dbgc("01",ULTRAF);
  dbgc("02",ULTRAB);
  IRFR = IRCHECKF();
  dbgc("03",IRFR);
  while ( ULTRAF > 30 && IRFR == 1) {
    // check if myWaitTime milliseconds have passed by
    if ( TimePeriodIsOver(MyPingTimer, myWaitTime) ) {
      // when 100 milliseconds really HAVE passed by do the next ultrasonic ping
    IRFR = IRCHECKF();
  while (1 <= ULTRAF && ULTRAF <= 30 && IRFR == 1) {
      // when myWaitTime milliseconds really HAVE passed by do the next ultrasonic ping
      IRFR = IRCHECKF();
      // don't do pings too fast. This does not work
      // the pings will overlap. You have to let time pass by
      // until the first pings echoes vanished
      // ULTRAF = ULTRASONICF(TRIG1, ECHO1); // commented out
      STOP();
  while ( 1 <= ULTRAF && ULTRAF <= 30 && IRFR == 0) {
      IRFR = IRCHECKF();
      STOP();
  while (IRFR == 0 && ULTRAF > 30) {
      IRFR = IRCHECKF();
      STOP();
void TURNLEFT() {
void TURNRIGHT() {
void TURN50() {
  return cm;
  return cm;
int IRCHECKF() {
  int IRFR;
  return IRFR;
int IRCHECKB() {
  int IRBR;
  return IRBR;
// helper-functions
void PrintFileNameDateTime() {
  Serial.println( F("Code running comes from file ") );
  Serial.println( F(__FILE__) );
  Serial.print( F("  compiled ") );
  Serial.print( F(__DATE__) );
  Serial.print( F(" ") );
  Serial.println( F(__TIME__) );
// easy to use helper-function for non-blocking timing
// explanation see here
// https://forum.arduino.cc/t/example-code-for-timing-based-on-millis-easier-to-understand-through-the-use-of-example-numbers-avoiding-delay/974017
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
  unsigned long currentMillis  = millis();
  if ( currentMillis - startOfPeriod >= TimePeriod ) {
    // more time than TimePeriod has elapsed since last time if-condition was true
    startOfPeriod = currentMillis; // a new period starts right here so set new starttime
    return true;
  else return false;            // actual TimePeriod is NOT yet over
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
  static unsigned long MyBlinkTimer;
  pinMode(IO_Pin, OUTPUT);
  if ( TimePeriodIsOver(MyBlinkTimer, BlinkPeriod) ) {
    digitalWrite(IO_Pin, !digitalRead(IO_Pin) );
