White Screen ILI9341 2.8" TFT w/ built-in SD card module
Good day, so I have this project I've been working on for a while where I need to display images on a TFT screen. I'll be pulling the images from the built-in sd card module that comes with the screen. graphicstest is working fine as well as the sd card reader, only problem is when I load up an example sketch for displaying images from the SD, the screen is stuck on white. I've racked my brain as to why but can't seem to find an answer.
`// Adafruit_ImageReader test for Adafruit ILI9341 TFT Shield for Arduino.
// Demonstrates loading images from SD card or flash memory to the screen,
// to RAM, and how to query image file dimensions.
// Requires three BMP files in root directory of SD card:
// purple.bmp, parrot.bmp and wales.bmp.
// As written, this uses the microcontroller's SPI interface for the screen
// (not 'bitbang') and must be wired to specific pins (e.g. for Arduino Uno,
// MOSI = pin 11, MISO = 12, SCK = 13). Other pins are configurable below.
#include <Adafruit_GFX.h>         // Core graphics library
#include <Adafruit_ILI9341.h>     // Hardware-specific library
#include <SdFat.h>                // SD card & FAT filesystem library
#include <Adafruit_SPIFlash.h>    // SPI / QSPI flash library
#include <Adafruit_ImageReader.h> // Image-reading functions
// Comment out the next line to load from SPI/QSPI flash instead of SD card:
#define USE_SD_CARD
// TFT display and SD card share the hardware SPI interface, using
// 'select' pins for each to identify the active device on the bus.
#define SD_CS   7// SD card select pin
#define TFT_CS 10 // TFT select pin
#define TFT_DC  9 // TFT display/command pin
#define TFT_RST 8
#define TFT_MOSI 11 // TFT display/command pin
#define TFT_MISO 12
#define TFT_CLK 13
#if defined(USE_SD_CARD)
  SdFat                SD;         // SD card filesystem
  Adafruit_ImageReader reader(SD); // Image-reader object, pass in SD filesys
#else
  // SPI or QSPI flash filesystem (i.e. CIRCUITPY drive)
  #if defined(__SAMD51__) || defined(NRF52840_XXAA)
    Adafruit_FlashTransport_QSPI flashTransport(PIN_QSPI_SCK, PIN_QSPI_CS,
      PIN_QSPI_IO0, PIN_QSPI_IO1, PIN_QSPI_IO2, PIN_QSPI_IO3);
  #else
    #if (SPI_INTERFACES_COUNT == 1)
      Adafruit_FlashTransport_SPI flashTransport(SS, &SPI);
    #else
      Adafruit_FlashTransport_SPI flashTransport(SS1, &SPI1);
    #endif
  #endif
  Adafruit_SPIFlash    flash(&flashTransport);
  FatVolume        filesys;
  Adafruit_ImageReader reader(filesys); // Image-reader, pass in flash filesys
#endif
Adafruit_ILI9341     tft    = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_MISO, TFT_CLK);
Adafruit_Image       img;        // An image loaded into RAM
int32_t              width  = 0, // BMP image dimensions
                     height = 0;
void setup(void) {
  ImageReturnCode stat; // Status from image-reading functions
#if !defined(ESP32)
  while(!Serial);       // Wait for Serial Monitor before continuing
#endif
  tft.begin();          // Initialize screen
  // The Adafruit_ImageReader constructor call (above, before setup())
  // accepts an uninitialized SdFat or FatVolume object. This MUST
  // BE INITIALIZED before using any of the image reader functions!
  Serial.print(F("Initializing filesystem..."));
  // SD card is pretty straightforward, a single call...
  if(!SD.begin(SD_CS, SD_SCK_MHZ(25))) { // ESP32 requires 25 MHz limit
    Serial.println(F("SD begin() failed"));
    for(;;); // Fatal error, do not continue
#else
  // SPI or QSPI flash requires two steps, one to access the bare flash
  // memory itself, then the second to access the filesystem within...
  if(!flash.begin()) {
    Serial.println(F("flash begin() failed"));
    for(;;);
  if(!filesys.begin(&flash)) {
    Serial.println(F("filesys begin() failed"));
    for(;;);
#endif
  Serial.println(F("OK!"));
  // Fill screen blue. Not a required step, this just shows that we're
  // successfully communicating with the screen.
  tft.fillScreen(ILI9341_BLUE);
  // Load full-screen BMP file 'purple.bmp' at position (0,0) (top left).
  // Notice the 'reader' object performs this, with 'tft' as an argument.
  Serial.print(F("Loading purple.bmp to screen..."));
  stat = reader.drawBMP("/woof.bmp", tft, 0, 0);
  reader.printStatus(stat);   // How'd we do?
  // Query the dimensions of image 'parrot.bmp' WITHOUT loading to screen:
  Serial.print(F("Querying parrot.bmp image size..."));
  stat = reader.bmpDimensions("/tiger.bmp", &width, &height);
  if(stat == IMAGE_SUCCESS) { // If it worked, print image size...
    Serial.print(F("Image dimensions: "));
    Serial.print(width);
    Serial.write('x');
    Serial.println(height);
  // Load small BMP 'wales.bmp' into a GFX canvas in RAM. This should fail
  // gracefully on Arduino Uno and other small devices, meaning the image
  // will not load, but this won't make the program stop or crash, it just
  // continues on without it. Should work on Arduino Mega, Zero, etc.
  // How'd we do?
  delay(2000); // Pause 2 seconds before moving on to loop()
  for(int r=0; r<4; r++) { // For each of 4 rotations...
    tft.setRotation(r);    // Set rotation
    tft.fillScreen(0);     // and clear screen
    // Load 4 copies of the 'parrot.bmp' image to the screen, some
    // partially off screen edges to demonstrate clipping. Globals
    // 'width' and 'height' were set by bmpDimensions() call in setup().
    for(int i=0; i<4; i++) {
      reader.drawBMP("/tiger.bmp", tft,
        (tft.width()  * i / 3) - (width  / 2),
        (tft.height() * i / 3) - (height / 2));
    delay(1000); // Pause 1 sec.
    // Draw 50 Welsh dragon flags in random positions. This has no effect
    // on memory-constrained boards like the Arduino Uno, where the image
    // failed to load due to insufficient RAM, but it's NOT fatal.
    for(int i=0; i<50; i++) {
      // Rather than reader.drawBMP() (which works from SD card),
      // a different function is used for RAM-resident images:
      img.draw(tft,                                    // Pass in tft object
        (int16_t)random(-img.width() , tft.width()) ,  // Horiz pos.
        (int16_t)random(-img.height(), tft.height())); // Vert pos
      // Reiterating a prior point: img.draw() does nothing and returns
      // if the image failed to load. It's unfortunate but not disastrous.
    delay(2000); // Pause 2 sec.
First thing, that display is almost certainly a 3.3V device, and the Uno you have pictured is a 5V device. I don't see any level shifters on any of the signal lines, and that's not good.
Second thing to check is to see if the display controller is tristating MISO when it's not selected. It's quite common for it not to be tristated with these displays, and that prevents the SD card from being communicated with.
I've put resistors for the signal lines so that's fine... but about the second thing you mentioned, how do I check that? I've got a feeling that's my problem here, only the other way around since serial monitor is showing that the files in my SD are being read and displayed on the lcd which is as I've stated above just displays white instead.
A read through of PJRC's Better SPI Bus Design in 3 Steps would give you a good grounding in what to look for and how to fix it.
As a Q&D check, try pulling the connection to the display's MISO line (not the SD card's). If your code never reads from the display, it ought to start working (obviously, do this with the power off).
