White square in Monitor serial ESP32 HX711 loader cells
Hi There,
My name is Thomas. I am french. Sorry for my english.
I worked with studients to create a prototype with ESP32 Lolin32 V1.0.0.
It is a scale with loader cells and HX711.
The C program worked well in Arduino IDE at school with the studients. But When I tried to upload the C Code with my computer at home nothing happens in the Monitor Serial. To be accurate one thing happens : white square appears sometimes when I pressed on the load cell.
The studients created a interface with DELs on breadboard. It works well. So the board is correct and all the connection works well also.
Another code can print in Monitor serial datas so I think the Monitor serial is OK.
I used Linux Ubuntu Budgie and windows 11 with Arduino IDE 2.3. I can see the square in both situation.
So everything is ok in the OS.
I changed the HX711 librairie. Nothing changed.
So do you have an idea of this issue?
  Description du programe
  Created for arduino-esp32 en Janvier, 2024
  par
//Declaration des bibliotheques utilisees dans ce programme
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiAP.h>
#include "HX711.h"
// Declaration du nom du reseau wifi ainsi que le mot de passe du reseau.
const char *ssid = "yourAP";
const char *password = "yourPassword";
// Définir les broches pour les amplificateurs HX711 et les LEDs
const int ampli1_dout = 4;
const int ampli1_sck = 0;
const int ampli2_dout = 5;
const int ampli2_sck = 18;
// declaration du bouton reset
const int reset = 39;
int etatreset =0;
const int ledreset = 33;
const int ledRG = 32;  // LED rouge gauche
const int ledJ2G = 13; // LED jaune 2 gauche
const int ledJ1G = 1;   // LED Jaune 1 gauche
const int ledV = 26;  // LED verte
const int ledJ1D = 27;  // LED jaune 1 droite
const int ledJ2D = 14;  // LED jaune 2 droite
const int ledRD = 12;  // LED rouge droite
int DeltaMesure = 500;
HX711 ampli1;
HX711 ampli2;
WiFiServer server(80);
  // Configuration du mode des pins des Leds
  pinMode(ledRG, OUTPUT);
  pinMode(ledJ2G, OUTPUT);
  pinMode(ledJ1G, OUTPUT);
  pinMode(ledV, OUTPUT);
  pinMode(ledJ1D, OUTPUT);
  pinMode(ledJ2D, OUTPUT);
  pinMode(ledRD, OUTPUT);
  pinMode(ledreset, OUTPUT);
  pinMode(reset, INPUT);
  // Configurer les amplificateurs HX711
  ampli1.begin(ampli1_dout, ampli1_sck);
  ampli2.begin(ampli2_dout, ampli2_sck);
  // Tare les amplificateurs HX711
  ampli1.tare();
  ampli2.tare();
  digitalWrite(ledJ1G, LOW);
  Serial.println("Configuring access point...");
  // You can remove the password parameter if you want the AP to be open.
  // a valid password must have more than 7 characters
  if (!WiFi.softAP(ssid, password)) {
    log_e("Soft AP creation failed.");
    while(1);
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("AP IP address: ");
  Serial.println(myIP);
  server.begin();
  Serial.println("Server started");
// Fonction pour allumer une LED spécifique et éteindre les autres
void allumerLED(int pin) {
  digitalWrite(ledRG, LOW);
  digitalWrite(ledJ2G, LOW);
  digitalWrite(ledV, LOW);
  digitalWrite(ledJ1D, LOW);
  digitalWrite(ledJ2D, LOW);
  digitalWrite(ledRD, LOW);
  digitalWrite(ledreset, LOW);
  digitalWrite(pin, HIGH);
  // Lire les valeurs des cellules de charge via les amplificateurs HX711
  long valeur1 = ampli1.get_units(1);
  long valeur2 = ampli2.get_units(1);
  // Lire la valeur du bouton
  etatreset = digitalRead(reset);
  // Calculer la différence entre les valeurs
  long difference = valeur1 - valeur2;
  int facteurdecharge = 40; // déterminer apres des mesures avec des poids que l'on connait
  int poids = abs(difference)/facteurdecharge; // conversion de la différence en gramme
  float poidsTot = (abs(valeur1) + abs(valeur2))/40; //poids total de la personne en gramme
  float ratio1 = (abs(valeur1)/40)/poidsTot; // calcul du ratio mesuré par le premier ampli
  float ratio2  = (abs(valeur2)/40)/poidsTot;  // calcul du ratio mesuré par le deuxieme ampli
//si le bouton reset est appuyé alors on tare les ampli
  if (etatreset == LOW){
    Serial.println("reset");
    ampli1.tare();
    ampli2.tare();
    allumerLED(ledreset);
  // sinon on mesure les valeurs
  else{
    if (poidsTot<= 2000) {
      allumerLED(ledV);
      ratio1 = 0.5;
      ratio2 = 0.5;
    else{
    // allumer les LEDs en fonction du ratio
      if (ratio1 < 0.15) {
        allumerLED(ledRG);
      } else if ((ratio1 >= 0.15) && (ratio1 < 0.30)) {
        allumerLED(ledJ2G);
      } else if ((ratio1 >= 0.30) && (ratio1 < 0.41)){
        allumerLED(ledJ1G);
      } else if ((ratio1 >= 0.41) && (ratio1 < 0.59)){
        allumerLED(ledV);
      }else if ((ratio1 >= 0.59) && (ratio1 < 0.70)){
        allumerLED(ledJ1D);
      } else if ((ratio1 >= 0.70) && (ratio1 < 0.85)){
        allumerLED(ledJ2D);
      } else if (ratio1 >= 0.85) {
        allumerLED(ledRD);
    delay(DeltaMesure);  // Attendre DeltaMesure miliseconde entre chaque itération
  WiFiClient client = server.available();   // listen for incoming clients
  //definition de la page HTML
  client.println("Content-type:text/html");
  client.println();
  client.println("<html><head>");
  client.println("<title>Interface </title>");
  //client.println("<meta http-equiv=\"refresh\" content=\"1\">");
  //definition des elements visuels de la page
  client.println("<style>body {font-family: Arial, sans-serif;margin: 0;padding: 0;}h1{text-align: center;margin-top: 50px;font-size: 50px;}.container {max-width: 600px;margin: 0 auto;padding: 20px;background-color: rgba(255, 255, 255, 0.8);border-radius: 10px;box-shadow: 0 0 10px rgba(0, 0, 0, 0.3);margin-top: 50px;}.demi-cercle-container {position: relative;width: 200px;height: 100px;overflow: visbile;margin: 0 auto;}.demi-cercle {position: absolute;width: 100%;height: 100%;background: conic-gradient( at 50% 0%,#FF0000 25% 32.5%,#ffa200 32.5%  40%,#FFFF00 40% 44.5%,#98fb98 44.5% 55.5%,#FFFF00 55.5% 60%,#ffa200 60% 67.5%,#FF0000 67.5% 75%) bottom;border-radius: 0 0 100px 100px;border: 0px solid #000;transform: rotate(180deg);}.aiguille {position: absolute;width: 2px;height: 95px;bottom: 0;left: 50%;background-color: #000;transform-origin: 0% 100%;transform: translateX(-50%) rotate(0deg);transition: transform 0.5s ease-in-out;}.button-container {text-align: center;margin-top: 20px;}button {padding: 10px 20px;font-size: 16px;cursor: pointer;}.background-content {background-color: #add8e6;background-repeat: repeat-x;background-position: top center;padding-top: 80px;text-align: center;}</style>");
  client.println("</head><body>");
  client.println("<div class=\"background-content\"><h1>test</h1><div class=\"container\"><p>Ratio1 : <span id=\"ratio1Valeur\"></span></p><div class=\"demi-cercle-container\"><div class=\"demi-cercle\"></div><div class=\"aiguille\"></div></div><div class=\"button-container\"><button onclick=\"resetArduinoValues()\">Reinitialiser les valeurs</button></div></div></div>");
  if (client && client.connected()) {                             // if you get a client,
    Serial.println("New Client.");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
        // String et boucle if créent le bouton de reset.
        String req = client.readStringUntil('\r');       // loop while the client's connected
        if (req.indexOf("/toggle") != -1) {
          // Exécuter les actions associées
          ampli1.tare();
          ampli2.tare();
          // Répondre au client avec une confirmation
          client.println("Content-Type: text/html");
          client.println();
        ampli1.tare();
        ampli2.tare();
      else{
          allumerLED(ledV);
          ratio1 = 0.5;
          ratio2 = 0.5;
        else{
            allumerLED(ledRG);
            allumerLED(ledJ2G);
            allumerLED(ledJ1G);
            allumerLED(ledV);
            allumerLED(ledJ1D);
            allumerLED(ledJ2D);
            allumerLED(ledRD);
        Serial.print("  |  ratio1 ");
        Serial.print(ratio1);
        Serial.print("  |  ratio2 ");
        Serial.println(ratio2);
          // The HTTP response ends with another blank line:
          // Ajoutez le code HTML, CSS et JavaScript pour le cadran en demi-rond ici
          // Ajoutez le code JavaScript pour mettre à jour l'aiguille ici
        client.println();
        client.println("<script>function toggle() {var xhr = new XMLHttpRequest();xhr.open('GET', '/toggle', true);xhr.send();}function updateAiguille(value) {const aiguille = document.getElementsByClassName('aiguille')[0];const angle = (value - 0.5) * 180;aiguille.style.transform = `translateX(-50%) rotate(${angle}deg)`;}function updateRatio1(valeurtest1) {const ratio1Valeur = document.getElementById('ratio1Valeur');ratio1Valeur.textContent = valeurtest1.toFixed(2);}setInterval(() => {const valeurCapteur = "+ String(ratio1) +";updateAiguille(valeurCapteur);const valeurtest = "+ String(ratio1) +";updateRatio1(valeurtest);}, 100);</script>");
        client.println("</body></html>");
Hallo, @thomas_desmares - Please, edit your post to format your code by clicking the < CODE > button and pasting your code where you see '''type or paste code here'''. Your code will look like this:
  par
#include <WiFi.h>
#include <WiFiAP.h>
#include "HX711.h"
int etatreset = 0;
HX711 ampli1;
HX711 ampli2;
  ampli1.tare();
  ampli2.tare();
    while (1);
  server.begin();
  int poids = abs(difference) / facteurdecharge; // conversion de la différence en gramme
  float poidsTot = (abs(valeur1) + abs(valeur2)) / 40; //poids total de la personne en gramme
  float ratio1 = (abs(valeur1) / 40) / poidsTot; // calcul du ratio mesuré par le premier ampli
  float ratio2 = (abs(valeur2) / 40) / poidsTot; // calcul du ratio mesuré par le deuxieme ampli
  if (etatreset == LOW) {
    ampli1.tare();
    ampli2.tare();
  else {
    if (poidsTot <= 2000) {
      allumerLED(ledV);
      ratio1 = 0.5;
      ratio2 = 0.5;
    else {
        allumerLED(ledRG);
        allumerLED(ledJ2G);
      } else if ((ratio1 >= 0.30) && (ratio1 < 0.41)) {
        allumerLED(ledJ1G);
      } else if ((ratio1 >= 0.41) && (ratio1 < 0.59)) {
        allumerLED(ledV);
      } else if ((ratio1 >= 0.59) && (ratio1 < 0.70)) {
        allumerLED(ledJ1D);
      } else if ((ratio1 >= 0.70) && (ratio1 < 0.85)) {
        allumerLED(ledJ2D);
        allumerLED(ledRD);
  client.println();
  client.println("");
  client.println("Interface ");
  //client.println("<meta http-equiv="refresh" content="1">");
  client.println("body {font-family: Arial, sans-serif;margin: 0;padding: 0;}h1{text-align: center;margin-top: 50px;font-size: 50px;}.container {max-width: 600px;margin: 0 auto;padding: 20px;background-color: rgba(255, 255, 255, 0.8);border-radius: 10px;box-shadow: 0 0 10px rgba(0, 0, 0, 0.3);margin-top: 50px;}.demi-cercle-container {position: relative;width: 200px;height: 100px;overflow: visbile;margin: 0 auto;}.demi-cercle {position: absolute;width: 100%;height: 100%;background: conic-gradient( at 50% 0%,#FF0000 25% 32.5%,#ffa200 32.5% 40%,#FFFF00 40% 44.5%,#98fb98 44.5% 55.5%,#FFFF00 55.5% 60%,#ffa200 60% 67.5%,#FF0000 67.5% 75%) bottom;border-radius: 0 0 100px 100px;border: 0px solid #000;transform: rotate(180deg);}.aiguille {position: absolute;width: 2px;height: 95px;bottom: 0;left: 50%;background-color: #000;transform-origin: 0% 100%;transform: translateX(-50%) rotate(0deg);transition: transform 0.5s ease-in-out;}.button-container {text-align: center;margin-top: 20px;}button {padding: 10px 20px;font-size: 16px;cursor: pointer;}.background-content {background-color: #add8e6;background-repeat: repeat-x;background-position: top center;padding-top: 80px;text-align: center;}");
  client.println("");
  client.println("<div class="background - content">
                test
                 <div class = "container">
                Ratio1 : <span id = "ratio1Valeur">
                 <div class = "demi-cercle-container">
                 <div class = "demi-cercle">
                 <div class = "aiguille">
                 <div class = "button-container">
                 <button onclick = "resetArduinoValues()">Reinitialiser les valeurs");
          ampli1.tare();
          ampli2.tare();
          client.println();
          ampli1.tare();
          ampli2.tare();
        else {
            allumerLED(ledV);
            ratio1 = 0.5;
            ratio2 = 0.5;
          else {
              allumerLED(ledRG);
              allumerLED(ledJ2G);
              allumerLED(ledJ1G);
              allumerLED(ledV);
              allumerLED(ledJ1D);
              allumerLED(ledJ2D);
              allumerLED(ledRD);
        client.println();
        client.println("<script>function toggle() {var xhr = new XMLHttpRequest();xhr.open('GET', '/toggle', true);xhr.send();}function updateAiguille(value) {const aiguille = document.getElementsByClassName('aiguille')[0];const angle = (value - 0.5) * 180;aiguille.style.transform = `translateX(-50%) rotate(${angle}deg)`;}function updateRatio1(valeurtest1) {const ratio1Valeur = document.getElementById('ratio1Valeur');ratio1Valeur.textContent = valeurtest1.toFixed(2);}setInterval(() => {const valeurCapteur = " + String(ratio1) + ";updateAiguille(valeurCapteur);const valeurtest = " + String(ratio1) + ";updateRatio1(valeurtest);}, 100);</script>");
Thank you. I did it correctly.
Show the white square.
Is your system sharing a common ground?
I will show you what the square looks like tonight. now I am still working on my shop. So when I come back home I will show you.
For common ground I can provide you a schema. You should have your answer on it.
Have you verified the connections? Your amplifiers have no power and your excite/signal wires are shorted.
As I told you on my first message, all the connections are great because the studients created a electronic system with del and all works well. It is only the serial monitor the issue. I can't see the datas. But del switch on exactly as we expect. So I don't think it is the connections. I will show you the white square in an hour.
Hereby the white square.
  delay(2500);
  Serial.println("Allons-y");
  // ... comme avant - d'ici
I see your red circle now. I will show it to a electronic industry. They should know the issue.
I will tell you in 15 days.
If anyone have a solution, feel free to inform me.
Thank you but nothing changed.
I laugh when I see "Allons-y"! :joy:
Well - it beats a square - at least Serial Monitor is "known good".
Nothing changed on serial monitor.
I upload this code in the ESP32 an the serial monitor works well.
  Filename    : SerialPrinter
  Description : Use UART send some data to PC, and show them on serial monitor.
  Auther      : www.freenove.com
  Modification: 2020/07/11
  Serial.println("ESP32 initialization completed!");
  Serial.printf("Running time : %.1f s\n", millis() / 1000.0f);
