I have this loop:
if (Serial.available() > 0) { //if serial incoming
incomingByte = Serial.read(); //read it
if (incomingByte==144){ // analyse the first byte (status) : 144 is note on ch1
incomingByte = Serial.read(); //read the next byte
if (incomingByte==60){ // analyse the second byte (note) : 60 is middle C
if(incomingByte>0){ //analyse the third byte : velocity >0
int bitToSet = 1;
registerWrite(bitToSet, HIGH);
}else{ //analyse the third byte : velocity=0
int bitToSet = 2;
I am getting this error:
Serial_to_Midi.cpp: In function 'void loop()':
Serial_to_Midi:39: error: 'incomingByte' was not declared in this scope
I'm confused if I need to declare incomingByte as an int or what. I'm confused because I don't see the variable declared anywhere in the example here:
http://www.arduino.cc/en/Serial/Read
