This is my first post in this forum so have mercy on me if i look stupid!
I have made a circuit where I use an Pro Mini to control a 5V miniature relay and a buzzer using three buttons.
The output of the relay activates a solenoid that needs 8.5V to operate.
Since I want a single 9V battery to feed both the Arduino and the solenoid I have used this circuit to indicate if the voltage drops below 8.5V:
I have connected the circuit in parallel with the Arduino.
See the attached schematics.
I use pinMode(7, INPUT_PULLUP) for the buttons.
When I adjust the trim pot so that the battery indicator LED is OFF the internal LED(Pin13) starts to flash slowly.
When I adjust it so that the LED is ON, the circuit and program works as wanted.
Why does the Arduino react to the value of the trimpot?
It does not make any sense!
What are the specs of the solenoid and is the the battery one of thses?
You will find it will not last long and probably be not able to activate the solenoid.
What are the specs of the buzzer and the 5V relay?
Do you have a DMM to measure circuit parameters?
INTP:
First of all, why the hell are you running 9V into the VCC pin of the board?
The RAW pin is there for a reason
LOL! Didn't you read my first request?
MrDoLittleLess:
Anyway, thanks for your gentle lesson!
This is my first Arduino project as well so now I am wiser than before I connected the +9V to VCC.
Never again!
I really didn't know that the RAW pin was connected before the Voltage regulator.
Every tutorial on the web connects the positive voltage to VCC and the negative to GND so I thought it was the way to do it.
The relay you are using, just meets the output current rating of the controller.
5V / 125R = 40mA,
How ever that current and the more than 300mA for the solenoid will mean the battery will not last very long.
When you have connected the battery to the correct terminal oft he controller, measure the battery voltage with your DMM with the solenoid OFF and then ON.
With the +9V connected to the RAW pin it works just fine. Thanks @INTP !
The battery voltage readings are like this:
Battery not yet connected to the circuit:
9.31V
Powering the Arduino and a LED:
9.18V
Powering the Arduino and a two LEDs:
9.12V
Powering the Arduino, a LED and the buzzer:
9.08V
Powering the Arduino, two LEDs, the Relay and the solenoid:
5.97V
Regarding the battery consumption...
The circuit will be off most of the time.
It will maybe be turned on for 10 sessions per week.
Each session will last approximately 20 min.
The relay will be activated in 300ms, once in each session.
Will using 6 x 1.5V AA batteries instead of a single 9V 6LR61 battery give better battery life?
If you are still using the PP3 battery you will keep having this problem, the battery voltage is going up and down when you set the low batt level because the load changes, that is another LED comes ON.
Try putting a 1000uF 16V electrolytic capacitor across the 9V battery, this may help with load changes.
8.75V
Powering the Arduino and a LED plus the low voltage LED:
8.67V
Powering the Arduino and a two LEDs plus the low voltage LED:
8.63V
Powering the Arduino, a LED and the buzzer plus the low voltage LED:
8.63V
Powering the Arduino, two LEDs, the Relay and the solenoid plus the low voltage LED:
5.57V
I also measured the total current through the circuit:
36 mA
53 mA
56 mA
1.57 A
I find the last value is far too high considering that the solenoid is rated 300mA.
Why is that? Is it because I feed 9V into a solenoid rated 6V?
By using Ohm's law the coil resistance should be
R=6/0.3=20 Ohm
In that case the current should be reading 450mA if using a 9V source instead:
I=9/20=450mA
