I'm still using 1.8.19 of the IDE so this might be a bit different: Go to File->Preferences and enable show verbose output during upload. Post the contents of the output window back here. You can copy and paste the text in the output window rather than a screenshot.
Sketch uses 5410 bytes (16%) of program storage space. Maximum is 32256 bytes.
Global variables use 210 bytes (10%) of dynamic memory, leaving 1838 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -carduino "-PCOM9" -b115200 -D "-Uflash:w:C:\Users\User\AppData\Local\Temp\arduino-sketch-40074ECC6BAFC97CAD3FA521BA679F52/P7 ADC Voltage.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM9
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\User\AppData\Local\Temp\arduino-sketch-40074ECC6BAFC97CAD3FA521BA679F52/P7 ADC Voltage.ino.hex"
avrdude: writing flash (5410 bytes):
Writing | ################################################## | 100% 0.85s
avrdude: 5410 bytes of flash written
avrdude: verifying flash memory against C:\Users\User\AppData\Local\Temp\arduino-sketch-40074ECC6BAFC97CAD3FA521BA679F52/P7 ADC Voltage.ino.hex:
avrdude: load data flash data from input file C:\Users\User\AppData\Local\Temp\arduino-sketch-40074ECC6BAFC97CAD3FA521BA679F52/P7 ADC Voltage.ino.hex:
avrdude: input file C:\Users\User\AppData\Local\Temp\arduino-sketch-40074ECC6BAFC97CAD3FA521BA679F52/P7 ADC Voltage.ino.hex contains 5410 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.66s
avrdude: verifying ...
avrdude: 5410 bytes of flash verified
avrdude done. Thank you.
That output suggests that the upload was successful.
I wonder if it's an IDE 2.0 issue? Maybe move your post over to the Arduino IDE 2.0 section where you will likely get a better explanation.
Ah, I see you already have created a new discussion in that section.
