Why is my Arduino IDE not reading or recognizing any of the libraries I throw at it?
#include <Adafruit_HTU21DF.h>
#include <Adafruit_BMP085.h>
#include <Adafruit_MPU6050.h>
#include <SD.h> // sd card library
#include <SPI.h> // SPI communication library between the SD card reader and the Arduino Chip
#include <Wire.h>
Adafruit_MPU6050 accelgyro;
Adafruit_BMP085 bmp;
Adafruit_HTU21DF humidity;
const int chipSelect = 4;
int16_t ax, ay, az; // define acceleration data
int16_t gx, gy, gz; // define gyroscopic data
#define LED_PIN 13
bool blinkState = false;
  Wire.begin();
  rtc.begin();
  humidity.begin();
  bmp.begin();
  // initialize devices (GY-87)
  Serial.println("Initializing I2C devices...");
  // SD Card Initialization
  if (SD.begin(chipSelect))
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
  // initialize bmp085
  if (!bmp.begin()) {
    Serial.println("Could not find a valid BMP085 sensor, check wiring!");
    while (1) {} }
  // initialize HTU21D
  if (!humidity.begin()) {
    Serial.println("Could not find a valid HTU21D sensor, check wiring!");
    while (1) {} }
  // initialize mpu6050
  accelgyro.initialize();
  Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
  accelgyro.setI2CBypassEnabled(true); // set bypass mode for gateway to hmc5883L
  // configure Arduino LED for checking activity
  pinMode(LED_PIN, OUTPUT);
  double sea_level_altitude = bmp.readSealevelPressure(); // define and read sea level pressure assuming 'standard' barometric pressure of 1013.25 millibar = 101325 Pascal
  double temp = bmp.readTemperature(); // define and read temperature
  double pressure = bmp.readPressure(); // define and read pressure
  accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz); // read raw accel/gyro measurements from device
  double altitude = bmp.readAltitude(); // define and read altitude
  double real_altitude = bmp.readAltitude(101500); // define and read real altitude
  double humidity = humidity.readHumidity();
  // printing out the temperature
  Serial.print("Temperature = ");
  Serial.print(temp); Serial.println(" *C ");
  //printing out the humidity
  Serial.print("Humidity = ");
  Serial.print(humidity); Serial.println(" % ");
  // printing out the pressure
  Serial.print("Pressure = ");
  Serial.print(pressure); Serial.println(" Pa ");
  // printing out the altitude
  Serial.print("Altitude = ");
  Serial.print(altitude); Serial.println(" m ");
  // printing out the pressure at sea level
  Serial.print("Pressure at sealevel (calculated) = ");
  Serial.print(sea_level_pressure); Serial.println(" Pa ");
  // printing out the 'real' altitude
  Serial.print("Real altitude = ");
  Serial.print(real_altitude); Serial.println(" m ");
  // printing out the acceleration data
  Serial.println("Accel: ");
  Serial.print("ax: "); Serial.print(ax); Serial.println("g ");
  Serial.print("ay: "); Serial.print(ay); Serial.println("g ");
  Serial.print("az: "); Serial.print(az); Serial.println("g ");
  // printing out the gyroscopic data
  Serial.println("Gyro: ");
  Serial.print("gx: "); Serial.print(gx); Serial.println(" deg/sec ");
  Serial.print("gy: "); Serial.print(gy); Serial.println(" deg/sec ");
  Serial.print("gz: "); Serial.print(gz); Serial.println(" deg/sec ");
  sdcard_file = SD.open("data.txt", FILE_WRITE);
  if (sdcard_file) { // writing the data in the MicroSD card
    sdcard_file.print("Temperature = ");
    sdcard_file.print(temp); sdcard_file.println(" *C ");
    sdcard_file.print("Humidity = ");
    sdcard_file.print(humidity); sdcard_file.println(" % ");
    sdcard_file.print("Pressure = ");
    sdcard_file.print(pressure); sdcard_file.println(" Pa ");
    sdcard_file.print("Altitude = ");
    sdcard_file.print(altitude); sdcard_file.println(" m ");
    sdcard_file.print("Pressure at sealevel (calculated) = ");
    sdcard_file.print(sea_level_pressure); sdcard_file.println(" Pa ");
    sdcard_file.print("'Real' altitude = ");
    sdcard_file.print(real_altitude); sdcard_file.println(" m ");
    sdcard_file.println("Acceleration data : ");
    sdcard_file.print("ax: "); sdcard_file.println(ax); sdcard_file.println("g ");
    sdcard_file.print("ay: "); sdcard_file.println(ay); sdcard_file.println("g ");
    sdcard_file.print("az: "); sdcard_file.println(az); sdcard_file.println("g ");
    sdcard_file.println("Gyroscopic data: ");
    sdcard_file.print("gx: "); sdcard_file.println(gx); sdcard_file.println(" deg/sec ");
    sdcard_file.print("gy: "); sdcard_file.println(gy); sdcard_file.println(" deg/sec ");
    sdcard_file.print("gz: "); sdcard_file.println(gz); sdcard_file.println(" deg/sec ");
    sdcard_file.close(); // close the file
  else { // if the file didn't open, print an error:
    Serial.println("Error opening test.txt");
  // blink LED to indicate activity
  blinkState = !blinkState;
  digitalWrite(LED_PIN, blinkState);
  delay(2000); // repeat the loop every 2000 milliseconds that is 2 seconds
I tried everything to make it work but it didn't. No matter what I did I got:
ArduSatLFLV_Code_1:1:10: fatal error: HTU21D.h: No such file or directory
compilation terminated.
exit status 1
I tried reinstalling the libraries both manually and through the library management thing. Also the SD and SPI libraries work just fine given that they are built in.
The documentation: Installing Libraries | Arduino Documentation | Arduino Documentation
States:
NB: the Library will be available to use in sketches, but with older IDE versions examples for the library will not be exposed in the File > Examples until after the IDE has restarted.
Try restarting the IDE
IDE version and OS?
Is the IDE Portable, installed with installer, or from MS Store?
And when "reinstalling" are you sure you have first completely deleted the folder?
And are you sure you haven't multple library copies (installed/copied elsewhere)?
EDIT:
Tried to compile and run the "HTU21DFtest" example sketch? (please note the #include on the example also... The library is note referenced with angle brackets but with double quotes...)
You're compiling for which board? Uno? ESP? What?
IDE version: 1.8.19
OS: Windows 11
I did delete the whole folder when reinstalling the lib
I did try to compile the test files in the libraries but they also did not recognize I2Cdev.h for example, they always had some missing dependencies
I am compiling to an Arduino Mega 2560
I just tried installing the library (from library manager) and the example code compiled like a charm. So, it's something in your system and/or code, I suspect.
But on your latest error report you said it can't find I2CDev (in real world it should be "Adafruit_I2CDevice.h", please always use real and complete names..), what about the first error on "HTU21D.h"? And why "HTU21D.h" and not "Adafriut_HTU21DF.h"? I suspect you have a weird libraries "mix"...
First uninstall the Adafruit libraries (HTU21 requires two more dependency libraries, remove them all) from the library manager, and check if you have any other "HTU*" library installed and remove them also. Then exit the IDE and remove any remaining folder on your entire system (make a full search for "Adafruit*" and "HTU21" over your whole local drives).
Then start the IDE again and install the Adafruit library back, it should prompt you to install the two dependencies also. Now run the example again and see if it works.
If not, I'm sorry but I can't tell you why, it's still something with your sistem and I can't say what, you need to deeply investigate the issue.
PS: you haven't answered to another question I made you: what kind of IDE installation? portable? installer? Microsoft? What?...
I will try this, but I am very doubtful given how much time I spent trying to fix the issue.
Going back to the IDE, I am pretty sure I installed it from the Arduino official website so installer I guess
But thanks for your effort! I hope it'll work once I attempt to fix it again!
OK so I tried and it did not work.
Here's a picture of my library names
#include "Adafruit_MPU6050.h"
#include "Adafruit_HTU21DF.h"
#include "Adafruit_BMP085.h"
#include "Adafruit_I2CDevice.h"
#include <Wire.h>
MPU6050 accelgyro;
HTU21D htu = Adafruit_HTU21DF();
#define LED_PIN 13
  Wire.begin();
  rtc.begin();
  htu.begin();
  bmp.begin();
  } else
    return;
  if (!bmp.begin()) {
    while (1) {} }
  if (!htu.begin()) {
    Serial.println("Couldn't find HTU21D sensor!");
    while (1);
  } else { // if the file didn't open, print an error:
  delay(2000); // repeat the loop every 2000 milliseconds (2 seconds)
The error message reads:
Arduino: 1.8.19 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
code:1:10: fatal error: Adafruit_MPU6050.h: No such file or directory
exit status 1
If you change their places, it will just give the exact same error but with the library you put in front of it. I am beyond hopeless. This is for a science fair and I will be so screwed if it won't work...
The error is saying the compiler can't find that include header file. If included with double quotes tells the compiler to search the file inside the same folder of the project (on my reply I enclosed some library names between double quotes but just to show the name, I didn't mean you should do that on all libraries), while angle brackets "<" and ">" mean they're inside global libraries folder(s). And I don't know if this library "mix" have something to be taken into consideration and we're missing (as I don't have those devices I can't tell you exactly).
Anyway, first of all, I already asked you this but I can't find your answer: have you tried to compile the "HTU21DFtest" example sketch? If not, please do it now!
And what about the other example codes of the Adafruit libraries?
(Just a doubt: do you see the Adafruit libraries examples under File menu, yes?)
If all Adafruit examples compile without errors, now you could try using those #include lines at the beginning of your code instead of the ones you already have:
Please note #include <Adafruit_MPU6050.h> already includes "Adafruit_I2CDevice.h" and "Wire.h" (see header code) so it's not necessary to call them again.
