Why led color change on iteration?
How. I have experience programming, and I can't understand what is going on with this simple code.
It's supposed to display a red circle, but it's alternating RGBW colors :confused:
These are the relevant excerpts. The rest is in the picture.
    strip.clear();
    colorWipe(strip.Color(255, 0, 0), 50); // Red
void colorWipe(uint32_t color, int wait) {
  for(int i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, color);
    strip.show();
    delay(wait);
Any hints?
Any hints?
Post your code.
#define LED_PIN 2
#define LED_COUNT 24
#define BRIGHTNESS 50
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRBW + NEO_KHZ800);
  strip.begin();           // INITIALIZE NeoPixel strip object (REQUIRED)
  strip.show();            // Turn OFF all pixels ASAP
  strip.setBrightness(50); // Set BRIGHTNESS to about 1/5 (max = 255)
bool done = false;
  if(!done) {
    strip.clear();
    done = true;
  for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
    Serial.println(color);
    strip.setPixelColor(i, color);         //  Set pixel's color (in RAM)
    strip.show();                          //  Update strip to match
    delay(wait);                           //  Pause for a moment
I can see in the console the color is always the same. But the ring... It's not respecting that.
I found the cause. And it's really strange for me. But changing NEO_GRBW to NEO_GRB solves the issue.
So, just RGB (without white) draws everything in red, as expected. Why the other configuration would behave so differently? I can live without knowing that, but it's really strange.
guillermuino:
Because the library's indexing would be out by one.
guillermuino:
Because that is the configuration for GRBW LEDs which you do not have. Yours are GRB. :roll_eyes:
Is that not perfectly simple? :astonished:
