Why my arduino code needs to re-upload or reset the arduino to function the code again
When I successfully uploaded my code, and test the functionality, it perfectly works, but when I tried once again, the code isnt functioning, and it needs to be re-uploaded or restart the arduino to function again, how to fix this?
Please show your sketch.
Of many possibilities, this one in your code, a condition might be set to stop the sketch from leaving the condition.
What Code?
What Arduino?
What is connected to the Arduino?
How is the Arduino powered?
That sounds like a code bug to me but you can upload your schematic to be sure.
Here is my code
```#include <Stepper.h>
#include <Servo.h>
#include <SoftwareSerial.h>
#include "DFRobotDFPlayerMini.h"
#include "VoiceRecognitionV3.h"
SoftwareSerial mySoftwareSerial(8, 9); // RX, TX for DFPlayer
VR myVR(2, 3); // RX, TX for Voice Recognition
uint8_t buf[128]; // Increased buffer size for Voice Recognition
const int stepsPerRevolution = 32;
const int buzzerPin = 11;
const int irSensorPin = A0;
const int servoPin = 12;
Servo servo;
int servoAngle = 0;
Stepper myStepper1(stepsPerRevolution, 4, 6, 5, 7);
DFRobotDFPlayerMini myDFPlayer;
#define NeozepRecord (0)
  mySoftwareSerial.begin(9600);
  myVR.begin(9600);
  // Initialize DFPlayer Mini
  if (!myDFPlayer.begin(mySoftwareSerial, true, false)) {
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    while (true);
  Serial.println(F("DFPlayer Mini online."));
  myDFPlayer.volume(30); // Set volume
  // Initialize Voice Recognition Module
  Serial.println("Elechouse Voice Recognition V3 Module\\Control LED sample");
  if (myVR.clear() == 0) {
    Serial.println("Recognizer cleared.");
    Serial.println("Voice Recognition Module not found.");
    Serial.println("Please check the connection and restart Arduino.");
    while (1);
  if (myVR.load((uint8_t)NeozepRecord) >= 0) {
    Serial.println("NeozepRecord loaded");
  // Setup pins
  pinMode(irSensorPin, INPUT);
  pinMode(buzzerPin, OUTPUT);
  pinMode(servoPin, OUTPUT);
  servo.attach(servoPin);
  myStepper1.setSpeed(900);
  myStepper1.step(0);
  int ret = myVR.recognize(buf, 75); // Adjust recognition threshold
  Serial.print("Voice Recognition Result: ");
  Serial.println(ret);
  if (ret > 0) {
    switch (buf[1]) {
      case NeozepRecord:
        // Actions for recognized voice command
        myDFPlayer.play(3); // Play the first MP3 file
        myStepper1.step(1024); // Rotate Stepper
        myStepper1.step(-1024); // Rotate back
        int sensorStatus = digitalRead(irSensorPin);
        if (sensorStatus == LOW) {
          digitalWrite(buzzerPin, HIGH);
          delay(1000); // Buzzer sound
          digitalWrite(buzzerPin, LOW);
          servo.write(180); // Rotate Servo
          delay(200);
          servo.write(0); // Rotate back
          delay(100);
          myDFPlayer.play(4); // Play the fourth MP3 file after servo rotation
Im using arduino mega 2560
What port?
Do you have a schematic?
Is this the same project you posted in this long thread:
If so, I have not yet had your reply to my post #16.
The VoiceRecognitionV3.h library install its own SoftwareSerial , so with these lines:
start a two SoftwareSerial instances.
The multiple SoftwareSerial can't work at the same time
How to fix this?
As @Delta_G mentioned above, Mega has a three (or four) hardware Serials. Replace the one of your SoftwareSerial to hardware one.
Open the DFRobotDFPlayerMini library example GetStarted to see how to use a hardware Serial with DFRobot player.
It still need to be re uploaded, how to fix this?
please show your revised code
#include <Servo.h>
#include "SoftwareSerial.h"
VR myVR(2, 3);
SoftwareSerial mySoftwareSerial(4, 5); // RX, TX
// SoftwareSerial mySoftwareSerial(5, 4); // RX, TX
const int buzzerPin = 7;
const int servoPin = 6;
Servo servo;
int servoAngle = 0;
Stepper myStepper1(stepsPerRevolution, 8, 10, 9, 11);
  Serial.println("Elechouse Voice Recognition V3 Module\r\nControl LED sample");
  mySoftwareSerial.begin(9600); // Initialize serial communication with DFPlayer Mini
  Serial.begin(115200); // Initialize serial communication with Arduino IDE
  myDFPlayer.begin(mySoftwareSerial); // Start communication with DFPlayer Mini
  delay(1000); // Wait for DFPlayer Mini to initialize
  myVR.begin(9600);
    while (1);
  pinMode(irSensorPin,INPUT);
  myStepper1.step(0);
  if (ret > 0) {
    int sensorStatus; // Declare sensorStatus outside the switch statement
    switch (buf[1]) {
      case NeozepRecord:
        // Play the first audio file
        myDFPlayer.play(1);
        delay(1000); // Wait for the first audio to finish playing
        // Rotate Stepper 1 clockwise
        // Rotate the stepper motor back
        // Trigger buzzer using IR sensor
        Serial.println("IR Sensor Status: " + String(sensorStatus)); // Debug print
          delay(1000); // Increase the delay for a longer buzzer sound
          // Rotate the servo motor
          Serial.println("Rotating Servo to 90 degrees..."); // Debug print
          servo.write(180); // Rotate to 90 degrees (adjust as needed)
          delay(300);     // Adjust the delay based on your requirements
          Serial.println("Rotating Servo back to 0 degrees..."); // Debug print
          servo.write(0);  // Rotate back to 0 degrees
          // Play the second audio file
        myDFPlayer.play(2);
        delay(3000); // Wait for the second audio to finish playing
From
https://docs.arduino.cc/learn/built-in-libraries/software-serial/
Not all pins on the Mega and Mega 2560 boards support change interrupts, so only the following can be used for RX: 10, 11, 12, 13, 14, 15, 50, 51, 52, 53, A8 (62), A9 (63), A10 (64), A11 (65), A12 (66), A13 (67), A14 (68), A15 (69).
You have not used any of the additional hard ware Serial ports as recommended.
@thomor
I don't see any big changes in your code... the two SoftwareSerial are still in its place
#include <Servo.h>
VR myVR(2, 3);
SoftwareSerial mySoftwareSerial(14, 15); // RX, TX
// SoftwareSerial mySoftwareSerial(14, 15); // RX, TX
Servo servo;
int servoAngle = 0;
  myVR.begin(9600);
    while (1);
  myStepper1.step(0);
  if (ret > 0) {
    switch (buf[1]) {
      case NeozepRecord:
        myDFPlayer.play(1);
        myDFPlayer.play(2);
Here is my code @b707
Are you trolling us?
