Why not equal if(message == "on" ){} in ESP32 bluethooth
Is there any problem not working please help me. Thanks all.
#include "BluetoothSerial.h"
#define LED 2
BluetoothSerial SerialBT;
String message = "";
  pinMode(LED, OUTPUT);
  if(!SerialBT.begin("ESP32")){
    Serial.println("An error occurred initializing Bluetooth");
  digitalWrite(LED, HIGH);
  if(SerialBT.available()){
    Serial.println("Enter to recieve");
    message = "";
    while(SerialBT.available()){
      char incomingChar = SerialBT.read();
      if(incomingChar != '\n'){
        message += String(incomingChar);
    Serial.print(message);
  if(message == "on"){
  else if(message == "off"){
    digitalWrite(LED, LOW);
  Serial.print("|");
  delay(50);
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Try printing the length of message before you test its value. Is it what you expect ?
best to understand using basic Serial interface
consider using readBytesUntil() instead of appending each character
#define LED  LED_BUILTIN
char  msg [80];
void
loop (void)
    if (Serial.available ())  {
        int n = Serial.readBytesUntil ('\n', msg, sizeof(msg));
        msg [n] = '\0';
        if (! strcmp (msg, "on"))
            digitalWrite (LED, HIGH);
        else if (! strcmp (msg, "off"))
            digitalWrite (LED, LOW);
        else  {
            Serial.print   (" invalid - ");
            Serial.println (msg);
void setup () {
    Serial.begin (115200);
    pinMode (LED, OUTPUT);
there is \r too
Yes. You don't understand how serial works.
You cannot assume that every byte will arrive instantaneously ... Serial.availble() may say there is nothing left to receive... because you are asking the question more often than bytes are received. Generally serial is slower than your micro-controller .. you need to handle this.
EDIT. and what @Juraj said.
Thank you. I changed '\n' to '\r' it is working good .
Thank you forgotten \r. Thankyou.
But i printing at end it is right recieved!
    message = "";
   < Serial.print(message);/>
Try to print it like this
Serial.print ('<');
Serial.println ('>');
Everything should be on a single line.
#define LED 2
  //Serial.begin(115200);
      SerialBT.println("An error occurred initializing Bluetooth");
  if (SerialBT.available()) {
    message = "";
    while (SerialBT.available()) {
      if (incomingChar == '\r' || incomingChar == '\n')SerialBT.read();
      else message += String(incomingChar);
  if (message == "on") {
  else if (message == "off") {
  delay(50);
You may have a look at this sketch
const byte LED = 2;
const byte MaxMessageLength = 10;
  if (MessageReceived()) React();
boolean MessageReceived(){  // Returns TRUE if either \r or \n was received
  boolean complete = false;
      if (incomingChar == '\r' || incomingChar == '\n') {
        complete = true;
      } else message += String(incomingChar);
      // If required we discard messages which are too long:
      if (message.length() > MaxMessageLength) message = "";
  // If the message is not "complete" (no \r or \n received or too long)
  // it will go on collecting characters in the next loop
  return complete;
void React(){
  // no real need for "else" as the comparison(s) do not require much time
  // and all used commands exclude each other
  // This makes it easier to expand the list of messages
  // and to follow the program sequence
  Serial.print("<");
  Serial.println(">");
  message = "";  // Reset the message here after evaluation, reaction and printing
It uses a receiving routine which is independent from delays between single characters of a message and also discards messages which are too long thus avoiding an overflow.
In most cases in the "real world" these problems will not occur, but to take care of Murphy's Law (If something bad can happen it will happen) ... :wink:
