Why Platformio can compile but ArduinoIDE not?
//  Makita Battery Monitor / Unlock / Omega Lock Utility
//  Normal mode    : full battery scan + auto-unlock (default)
//  Omega lock mode: sets charger lock nybble (nybble 34) non-zero
//  Mode select :  bridge GPIO2 -> GPIO3  =>  OMEGA LOCK  (red pulse)
//                 both pins open         =>  SCAN/UNLOCK (white pulse)
//  Target : Waveshare RP2040 Zero (primary) + other Arduino boards
//  Build  : PlatformIO + Adafruit NeoPixel + OneWire2 (vendored fork)
//  License: Provided as-is, no warranty. Interacting with battery
//           pack firmware can permanently brick a pack. Use at your
//           own risk.
#include <Arduino.h>
#include "OneWire2.h"  // vendored fork of OneWire with tweaks for Makita timing
#if defined(ARDUINO_ARCH_RP2040)
#include <pico/stdlib.h>
#include <hardware/watchdog.h>
#endif
// ─── Firmware identity ────────────────────────────────────────
#define FIRMWARE_VERSION "1.6.0"
// ─── Pin definitions ─────────────────────────────────────────
static constexpr uint8_t PIN_ONEWIRE = 6;
static constexpr uint8_t PIN_ENABLE = 8;
static constexpr uint8_t NEOPIXEL_OUT_PIN = 16;
static constexpr uint8_t NUM_PIXELS = 1;
static constexpr uint8_t PIN_MODE_OUT = 2;
static constexpr uint8_t PIN_MODE_IN1 = 3;  // Omega lock mode (bridge GPIO2-GPIO3)
// On RP2040 PIN_MODE_OUT drives HIGH and the inputs use INPUT_PULLDOWN, so a
// bridge pulls them HIGH. On other boards we drive LOW with INPUT_PULLUP.
static constexpr bool MODE_PIN_ACTIVE_HIGH = true;
#else
static constexpr bool MODE_PIN_ACTIVE_HIGH = false;
#endif
// ─── 1-Wire bus timing ───────────────────────────────────────
static constexpr uint16_t BUS_BYTE_GAP_US = 90;    // inter-byte gap on 1-Wire bus
static constexpr uint16_t BUS_SETTLE_US = 100;     // settle before reading response bytes
static constexpr uint16_t BUS_SETTLE_ON_MS = 150;  // bus power-up settle after ENABLE=HIGH
//                                                       (covers: enable, presence poll, powercycle-on)
static constexpr uint16_t POWERCYCLE_OFF_MS = 100;  // bus off time during power cycle
// ─── Inter-command delays ─────────────────────────────────────
// All inter-step delays use 30ms — consistent across frame-write,
// testmode, and Type 5 session sequences.
static constexpr uint16_t INTER_CMD_MS = 30;
// ─── Type 5 (F0513) constants ─────────────────────────────────
static constexpr uint8_t TYPE5_CMD_SESSION = 0x99;  // enters voltage read session
static constexpr uint8_t TYPE5_CMD_MODEL = 0x31;    // reads model bytes
static constexpr uint8_t TYPE5_CMD_TEMP = 0x52;     // reads cell temperature
// Some Type 5 variants require multiple read attempts before all
// cells report valid data — this is a hardware ADC property.
static constexpr uint8_t TYPE5_MAX_ATTEMPTS = 10;  // max read attempts per scan
// ─── Type 6 constants ─────────────────────────────────────────
static constexpr uint8_t TYPE6_VOLT_READ = 0xD4;  // voltage read prefix
static constexpr float TEMP6_A = 9323.0f;
static constexpr float TEMP6_B = -40.0f;
// ─── Protocol commands ────────────────────────────────────────
static constexpr uint8_t CMD_BASIC_INFO[] = { 0xAA, 0x00 };
static constexpr uint8_t CMD_MODEL[] = { 0xDC, 0x0C };
static constexpr uint8_t CMD_TESTMODE_ENTER[] = { 0xD9, 0x96, 0xA5 };
static constexpr uint8_t CMD_TESTMODE_EXIT[] = { 0xD9, 0xFF, 0xFF };
static constexpr uint8_t CMD_RESET_ERRORS[] = { 0xDA, 0x04 };
static constexpr uint8_t CMD_CC_F0[] = { 0xF0, 0x00 };  // ADC trigger / frame-write arm
static constexpr uint8_t CMD_STORE[] = { 0x55, 0xA5 };
static constexpr uint8_t FRAME_WRITE_OPCODE = 0x0F;
static constexpr uint8_t FRAME_WRITE_PAD = 0x00;
static constexpr uint8_t BASIC_INFO_LEN = 32;
static constexpr uint8_t TYPE_PROBE_MAGIC = 0x06;
static constexpr float TEMP_INVALID = -999.0f;
static constexpr uint8_t MAX_CELLS = 10;
// ─── Health / battery data ────────────────────────────────────
static constexpr uint8_t HEALTH_SCALE_EXTENDED_CODES[] = { 26, 28, 40, 50 };
static constexpr size_t HEALTH_SCALE_EXTENDED_COUNT =
  sizeof(HEALTH_SCALE_EXTENDED_CODES) / sizeof(HEALTH_SCALE_EXTENDED_CODES[0]);
static constexpr uint16_t HEALTH_SCALE_STANDARD = 600;
static constexpr uint16_t HEALTH_SCALE_EXTENDED = 1000;
static constexpr float HEALTH_MAX = 4.0f;
static constexpr float SOC_DIVISOR = 2880.0f;
// ─── Scan / mode timing ───────────────────────────────────────
static constexpr uint16_t POLL_INTERVAL_MS = 200;
static constexpr uint16_t MODE_DEBOUNCE_MS = 50;
static constexpr uint8_t MODE_DEBOUNCE_COUNT = 4;
// ─── No-response polling ─────────────────────────────────────
// Chip goes bus-silent for ~3s during frame commit. 10s failsafe = 3x headroom.
static constexpr uint32_t NO_RESPONSE_TIMEOUT_MS = 10000;
static constexpr uint16_t NO_RESPONSE_POLL_MS = 25;
// ─── Unlock / lock attempt limits ────────────────────────────
static constexpr uint8_t UNLOCK_MAX_CYCLES = 6;
static constexpr uint8_t LOCK_MAX_ATTEMPTS = 6;
// ─── LED parameters ──────────────────────────────────────────
static constexpr uint8_t LED_BRIGHTNESS_MAX = 80;
static constexpr uint8_t LED_FLASH_COUNT = 3;
static constexpr uint16_t LED_FLASH_ON_MS = 200;
static constexpr uint16_t LED_FLASH_OFF_MS = 100;
static constexpr uint16_t LED_PULSE_PERIOD_MS = 2000;
static constexpr uint8_t LED_PULSE_INTERVAL_MS = 20;
static constexpr float IMBALANCE_THRESHOLD_V = 0.300f;
static constexpr uint16_t IMBALANCE_BLINK_INTERVAL_MS = 500;
static constexpr uint16_t IMBALANCE_BLINK_ON_MS = 80;
// ─── Watchdog ────────────────────────────────────────────────
// Must exceed NO_RESPONSE_TIMEOUT_MS (10s). Set to 12s.
static constexpr uint32_t WATCHDOG_TIMEOUT_MS = 12000;
// ─── Lock cause flags (bitfield) ─────────────────────────────
// Confirmed by systematic charger validation testing (193 fields tested).
static constexpr uint16_t LF_CS0 = 0x0002;  // CS0 mismatch (nybbles 0-15)
static constexpr uint16_t LF_CS2 = 0x0008;  // CS2 mismatch (nybbles 32-40)
static constexpr uint16_t LF_N34 = 0x0040;  // nybble 34 != 0 (charger lock nybble)
// ─── Return codes / types ─────────────────────────────────────
enum BasicInfoResult { BASIC_INFO_NO_RESPONSE = 0,
                       BASIC_INFO_OK = 1,
                       BASIC_INFO_PRE_TYPE0 = -1 };
enum BusResult { BUS_OK = 0,
                 BUS_NO_PRESENCE = 1 };
// Failure codes stored in nybble 40 of the basic-info frame.
enum FailureCode : uint8_t {
  FC_OK = 0,
  FC_OVERLOADED = 1,
  FC_OVERVOLT_C = 3,
  FC_UNKNOWN4 = 4,
  FC_WARNING = 5,
  FC_NTC_IMBAL = 7,
  FC_UNDERCAP = 15,
enum class BatteryType : int8_t {
  UNKNOWN = -1,
  T0 = 0,
  T2 = 2,
  T3 = 3,
  T5 = 5,
  T6 = 6,
static inline int batt_type_to_int(BatteryType t) {
  return static_cast<int>(t);
static inline bool is_type_023(BatteryType t) {
  return t == BatteryType::T0 || t == BatteryType::T2 || t == BatteryType::T3;
static inline bool is_type_56(BatteryType t) {
  return t == BatteryType::T5 || t == BatteryType::T6;
// ─── Data structures ─────────────────────────────────────────
struct RawBasicInfo {
  uint8_t batt_type, capacity, failure_code, overdischarge, overload;
  uint16_t cycles;
  bool cell_failure;
  uint8_t checksum_n[3];
  uint8_t aux_checksum_n[2];
struct HealthData {
  float rating;
  uint16_t overload_count;
  uint8_t od_count;
  uint32_t charge_level;
struct CellVoltages {
  float v[MAX_CELLS];
  uint8_t n;
  bool valid;
struct VoltageReadResult {
  float vpack;
  CellVoltages cells;
  float t_cell;
  float t_mosfet;
  bool ok;
static inline VoltageReadResult voltage_result_init() {
  VoltageReadResult vr{};
  vr.t_cell = TEMP_INVALID;
  vr.t_mosfet = TEMP_INVALID;
  return vr;
struct BatteryInfo {
  char model[8];
  uint8_t rom_id[8];
  bool rom_id_valid;
  BatteryType type;
  RawBasicInfo raw;
  HealthData health;
  float temperature_c;
  float temperature_mosfet_c;
  uint8_t cell_count;
  float capacity_ah;
  bool locked;
  bool checksums_ok[3];
  bool aux_checksums_ok[2];
  uint16_t lock_causes;  // bitfield of LF_* flags
// ─── Globals ──────────────────────────────────────────────────
static OneWire g_ow(PIN_ONEWIRE);
static Adafruit_NeoPixel g_pixel(NUM_PIXELS, NEOPIXEL_OUT_PIN, NEO_GRB + NEO_KHZ800);
static bool g_charger_arm_issued = false;
static bool g_in_testmode = false;
static volatile bool g_pulse_active = false;
static volatile bool g_pulse_scan_mode = true;
static volatile bool g_imbalance = false;
static volatile uint8_t g_result_r = 0;
static volatile uint8_t g_result_g = 0;
static volatile uint8_t g_result_b = 0;
static uint32_t g_last_poll = 0;
static uint8_t g_mode_debounce = 0;
static uint32_t g_last_mode_poll = 0;
// ─── Watchdog helpers ────────────────────────────────────────
static inline void wdt_kick() {
  watchdog_update();
#endif
static inline void wdt_begin() {
  watchdog_enable(WATCHDOG_TIMEOUT_MS, true);
#endif
static void safe_delay(uint32_t ms) {
  const uint32_t chunk = 500;
  while (ms > chunk) {
    delay(chunk);
    wdt_kick();
    ms -= chunk;
  delay(ms);
  wdt_kick();
// ─── NeoPixel colours ─────────────────────────────────────────
struct Colour {
  uint8_t r, g, b;
static constexpr Colour COL_OFF = { 0, 0, 0 };
static constexpr Colour COL_GREEN = { 0, LED_BRIGHTNESS_MAX, 0 };
static constexpr Colour COL_YELLOW = { LED_BRIGHTNESS_MAX, 60, 0 };
static constexpr Colour COL_ORANGE = { LED_BRIGHTNESS_MAX, 40, 0 };
static constexpr Colour COL_BLUE = { 0, 0, LED_BRIGHTNESS_MAX };
static constexpr Colour COL_RED = { LED_BRIGHTNESS_MAX, 0, 0 };
static constexpr Colour COL_PURPLE = { LED_BRIGHTNESS_MAX, 0, LED_BRIGHTNESS_MAX };
static constexpr Colour COL_WHITE = { LED_BRIGHTNESS_MAX, LED_BRIGHTNESS_MAX, LED_BRIGHTNESS_MAX };
static void led_set(Colour c) {
  g_pixel.setPixelColor(0, g_pixel.Color(c.r, c.g, c.b));
  g_pixel.show();
static void led_off() {
  led_set(COL_OFF);
static void led_yellow() {
  led_set(COL_YELLOW);
static void led_blue() {
  led_set(COL_BLUE);
static void led_purple() {
  led_set(COL_PURPLE);
static void led_flash(Colour c) {
  g_pulse_active = false;  // pause core1 during flash
  for (uint8_t i = 0; i < LED_FLASH_COUNT; i++) {
    led_set(c);
    safe_delay(LED_FLASH_ON_MS);
    led_off();
    safe_delay(LED_FLASH_OFF_MS);
  led_set(c);  // stays on after final flash
static void led_pulse(Colour c) {
  constexpr uint32_t HALF = LED_PULSE_PERIOD_MS / 2;
  uint32_t t = millis() % LED_PULSE_PERIOD_MS;
  uint8_t v = (t < HALF)
                ? (uint8_t)(t * LED_BRIGHTNESS_MAX / HALF)
                : (uint8_t)((LED_PULSE_PERIOD_MS - t) * LED_BRIGHTNESS_MAX / HALF);
  Colour sc = {
    (uint8_t)(v * c.r / LED_BRIGHTNESS_MAX),
    (uint8_t)(v * c.g / LED_BRIGHTNESS_MAX),
    (uint8_t)(v * c.b / LED_BRIGHTNESS_MAX),
  led_set(sc);
static inline void led_result(bool ok) {
  led_flash(ok ? COL_GREEN : COL_RED);
// ─── Mode detection ───────────────────────────────────────────
// Mode 0 = SCAN/UNLOCK  (both pins open)
// Mode 1 = OMEGA LOCK   (GPIO2-GPIO3 bridged)
enum DeviceMode { MODE_SCAN = 0,
                  MODE_LOCK = 1 };
static DeviceMode g_last_mode = MODE_SCAN;  // must follow DeviceMode definition
static inline bool mode_pin_active(uint8_t pin) {
  return digitalRead(pin) == (MODE_PIN_ACTIVE_HIGH ? HIGH : LOW);
static DeviceMode mode_read() {
  if (mode_pin_active(PIN_MODE_IN1)) return MODE_LOCK;
  return MODE_SCAN;
// ─── Bus control ─────────────────────────────────────────────
static void bus_enable(uint16_t ms = BUS_SETTLE_ON_MS) {
  digitalWrite(PIN_ENABLE, HIGH);
  safe_delay(ms);
static void bus_disable() {
  digitalWrite(PIN_ENABLE, LOW);
static void power_cycle_bus(uint16_t off_ms = POWERCYCLE_OFF_MS, uint16_t on_ms = BUS_SETTLE_ON_MS) {
  bus_disable();
  safe_delay(off_ms);
  bus_enable(on_ms);
static bool battery_present() {
  safe_delay(BUS_SETTLE_ON_MS);
  bool p = (g_ow.reset() == 1);
  return p;
// ─── Low-level 1-Wire transactions ───────────────────────────
static BusResult ow_transaction(bool managed, uint8_t rom_prefix,
                                const uint8_t *cmd, uint8_t cmd_len,
                                uint8_t *rsp, uint8_t rsp_len) {
  if (managed) bus_enable();
  if (!g_ow.reset()) {
    if (managed) bus_disable();
    return BUS_NO_PRESENCE;
  g_ow.write(rom_prefix, 0);
  if (rom_prefix == 0x33) {
    for (uint8_t i = 0; i < 8; i++) {
      delayMicroseconds(BUS_BYTE_GAP_US);
      rsp[i] = g_ow.read();
    rsp += 8;
  for (uint8_t i = 0; i < cmd_len; i++) {
    g_ow.write(cmd[i], 0);
  delayMicroseconds(BUS_SETTLE_US);
  for (uint8_t i = 0; i < rsp_len; i++) {
  return BUS_OK;
static BusResult cmd_cc(const uint8_t *c, uint8_t cl, uint8_t *r, uint8_t rl) {
  return ow_transaction(true, 0xCC, c, cl, r, rl);
static BusResult cmd_cc_raw(const uint8_t *c, uint8_t cl, uint8_t *r, uint8_t rl) {
  return ow_transaction(false, 0xCC, c, cl, r, rl);
// Two safe wrappers for the 0x33 (read-ROM) command.
// _with_rom : caller wants the 8 ROM bytes + rsp_len response bytes.
// _no_rom   : ROM bytes are discarded internally; rsp_len may be 0.
static BusResult cmd_33_with_rom(const uint8_t *c, uint8_t cl,
                                 uint8_t rom_out[8],
  uint8_t buf[8 + 32] = { 0 };
  BusResult res = ow_transaction(true, 0x33, c, cl, buf, rsp_len);
  if (res == BUS_OK) {
    memcpy(rom_out, buf, 8);
    if (rsp && rsp_len) memcpy(rsp, buf + 8, rsp_len);
  return res;
static BusResult cmd_33_no_rom(const uint8_t *c, uint8_t cl) {
  uint8_t throwaway[8] = { 0 };
  return ow_transaction(true, 0x33, c, cl, throwaway, 0);
// ─── Nybble helpers ───────────────────────────────────────────
static uint8_t nybble_get(const uint8_t *d, uint8_t n) {
  return (n % 2 == 0) ? (d[n / 2] & 0x0F) : ((d[n / 2] >> 4) & 0x0F);
static void nybble_set(uint8_t *d, uint8_t n, uint8_t v) {
  v &= 0x0F;
  if (n % 2 == 0) d[n / 2] = (d[n / 2] & 0xF0) | v;
  else d[n / 2] = (d[n / 2] & 0x0F) | (v << 4);
static uint8_t nybble_pair(const uint8_t *d, uint8_t hi, uint8_t lo) {
  return (uint8_t)((nybble_get(d, hi) << 4) | nybble_get(d, lo));
static uint8_t checksum_calc(const uint8_t *d, uint8_t s, uint8_t e) {
  uint8_t sum = 0;
  for (uint8_t i = s; i <= e; i++) sum += nybble_get(d, i);
  return sum & 0x0F;
static inline uint16_t le16(const uint8_t *b) {
  return (uint16_t)b[0] | ((uint16_t)b[1] << 8);
// ─── Utility ─────────────────────────────────────────────────
static void print_sep() {
  Serial.println(F("-------------------------------------------------"));
static void print_failure_code(uint8_t fc, const uint8_t d[BASIC_INFO_LEN]) {
  switch (fc) {
    case FC_OK: Serial.println(F("OK (0)")); break;
    case FC_OVERLOADED: Serial.println(F("BAD (1) — Overcurrent / overload")); break;
    case FC_OVERVOLT_C:
      Serial.print(F("BAD (3) — "));
      if (d[8] & 0x40) Serial.println(F("Fuse blown or mosfet shorted"));
      else if (d[8] & 0x02) Serial.println(F("Cell overvoltage while charging (4.37V)"));
      else Serial.println(F("Charging fault"));
    case FC_UNKNOWN4: Serial.println(F("BAD (4) — Fault (sub-cause not yet mapped)")); break;
    case FC_WARNING: Serial.println(F("BAD (5) — Warning")); break;
    case FC_NTC_IMBAL:
      Serial.print(F("BAD (7) — "));
      if (d[11] >= 0x80) Serial.println(F("NTC temperature difference >50C"));
      else if (d[13] & 0x80) Serial.println(F("EEPROM read error"));
      else if (d[13] >= 4) Serial.println(F("Cell overvoltage (4.22V)"));
      else if (d[11] >= 3) Serial.println(F("Cell imbalance >300mV at idle"));
      else Serial.println(F("Fault (sub-cause unclear)"));
    case FC_UNDERCAP: Serial.println(F("BAD (15) — Real cap under 70% of rated")); break;
    default:
      Serial.print(F("BAD — Unknown ("));
      Serial.print(fc);
      Serial.println(')');
// Prints each active lock cause with aligned brackets.
// Only prints if there are causes — nothing printed if clean.
static void print_lock_causes(const BatteryInfo &info, const uint8_t d[BASIC_INFO_LEN]) {
  if (info.lock_causes == 0) return;
  Serial.println(F("Lock causes    :"));
  char buf[48];
  if (info.lock_causes & LF_CS0) Serial.println(F("  CS0 mismatch     (nybbles 0-15)"));
  if (info.lock_causes & LF_CS2) Serial.println(F("  CS2 mismatch     (nybbles 32-40)"));
  if (info.lock_causes & LF_N34) {
    snprintf(buf, sizeof(buf), "  Nybble 34 = 0x%X  (must be 0)", nybble_get(d, 34));
    Serial.println(buf);
static void print_frame(const uint8_t d[BASIC_INFO_LEN],
                        const __FlashStringHelper *label = nullptr) {
  if (!label) label = F("Frame          : ");
  Serial.print(label);
  for (uint8_t i = 0; i < BASIC_INFO_LEN; i++) {
    if (i > 0 && i % 11 == 0) {
      Serial.print(F("                 "));
    if (d[i] < 0x10) Serial.print('0');
    Serial.print(d[i], HEX);
    if (i < BASIC_INFO_LEN - 1) Serial.print(' ');
// ─── Test mode ───────────────────────────────────────────────
static BusResult enter_testmode() {
  uint8_t r[1] = { 0 };
  BusResult res = cmd_cc(CMD_TESTMODE_ENTER, sizeof(CMD_TESTMODE_ENTER), r, 1);
    g_in_testmode = true;
    safe_delay(INTER_CMD_MS);
  return res;
static void exit_testmode() {
  if (!g_in_testmode) return;
  cmd_cc(CMD_TESTMODE_EXIT, sizeof(CMD_TESTMODE_EXIT), r, 1);
// ─── Basic info read ─────────────────────────────────────────
static BasicInfoResult read_basic_info(uint8_t d[BASIC_INFO_LEN]) {
  if (cmd_cc(CMD_BASIC_INFO, sizeof(CMD_BASIC_INFO), d, BASIC_INFO_LEN) != BUS_OK)
    return BASIC_INFO_NO_RESPONSE;
  uint8_t orv = 0, andv = 0xFF;
    orv |= d[i];
    andv &= d[i];
  if (orv == 0x00) return BASIC_INFO_NO_RESPONSE;
  if (andv == 0xFF) return BASIC_INFO_PRE_TYPE0;
  return BASIC_INFO_OK;
// ─── ROM ID read ─────────────────────────────────────────────
// Returns true on bus success. On failure rom_out is zero-filled; callers
// MUST treat it as invalid (a zero ROM looks like a valid type-5 ROM).
static bool read_rom_id(uint8_t rom_out[8]) {
  uint8_t rsp[BASIC_INFO_LEN] = { 0 };
  BusResult res = cmd_33_with_rom(CMD_BASIC_INFO, sizeof(CMD_BASIC_INFO),
                                  rom_out, rsp, BASIC_INFO_LEN);
  if (res != BUS_OK) {
    memset(rom_out, 0, 8);
    return false;
  return true;
// ─── Raw bus session helper ──────────────────────────────────
static bool raw_cc_session(uint16_t powerup_ms, bool send_skip_rom,
  if (powerup_ms) safe_delay(powerup_ms);
    return false;
  if (send_skip_rom) {
    g_ow.write(0xCC, 0);
  return true;
// ─── Model read ──────────────────────────────────────────────
static bool model_looks_valid(const char *m) {
  return strlen(m) >= 4 && ((m[0] == 'B' && m[1] == 'L') || (m[0] == 'D' && m[1] == 'C'));
static bool read_model(char out[8]) {
  uint8_t rsp[16] = { 0 };
  if (cmd_cc(CMD_MODEL, sizeof(CMD_MODEL), rsp, 16) != BUS_OK) {
    out[0] = '\0';
    return false;
  for (uint8_t i = 0; i < 7; i++) {
    uint8_t c = rsp[i];
    if (c < 0x20 || c >= 0x7F) {
      out[i] = '\0';
    out[i] = (char)c;
  out[7] = '\0';
  return model_looks_valid(out);
static bool read_model_type5(char out[8]) {
  // ENABLE must stay HIGH throughout — cutting power between the
  // session enter and model read resets the battery's internal state.
  // Session enter: CC 99
    snprintf(out, 8, "BL18xx");
    return false;
  g_ow.write(0x99, 0);
  // Model read: bare 0x31 — returns two bytes, high byte first
    return false;
  g_ow.write(0x31, 0);
  uint8_t hi = g_ow.read();
  uint8_t lo = g_ow.read();
  if ((hi != 0xFF || lo != 0xFF) && (hi != 0x00 || lo != 0x00)) {
    snprintf(out, 8, "BL%02X%02X", lo, hi);
    return true;
  return false;
// ─── Universal no-response recovery ──────────────────────────
static bool wait_for_response() {
  Serial.print(F("  [No response] - waiting"));
  uint32_t started = millis();
  while (millis() - started < NO_RESPONSE_TIMEOUT_MS) {
    wdt_kick();
    power_cycle_bus();
    if (g_ow.reset() == 1) {
      uint32_t elapsed = millis() - started;
      Serial.print(F(" OK ("));
      Serial.print(elapsed);
      Serial.println(F(" ms)"));
      return true;
    Serial.print(F("."));
  Serial.print(F(" TIMEOUT ("));
  Serial.print(NO_RESPONSE_TIMEOUT_MS);
  return false;
static bool poll_until_response(uint8_t frame[BASIC_INFO_LEN]) {
  Serial.print(F("  Waiting"));
    wdt_kick();
    if (read_basic_info(frame) == BASIC_INFO_OK) {
      Serial.print(F(" ("));
      return true;
    power_cycle_bus();
  return false;
// ─── Battery type detection ───────────────────────────────────
static int8_t detect_battery_type_raw(const uint8_t rom[8], const uint8_t d[BASIC_INFO_LEN],
                                      bool lock_only) {
  if (rom[3] < 100) return lock_only ? -1 : (int8_t)BatteryType::T5;
  if (d[17] == 30) return lock_only ? -1 : (int8_t)BatteryType::T6;
    static const uint8_t c[] = { 0xDC, 0x0B };
    uint8_t r[17] = { 0 };
    if (cmd_cc(c, sizeof(c), r, 17) == BUS_OK && r[16] == TYPE_PROBE_MAGIC) return 0;
    if (enter_testmode() == BUS_OK) {
      static const uint8_t c[] = { 0xDC, 0x0A };
      BusResult br = cmd_cc(c, sizeof(c), r, 17);
      exit_testmode();
      power_cycle_bus();  // quiet settle after testmode exit — do NOT poll here
      if (br == BUS_OK && r[16] == TYPE_PROBE_MAGIC) return 2;
    static const uint8_t c[] = { 0xD4, 0x2C, 0x00, 0x02 };
    uint8_t r[3] = { 0 };
    if (cmd_cc(c, sizeof(c), r, 3) == BUS_OK && r[2] == TYPE_PROBE_MAGIC) return 3;
  return lock_only ? -1 : 0;
static BatteryType detect_battery_type(const uint8_t rom[8], const uint8_t d[BASIC_INFO_LEN]) {
  return (BatteryType)detect_battery_type_raw(rom, d, false);
static int8_t lock_detect_type(const uint8_t rom[8], const uint8_t d[BASIC_INFO_LEN]) {
  return detect_battery_type_raw(rom, d, true);
// ─── Parse / derive ───────────────────────────────────────────
static void parse_basic_info(const uint8_t d[BASIC_INFO_LEN], RawBasicInfo &o) {
  o.batt_type = nybble_pair(d, 22, 23);
  o.capacity = nybble_pair(d, 32, 33);
  o.failure_code = nybble_get(d, 40);
  o.overdischarge = nybble_pair(d, 48, 49);
  o.overload = nybble_pair(d, 50, 51);
  o.cell_failure = (nybble_get(d, 44) & 0x04) != 0;
  o.cycles = ((uint16_t)(nybble_get(d, 52) & 0x1) << 12)
             | ((uint16_t)nybble_get(d, 53) << 8)
             | ((uint16_t)nybble_get(d, 54) << 4)
             | (uint16_t)nybble_get(d, 55);
  o.checksum_n[0] = nybble_get(d, 41);
  o.checksum_n[1] = nybble_get(d, 42);
  o.checksum_n[2] = nybble_get(d, 43);
  o.aux_checksum_n[0] = nybble_get(d, 62);
  o.aux_checksum_n[1] = nybble_get(d, 63);
static void derive_battery_info(const uint8_t d[BASIC_INFO_LEN], BatteryInfo &info) {
  const RawBasicInfo &r = info.raw;
  info.cell_count = (r.batt_type < 13) ? 4 : (r.batt_type < 30) ? 5
        : 10;
  info.capacity_ah = r.capacity / 10.0f;
  info.checksums_ok[0] = (checksum_calc(d, 0, 15) == r.checksum_n[0]);
  info.checksums_ok[1] = (checksum_calc(d, 16, 31) == r.checksum_n[1]);
  info.checksums_ok[2] = (checksum_calc(d, 32, 40) == r.checksum_n[2]);
  info.aux_checksums_ok[0] = (checksum_calc(d, 44, 47) == r.aux_checksum_n[0]);
  info.aux_checksums_ok[1] = (checksum_calc(d, 48, 61) == r.aux_checksum_n[1]);
  // Build lock cause bitfield — every known cause of a battery not charging
  info.lock_causes = 0;
  if (!info.checksums_ok[0]) info.lock_causes |= LF_CS0;
  if (!info.checksums_ok[2]) info.lock_causes |= LF_CS2;
  if (nybble_get(d, 34) != 0) info.lock_causes |= LF_N34;
  info.locked = (info.lock_causes != 0);
static inline void refresh_info_from_frame(const uint8_t d[BASIC_INFO_LEN], BatteryInfo &info) {
  parse_basic_info(d, info.raw);
  derive_battery_info(d, info);
// ─── Health calculations ──────────────────────────────────────
static float calc_health_type56(const RawBasicInfo &r) {
  int16_t f_ol = max((int16_t)((int16_t)r.overload - 29), (int16_t)0);
  int16_t f_od = max((int16_t)(35 - (int16_t)r.overdischarge), (int16_t)0);
  float dmg = r.cycles + r.cycles * (f_ol + f_od) / 32.0f;
  uint16_t scale = HEALTH_SCALE_STANDARD;
  for (size_t i = 0; i < HEALTH_SCALE_EXTENDED_COUNT; i++)
    if (r.capacity == HEALTH_SCALE_EXTENDED_CODES[i]) {
      scale = HEALTH_SCALE_EXTENDED;
  return max(0.0f, HEALTH_MAX - dmg / scale);
static float calc_health_type023(uint16_t raw, uint8_t cap) {
  if (cap == 0) return 0.0f;
  float ratio = (float)raw / cap;
  return (ratio > 80.0f) ? HEALTH_MAX : max(0.0f, ratio / 10.0f - 5.0f);
static float calc_health_damage_rating(const uint8_t d[BASIC_INFO_LEN]) {
  uint8_t dmg = (nybble_get(d, 46) >> 1) & 0x07;
  if (dmg < 3) return HEALTH_MAX;
  if (dmg >= 7) return 0.0f;
  return max(0.0f, HEALTH_MAX - (float)(dmg - 2));
// ─── Secondary reads (types 0, 2, 3) ─────────────────────────
static bool cc_probe(const uint8_t *cmd, uint8_t *rsp, uint8_t rsp_len) {
  if (cmd_cc(cmd, 4, rsp, rsp_len) != BUS_OK) return false;
  return rsp[rsp_len - 1] == TYPE_PROBE_MAGIC;
static uint8_t type023_idx(BatteryType t) {
  return (t == BatteryType::T2) ? 1 : (t == BatteryType::T3) ? 2
                                                             : 0;
static uint16_t read_health_raw(BatteryType t) {
  static const uint8_t cmds[3][4] = {
    { 0xD4, 0x50, 0x01, 0x02 }, { 0xD6, 0x04, 0x05, 0x02 }, { 0xD6, 0x38, 0x02, 0x02 }
  if (!is_type_023(t)) return 0;
  return cc_probe(cmds[type023_idx(t)], r, 3) ? le16(r) : 0;
static uint8_t read_od_count(BatteryType t) {
    { 0xD4, 0xBA, 0x00, 0x01 }, { 0xD6, 0x8D, 0x05, 0x01 }, { 0xD6, 0x09, 0x03, 0x01 }
  uint8_t r[2] = { 0 };
  return cc_probe(cmds[type023_idx(t)], r, 2) ? r[0] : 0;
static uint16_t read_overload_count(BatteryType t) {
  switch (t) {
    case BatteryType::T0:
        static const uint8_t c[] = { 0xD4, 0x8D, 0x00, 0x07 };
        uint8_t r[8] = { 0 };
        if (!cc_probe(c, r, 8)) return 0;
        uint16_t a = ((uint16_t)(r[0] >> 6) & 0x03) | ((uint16_t)r[1] << 2);
        uint16_t b = (uint16_t)r[3] | (((uint16_t)r[4] & 0x03) << 8);
        uint16_t c2 = ((uint16_t)(r[5] >> 4)) | (((uint16_t)r[6] & 0x3F) << 4);
        return a + b + c2;
    case BatteryType::T2:
        static const uint8_t c[] = { 0xD6, 0x5F, 0x05, 0x07 };
        return cc_probe(c, r, 8) ? (uint16_t)(r[0] + r[2] + r[3] + r[5] + r[6]) : 0;
    case BatteryType::T3:
        static const uint8_t c[] = { 0xD6, 0x5B, 0x03, 0x04 };
        uint8_t r[6] = { 0 };
        return cc_probe(c, r, 6) ? (uint16_t)(r[0] + r[2] + r[3]) : 0;
    default: return 0;
static uint32_t read_charge_level() {
  static const uint8_t cmd[] = { 0xD7, 0x19, 0x00, 0x04 };
  uint8_t r[5] = { 0 };
  if (!cc_probe(cmd, r, 5)) return 0;
  return (uint32_t)r[0] | ((uint32_t)r[1] << 8) | ((uint32_t)r[2] << 16) | ((uint32_t)r[3] << 24);
// ─── Temperature (type 6 only) ───────────────────────────────
static float read_temperature_type6() {
  static const uint8_t CMD_TEMP6[] = { 0xD2 };
  bus_enable();
  bool ok = g_ow.reset() != 0;
  if (ok) {
    g_ow.write(CMD_TEMP6[0], 0);
    r[0] = g_ow.read();
  bus_disable();
  return ok ? (TEMP6_A + TEMP6_B * r[0]) / 100.0f : TEMP_INVALID;
// ─── Voltage reads ────────────────────────────────────────────
static bool read_voltages_type023(VoltageReadResult &vr, uint8_t ncells) {
  static const uint8_t ext[] = { 0xD7, 0x00, 0x00, 0xFF };
  static const uint8_t short_[] = { 0xD7, 0x00, 0x00, 0x0C };
  uint8_t r[27] = { 0 };
  uint8_t n = min(ncells, (uint8_t)5);
  bool ok = (cmd_cc(ext, sizeof(ext), r, 27) == BUS_OK) && (le16(&r[0]) > 0);
  if (ok) {
    vr.vpack = le16(&r[0]) / 1000.0f;
    for (uint8_t i = 0; i < n; i++) vr.cells.v[i] = le16(&r[2 + i * 2]) / 1000.0f;
    vr.cells.n = n;
    vr.cells.valid = true;
    uint16_t rc = le16(&r[14]), rm = le16(&r[16]);
    vr.t_cell = (rc != 0 && rc != 0xFFFF) ? rc / 10.0f - 273.15f : TEMP_INVALID;
    vr.t_mosfet = (rm != 0 && rm != 0xFFFF) ? rm / 10.0f - 273.15f : TEMP_INVALID;
    vr.ok = true;
    return true;
  uint8_t s[13] = { 0 };
  if (cmd_cc(short_, sizeof(short_), s, 13) != BUS_OK || s[12] != TYPE_PROBE_MAGIC) return false;
  vr.vpack = le16(&s[0]) / 1000.0f;
  for (uint8_t i = 0; i < n; i++) vr.cells.v[i] = le16(&s[2 + i * 2]) / 1000.0f;
  vr.cells.n = n;
  vr.ok = true;
  return true;
// ─── Type 5 voltage reads ────────────────────────────────────
// Two-path approach for the two known Type 5 variants:
// Fast path: battery session is already warm from read_model_type5.
//   CC 31 responds immediately — read all cells and return.
// Slow path: battery ADC needs multiple read cycles to settle.
//   Re-enter session with CC 99, then poll until all cells valid.
static bool read_voltages_type5(VoltageReadResult &vr, uint8_t ncells) {
  static const uint8_t CELL_CMDS[] = { 0x31, 0x32, 0x33, 0x34, 0x35 };
  static const uint8_t TC[] = { TYPE5_CMD_TEMP };
  // ── Fast path ────────────────────────────────────────────────
  // Try CC 31 immediately. If cell 1 returns a valid voltage the
  // session is warm and we can read all cells in one pass.
    cmd_cc(&CELL_CMDS[0], 1, r, 2);  // managed — enables bus with 150ms settle
    uint16_t mv = le16(r);
    if (mv >= 2500 && mv <= 4500) {
      float pack = mv / 1000.0f;
      vr.cells.v[0] = mv / 1000.0f;
      bus_enable();  // bus was disabled by cmd_cc — re-enable for raw reads
      for (uint8_t i = 1; i < n; i++) {
        r[0] = r[1] = 0;
        cmd_cc_raw(&CELL_CMDS[i], 1, r, 2);
        mv = le16(r);
        if (mv >= 500 && mv <= 4800) {
          vr.cells.v[i] = mv / 1000.0f;
          pack += vr.cells.v[i];
      r[0] = r[1] = 0;
      cmd_cc_raw(TC, 1, r, 2);
      uint16_t traw = le16(r);
      if (traw > 0 && traw != 0xFFFF) vr.t_cell = traw / 100.0f;
      bus_disable();
      vr.cells.n = n;
      vr.vpack = pack;
      vr.ok = true;
      return true;
  // ── Slow path ────────────────────────────────────────────────
  // Cell 1 returned 0 — re-enter session and poll until the ADC
  // has valid data for all cells.
  uint8_t prime[2] = { 0 };
  raw_cc_session(0, true, &TYPE5_CMD_SESSION, 1, prime, 0);
  raw_cc_session(0, false, &TYPE5_CMD_MODEL, 1, prime, 2);
  float best_v[5] = { 0 };
  uint8_t best_any = 0;
  float best_pack = 0, best_temp = TEMP_INVALID;
  for (uint8_t attempt = 0; attempt < TYPE5_MAX_ATTEMPTS; attempt++) {
    wdt_kick();
    float v[5] = { 0 };
    uint8_t got = 0;
    float pack = 0;
    // First cell uses managed cmd_cc (150ms settle after bus was off)
        pack += v[0];
        got++;
    // Remaining cells use raw — bus already enabled by first read
    bus_enable();
        pack += v[i];
        got++;
    uint8_t tr[2] = { 0 };
    cmd_cc_raw(TC, 1, tr, 2);
    bus_disable();
    uint16_t traw = le16(tr);
    float t = (traw > 0 && traw != 0xFFFF) ? traw / 100.0f : TEMP_INVALID;
    if (got >= best_any) {
      best_any = got;
      best_pack = pack;
      best_temp = t;
      for (uint8_t i = 0; i < n; i++) best_v[i] = v[i];
    if (got == n) break;
  if (best_any == 0) return false;
  for (uint8_t i = 0; i < n; i++) vr.cells.v[i] = best_v[i];
  vr.cells.n = n;
  vr.vpack = best_pack;
  vr.t_cell = best_temp;
  vr.ok = true;
  return true;
static bool read_voltages_type6(VoltageReadResult &vr, uint8_t ncells) {
  uint8_t ign[1] = { 0 }, r[20] = { 0 };
  bus_enable();
    static const uint8_t c[] = { 0x10, 0x21 };
    cmd_cc_raw(c, sizeof(c), ign, 0);
    safe_delay(10);
  if (ok) {
    g_ow.write(TYPE6_VOLT_READ, 0);
    for (uint8_t i = 0; i < 20; i++) {
      r[i] = g_ow.read();
  bus_disable();
  if (!ok) return false;
  uint8_t n = min(ncells, (uint8_t)MAX_CELLS);
  float pack = 0;
  for (uint8_t i = 0; i < n; i++) {
    vr.cells.v[i] = (6000.0f - le16(&r[i * 2]) / 10.0f) / 1000.0f;
  vr.cells.n = n;
  vr.vpack = pack;
  vr.ok = true;
  return true;
// ─── Diagnostic report ───────────────────────────────────────
// ─── Type 0 extended stats via D7 SRAM read ──────────────────
struct D7Data {
  bool valid = false;
  float current_avg = 0.0f;
  uint16_t soc = 0;
  uint16_t rem1 = 0;
  uint16_t rem2 = 0;
  uint8_t error_status = 0;
  uint8_t error_counters[6] = { 0 };
  uint16_t stability_count = 0;
static D7Data read_d7_type0(VoltageReadResult &vr) {
  D7Data d7;
  uint8_t xcmd[] = { 0xD7, 0x00, 0x00, 0xFE };
  uint8_t xbuf[255] = { 0 };
  if (cmd_cc(xcmd, 4, xbuf, 255) != BUS_OK) return d7;
  float pack = 0;
  vr.cells.n = 5;
  vr.ok = true;
  for (uint8_t i = 0; i < 5; i++) {
    uint16_t mv = (uint16_t)xbuf[0x02 + i * 2] | ((uint16_t)xbuf[0x03 + i * 2] << 8);
  vr.vpack = pack;
  uint16_t t1 = (uint16_t)xbuf[0x0E] | ((uint16_t)xbuf[0x0F] << 8);
  uint16_t t2 = (uint16_t)xbuf[0x10] | ((uint16_t)xbuf[0x11] << 8);
  vr.t_cell = (t1 > 0 && t1 != 0xFFFF) ? t1 / 10.0f - 273.15f : TEMP_INVALID;
  vr.t_mosfet = (t2 > 0 && t2 != 0xFFFF) ? t2 / 10.0f - 273.15f : TEMP_INVALID;
  uint8_t lccmd[] = { 0xD7, 0x61, 0x03, 0x02 };
  uint8_t lcbuf[3] = { 0 };
  if (cmd_cc(lccmd, 4, lcbuf, 3) == BUS_OK) {
    uint16_t lc = (uint16_t)lcbuf[0] | ((uint16_t)lcbuf[1] << 8);
    d7.current_avg = (lc != 0xFFFF && lc != 0x0000) ? (32768.0f - (float)lc) / 100.0f : 0.0f;
  d7.soc = (uint16_t)xbuf[0x15] | ((uint16_t)xbuf[0x16] << 8);
  d7.rem1 = (uint16_t)xbuf[0x17] | ((uint16_t)xbuf[0x18] << 8);
  d7.rem2 = (uint16_t)xbuf[0x1D] | ((uint16_t)xbuf[0x1E] << 8);
  d7.error_status = xbuf[0x30];
  for (uint8_t i = 0; i < 6; i++) d7.error_counters[i] = xbuf[0x57 + i];
  d7.stability_count = (uint16_t)xbuf[0x67] | ((uint16_t)xbuf[0x68] << 8);
  d7.valid = true;
  return d7;
static void print_report(const BatteryInfo &info, const VoltageReadResult &vr,
                         const uint8_t d[BASIC_INFO_LEN], const D7Data &d7) {
  Serial.print(F("Model          : "));
  Serial.println(info.model);
  Serial.print(F("ROM ID         : "));
  if (info.rom_id_valid) {
      if (info.rom_id[i] < 0x10) Serial.print('0');
      Serial.print(info.rom_id[i], HEX);
      if (i < 7) Serial.print(' ');
    char db[13];
    snprintf(db, sizeof(db), "%02d/%02d/20%02d", info.rom_id[2], info.rom_id[1], info.rom_id[0]);
    Serial.print(F("Mfg date       : "));
    Serial.println(db);
    Serial.println(F("(unavailable)"));
  Serial.print(F("Detected type  : "));
  Serial.println(batt_type_to_int(info.type));
  Serial.print(F("Family type    : "));
  Serial.print(info.raw.batt_type);
  if (info.raw.batt_type < 13) Serial.print(F("4 cell BL14xx"));
  else if (info.raw.batt_type < 30) Serial.print(F("5 cell BL18xx"));
  else Serial.print(F("10 cell BL36xx"));
  Serial.print(F("Rated capacity : "));
  Serial.print(info.capacity_ah, 1);
  Serial.println(F(" Ah"));
  if (d7.valid) {
    Serial.print(F("Real capacity  : "));
    Serial.print(d7.rem1 / 1000.0f, 3);
    Serial.print(F("Target capacity: "));
    Serial.print(d7.rem2 / 1000.0f, 3);
  print_sep();
  if (info.raw.cycles > 0) {
    Serial.print(F("Cycle count    : "));
    Serial.println(info.raw.cycles);
  if (info.health.rating > 0.0f) {
    Serial.print(F("Health         : "));
    Serial.print(info.health.rating, 2);
    Serial.print(F(" / 4  ("));
    int h = (int)round(info.health.rating);
    for (int i = 0; i < 4; i++) Serial.print(i < h ? '#' : '-');
  if (is_type_023(info.type)) {
    Serial.print(F("Overdischarge #: "));
    Serial.println(info.health.od_count);
    Serial.print(F("Overdischarge %: "));
    if (info.health.od_count == 0 || info.raw.cycles == 0) {
      Serial.println(F("0.0 %"));
      Serial.print(4.0f + 100.0f * info.health.od_count / info.raw.cycles, 1);
      Serial.println(F(" %"));
    Serial.print(F("Overload #     : "));
    Serial.println(info.health.overload_count);
    Serial.print(F("Overload %     : "));
    if (info.health.overload_count == 0 || info.raw.cycles == 0) {
      Serial.print(4.0f + 100.0f * info.health.overload_count / info.raw.cycles, 1);
  if (is_type_56(info.type)) {
    Serial.print(F("OD %           : "));
    Serial.print(-5.0f * info.raw.overdischarge + 160.0f, 1);
    Serial.print(5.0f * info.raw.overload - 160.0f, 1);
  if (info.temperature_c != TEMP_INVALID) {
    Serial.print(F("Temp (Cells)   : "));
    Serial.print(info.temperature_c, 1);
    Serial.println(F(" C"));
  if (info.temperature_mosfet_c != TEMP_INVALID) {
    Serial.print(F("Temp (Mosfet)  : "));
    Serial.print(info.temperature_mosfet_c, 1);
  if (d7.valid) {
    float current_display = d7.current_avg + (info.capacity_ah >= 12.0f ? 200.0f : 0.0f);
    Serial.print(F("Current Draw   : "));
    Serial.print(current_display, 2);
    Serial.println(F(" A"));
    Serial.print(F("State of Charge: "));
    Serial.print(d7.soc / 256.0f, 1);
    float remaining_ah = (d7.soc / 256.0f / 100.0f) * (d7.rem2 / 1000.0f);
    Serial.print(F("Remaining chg  : "));
    Serial.print(remaining_ah, 3);
    uint16_t secs_elapsed = (d7.stability_count <= 2399) ? d7.stability_count / 6 : 399;
    uint16_t secs_to_next = (d7.stability_count <= 2399) ? (2399 - d7.stability_count) / 6 : 0;
    Serial.print(F("Last SOC Recalc: "));
    Serial.print(secs_elapsed);
    Serial.print(F("s ago (~"));
    Serial.print(secs_to_next);
    Serial.println(F("s to recalc)"));
  print_sep();
  Serial.print(F("Pack voltage   : "));
  Serial.println(vr.vpack, 3);
  if (!vr.cells.valid || vr.cells.n == 0) {
    Serial.println(F("(no cells reported)"));
    float vmax = vr.cells.v[0], vmin = vr.cells.v[0];
    for (uint8_t i = 0; i < vr.cells.n; i++) {
      char lb[22];
      snprintf(lb, sizeof(lb), "Cell %2u        : ", (unsigned)i + 1);
      Serial.print(lb);
      Serial.println(vr.cells.v[i], 3);
      if (vr.cells.v[i] > vmax) vmax = vr.cells.v[i];
      if (vr.cells.v[i] < vmin) vmin = vr.cells.v[i];
    Serial.print(F("Cell imbalance : "));
    Serial.println(vmax - vmin, 3);
  if (!d7.valid && is_type_023(info.type) && info.health.charge_level > 0 && info.raw.capacity > 0) {
    float ratio = (float)info.health.charge_level / info.raw.capacity / SOC_DIVISOR;
    uint8_t soc = (ratio < 10.0f) ? 1 : (uint8_t)min((int)(ratio / 10.0f), 7);
    print_sep();
    Serial.print(F("State of charge: "));
    Serial.print(soc);
    Serial.println(F(" / 7"));
  print_sep();
  Serial.print(F("Lock status    : "));
  Serial.println(info.locked ? F("LOCKED") : F("UNLOCKED"));
  Serial.print(F("Cell failure   : "));
  Serial.println(info.raw.cell_failure ? F("YES") : F("No"));
  Serial.print(F("Checksum 0-15  : "));
  Serial.println(info.checksums_ok[0] ? F("OK") : F("BAD"));
  Serial.print(F("Checksum 16-31 : "));
  Serial.println(info.checksums_ok[1] ? F("OK") : F("BAD"));
  Serial.print(F("Checksum 32-40 : "));
  Serial.println(info.checksums_ok[2] ? F("OK") : F("BAD"));
  Serial.print(F("Aux CSum 44-47 : "));
  Serial.println(info.aux_checksums_ok[0] ? F("OK") : F("BAD"));
  Serial.print(F("Aux CSum 48-61 : "));
  Serial.println(info.aux_checksums_ok[1] ? F("OK") : F("BAD"));
    char buf[64];
    if (d[1] == 0x26) Serial.println(F("Byte 1 origin  : China/Murata (26)"));
    else if (d[1] == 0x36) Serial.println(F("Byte 1 origin  : Vietnam/Samsung (36)"));
    else if (d[1] == 0x31) Serial.println(F("Byte 1 origin  : Old family (31)"));
    else {
      snprintf(buf, sizeof(buf), "Byte 1 origin  : Unknown (%02X)", d[1]);
    uint8_t n34 = nybble_get(d, 34);
    snprintf(buf, sizeof(buf), "Nybble 34 lock : %s (%X)", (n34 == 0 ? "OK" : "BAD"), n34);
    snprintf(buf, sizeof(buf), "Byte 19 status : (%02X)", d[19]);
    Serial.print(F("Nybble 40 code : "));
    print_failure_code(info.raw.failure_code, d);
  if (d7.valid) {
    Serial.print(F("Error status   : 0b"));
    Serial.println(d7.error_status, BIN);
    Serial.print(F("Error counters : "));
    for (uint8_t i = 0; i < 6; i++) {
      if (d7.error_counters[i] < 0x10) Serial.print('0');
      Serial.print(d7.error_counters[i], HEX);
      Serial.print(' ');
  if (info.locked) print_lock_causes(info, d);
  print_sep();
  print_frame(d);
// ─── Frame repair / write ────────────────────────────────────
static bool charger_write_frame(const uint8_t src[BASIC_INFO_LEN]) {
  if (g_charger_arm_issued) {
    Serial.println(F("  Arm already issued - power-cycle required."));
    return false;
    uint8_t r[BASIC_INFO_LEN] = { 0 };
    if (cmd_cc(CMD_CC_F0, sizeof(CMD_CC_F0), r, BASIC_INFO_LEN) != BUS_OK) {
      Serial.println(F("  Arm: no presence."));
      return false;
    g_charger_arm_issued = true;
    uint8_t payload[2 + BASIC_INFO_LEN];
    payload[0] = FRAME_WRITE_OPCODE;
    payload[1] = FRAME_WRITE_PAD;
    memcpy(&payload[2], src, BASIC_INFO_LEN);
    if (cmd_33_no_rom(payload, sizeof(payload)) != BUS_OK) {
      Serial.println(F("  Write: no presence."));
      return false;
    if (cmd_33_no_rom(CMD_STORE, sizeof(CMD_STORE)) != BUS_OK) {
      Serial.println(F("  Store: no presence."));
      return false;
  return true;
static bool do_protected_write(const uint8_t frame[BASIC_INFO_LEN],
                               const __FlashStringHelper *log_prefix) {
  if (enter_testmode() != BUS_OK) {
    Serial.print(log_prefix);
    Serial.println(F("No presence entering testmode."));
    if (!wait_for_response()) return false;
      Serial.println(F("Still no presence. Aborting write."));
      return false;
  if (!charger_write_frame(frame)) {
    exit_testmode();
    power_cycle_bus();
    return false;
  exit_testmode();
  return true;
// Send DA04 error register clear. Call after a successful frame write.
// Frame repair — sets nybble 34 = 0 and recalculates checksums.
// Confirmed by testing: only nybble 34, CS0, and CS2 are charger-validated.
// All other frame data is left untouched.
static bool repair_frame(uint8_t data32[BASIC_INFO_LEN]) {
  uint8_t frame[BASIC_INFO_LEN];
  memcpy(frame, data32, BASIC_INFO_LEN);
  // Set nybble 34 = 0 — the only charger lock nybble (byte 17 high nybble preserved)
  frame[17] = (frame[17] & 0xF0) | 0x00;
  // Recalculate CS0 and CS2 — the only checksums the charger validates
  nybble_set(frame, 41, checksum_calc(frame, 0, 15));   // CS0
  nybble_set(frame, 43, checksum_calc(frame, 32, 40));  // CS2
  print_frame(frame, F("  Repair frame : "));
  if (!do_protected_write(frame, F("  "))) return false;
  power_cycle_bus();
  uint8_t verify[BASIC_INFO_LEN] = { 0 };
  if (!poll_until_response(verify)) {
    Serial.println(F("  No response during verify."));
    return false;
  bool ok0 = (checksum_calc(verify, 0, 15) == nybble_get(verify, 41));
  bool ok2 = (checksum_calc(verify, 32, 40) == nybble_get(verify, 43));
  uint8_t n34 = nybble_get(verify, 34);
  char buf[48];
  snprintf(buf, sizeof(buf), "  Lock check : CS0=%s  CS2=%s  N34=%s (%u)",
           ok0 ? "OK" : "BAD",
           ok2 ? "OK" : "BAD",
           n34 == 0 ? "OK" : "BAD", (unsigned)n34);
  if (ok0 && ok2 && n34 == 0) {
    memcpy(data32, verify, BASIC_INFO_LEN);
    return true;
  return false;
static bool type_supports_unlock(BatteryType t) {
  return is_type_023(t);
// ─── Scan steps ───────────────────────────────────────────────
static BasicInfoResult step_read_basic_info(uint8_t d[BASIC_INFO_LEN]) {
  bool printed = false;
    BasicInfoResult r = read_basic_info(d);
    if (r != BASIC_INFO_NO_RESPONSE) {
      if (printed) {
      return r;
    if (!printed) {
      printed = true;
    wdt_kick();
    power_cycle_bus();
  if (printed) Serial.println();
  if (!wait_for_response()) return BASIC_INFO_NO_RESPONSE;
  return read_basic_info(d);
static void step_identify(BatteryInfo &info, const uint8_t d[BASIC_INFO_LEN]) {
  info.rom_id_valid = read_rom_id(info.rom_id);
  if (!info.rom_id_valid)
    Serial.println(F("WARNING: ROM ID read failed; using fallback type detection."));
  info.type = detect_battery_type(info.rom_id, d);
  (void)((info.type == BatteryType::T5) ? read_model_type5(info.model) : read_model(info.model));
static VoltageReadResult step_read_voltages(const BatteryInfo &info) {
  VoltageReadResult vr = voltage_result_init();
  switch (info.type) {
    case BatteryType::T5:
      safe_delay(10);
      read_voltages_type5(vr, info.cell_count);
    case BatteryType::T6: read_voltages_type6(vr, info.cell_count); break;
    default: read_voltages_type023(vr, info.cell_count); break;
  return vr;
static void step_read_health(BatteryInfo &info, const uint8_t d[BASIC_INFO_LEN]) {
  info.health = {};
    info.health.rating = calc_health_type56(info.raw);
  } else if (is_type_023(info.type)) {
    info.health.rating = calc_health_type023(read_health_raw(info.type), info.raw.capacity);
    info.health.od_count = read_od_count(info.type);
    info.health.overload_count = read_overload_count(info.type);
    info.health.charge_level = (info.type == BatteryType::T0) ? read_charge_level() : 0;
    info.health.rating = calc_health_damage_rating(d);
// ─── Unlock sequence ─────────────────────────────────────────
static void step_handle_lock(BatteryInfo &info, uint8_t d[BASIC_INFO_LEN]) {
  if (!info.locked) {
    Serial.println(F("Battery UNLOCKED."));
    led_flash(COL_GREEN);
    if (type_supports_unlock(info.type)) power_cycle_bus();
    return;
  if (!type_supports_unlock(info.type)) {
    Serial.print(F("Unlock not supported for type "));
    Serial.print(batt_type_to_int(info.type));
    Serial.println(F(". Skipping."));
    led_flash(COL_RED);
    return;
  Serial.println(F("Battery LOCKED."));
  led_yellow();
  bool unlocked = false;
  for (uint8_t attempt = 1; attempt <= UNLOCK_MAX_CYCLES && !unlocked; attempt++) {
    wdt_kick();
    if (attempt == 1) {
      // Attempt 1: DA04 error register clear.
      // Handles naturally locked batteries (overdischarge, overload).
      // Type 2 batteries self-repair entirely via DA04.
      Serial.println(F("--- Attempt 1: DA04 reset"));
      led_yellow();
      power_cycle_bus();
        uint8_t rom[8] = { 0 }, r[9] = { 0 };
        cmd_33_with_rom(CMD_RESET_ERRORS, sizeof(CMD_RESET_ERRORS), rom, r, 9);
        exit_testmode();
        power_cycle_bus();
        if (poll_until_response(verify)) {
          memcpy(d, verify, BASIC_INFO_LEN);
          refresh_info_from_frame(d, info);
          if (!info.locked) {
            Serial.println(F("  -> UNLOCKED by DA04."));
            unlocked = true;
            continue;
          Serial.println(F("  -> Still locked. Trying frame repair."));
      // Fall through to frame repair on same attempt
    // Attempt 1 fallthrough + attempts 2-6: frame repair
    Serial.print(F("--- Attempt "));
    Serial.print(attempt);
    Serial.println(F(": Frame repair"));
    led_purple();
    if (repair_frame(d)) {
      if (!info.locked) {
        Serial.println(F("  -> UNLOCKED."));
        unlocked = true;
        Serial.println(F("  -> Still locked. Retrying."));
      Serial.println(F("  -> Frame repair failed."));
  if (unlocked) {
    Serial.println(F("Battery successfully unlocked."));
    power_cycle_bus();
    Serial.println(F("Battery still locked."));
    led_flash(COL_RED);
//  OMEGA LOCK
//  Sets nybble 34 (original Makita charger lock nybble) non-zero.
//  Present in ALL Makita LXT batteries. Charger rejects if non-zero.
//  DA04 cannot undo this lock. Only repair_frame() can restore it.
static void omega_mutate(uint8_t v[BASIC_INFO_LEN]) {
  // Set nybble 34 = 4, preserve nybble 35 (high nybble of byte 17)
  v[17] = (v[17] & 0xF0) | 0x04;
  // Recalculate CS2 (covers nybbles 32-40, includes byte 17)
  nybble_set(v, 43, checksum_calc(v, 32, 40));
static bool omega_verify(const uint8_t v[BASIC_INFO_LEN]) {
  return nybble_get(v, 34) != 0;
static bool omega_already_locked(const uint8_t frame[BASIC_INFO_LEN]) {
  return nybble_get(frame, 34) != 0;
static bool run_lock() {
  if (g_in_testmode) exit_testmode();
  power_cycle_bus();
  led_blue();
  uint8_t rom_id[8] = { 0 };
  bool rom_ok = read_rom_id(rom_id);
  uint8_t frame[BASIC_INFO_LEN] = { 0 };
  BasicInfoResult fr = step_read_basic_info(frame);
  if (fr != BASIC_INFO_OK) {
    if (fr == BASIC_INFO_PRE_TYPE0) {
      Serial.println(F("  [Lock] Pre-type-0 HC08 - unsupported."));
      led_yellow();
      Serial.println(F("  [Lock] ERROR: No valid frame."));
      led_flash(COL_RED);
    bus_disable();
    return false;
  if (!rom_ok) Serial.println(F("  [Lock] WARNING: ROM ID read failed."));
  int8_t type = lock_detect_type(rom_id, frame);
  Serial.print(F("  [Lock] Type: "));
  if (type < 0) {
    Serial.println(F("unsupported (5, 6, or unknown)."));
    led_yellow();
    bus_disable();
    return false;
  Serial.println(type);
  if (omega_already_locked(frame)) {
    Serial.println(F("  [Lock] Battery already OMEGA LOCKED (nybble 34 != 0)."));
    led_flash(COL_RED);
    bus_disable();
    return true;
  bool ok = false;
  for (uint8_t attempt = 1; attempt <= LOCK_MAX_ATTEMPTS && !ok; attempt++) {
    Serial.print(F("  [Lock] Attempt "));
    Serial.println(attempt);
    wdt_kick();
    uint8_t v[BASIC_INFO_LEN];
    memcpy(v, frame, BASIC_INFO_LEN);
    omega_mutate(v);
    led_purple();
    if (!do_protected_write(v, F("  [Lock] "))) {
      bus_disable();
      return false;
    power_cycle_bus();
      Serial.println(F("  [Lock] No response."));
    Serial.print(F("  [Lock] Nybble 34 = "));
    Serial.println(nybble_get(verify, 34));
    ok = omega_verify(verify);
  print_sep();
  if (ok) Serial.println(F("  [Lock] OMEGA LOCKED. Nybble 34 set non-zero."));
  else Serial.println(F("  [Lock] FAILED."));
  print_sep();
  led_result(ok);
  bus_disable();
  return ok;
// ─── Main scan ───────────────────────────────────────────────
static bool run_scan() {
  power_cycle_bus();
  led_blue();
  BatteryInfo info{};
  info.temperature_c = info.temperature_mosfet_c = TEMP_INVALID;
  info.type = BatteryType::UNKNOWN;
  uint8_t data32[BASIC_INFO_LEN] = { 0 };
  BasicInfoResult br = step_read_basic_info(data32);
  if (br == BASIC_INFO_NO_RESPONSE) {
    Serial.println(F("ERROR: Battery not responding after retries. Aborting."));
    bus_disable();
    return false;
  if (br == BASIC_INFO_PRE_TYPE0) {
    print_sep();
    Serial.println(F("WARNING: Pre-type-0 HC08 battery detected!"));
    Serial.println(F("         Freescale MC908JK3E BMS -- no cell protection."));
    Serial.println(F("         DO NOT charge on any charger."));
    print_sep();
    led_flash(COL_RED);
    bus_disable();
    return true;
  refresh_info_from_frame(data32, info);
  step_identify(info, data32);
  print_sep();
  Serial.print(F("Battery found  : "));
  D7Data d7;
  VoltageReadResult vr;
  if (info.type == BatteryType::T0) {
    d7 = read_d7_type0(vr);
    vr = step_read_voltages(info);
  info.temperature_c = vr.t_cell;
  info.temperature_mosfet_c = vr.t_mosfet;
  if (info.type == BatteryType::T6) info.temperature_c = read_temperature_type6();
  step_read_health(info, data32);
  if (!battery_present()) {
    Serial.println(F("Battery removed during scan. Aborting."));
    bus_disable();
    return false;
  if (!vr.ok) Serial.println(F("WARNING: voltage read failed; cell data may be missing."));
  print_sep();
  print_report(info, vr, data32, d7);
  print_sep();
  // Detect cell imbalance — warn via orange blink after result
  bool imbalanced = false;
  if (vr.cells.valid && vr.cells.n > 1) {
    for (uint8_t i = 1; i < vr.cells.n; i++) {
    if ((vmax - vmin) >= IMBALANCE_THRESHOLD_V) {
      imbalanced = true;
      Serial.print(F("WARNING: Cell imbalance "));
      Serial.print(vmax - vmin, 3);
      Serial.println(F("V — check balancing tabs."));
  step_handle_lock(info, data32);
  print_sep();
  Serial.println(F("Complete."));
  // Set imbalance blink — orange over result colour
  g_imbalance = imbalanced;
  Colour rc = info.locked ? COL_RED : COL_GREEN;
  g_result_r = rc.r;
  g_result_g = rc.g;
  g_result_b = rc.b;
  bus_disable();
  return true;
// Core 1 handles the breathing pulse independently of Core 0's
// battery operations. Volatile flags are the only shared state.
void setup1() { /* nothing needed */
void loop1() {
  if (g_pulse_active) {
    led_pulse(g_pulse_scan_mode ? COL_WHITE : COL_RED);
    delay(LED_PULSE_INTERVAL_MS);
    return;
  if (g_imbalance) {
    // Orange blink every IMBALANCE_BLINK_INTERVAL_MS over the result colour
    delay(IMBALANCE_BLINK_INTERVAL_MS - IMBALANCE_BLINK_ON_MS);
    led_set(COL_ORANGE);
    delay(IMBALANCE_BLINK_ON_MS);
    led_set({ (uint8_t)g_result_r, (uint8_t)g_result_g, (uint8_t)g_result_b });
    return;
// ─── Hot-swap state machine ───────────────────────────────────
enum ScanState { WAIT_BATTERY,
                 SCAN_PENDING,
                 IDLE,
                 UNSUPPORTED };
static ScanState g_state = WAIT_BATTERY;
// ─── Arduino entry points ─────────────────────────────────────
  pinMode(PIN_ENABLE, OUTPUT);
  pinMode(PIN_MODE_OUT, OUTPUT);
  digitalWrite(PIN_MODE_OUT, HIGH);
  pinMode(PIN_MODE_IN1, INPUT_PULLDOWN);
#else
  digitalWrite(PIN_MODE_OUT, LOW);
  pinMode(PIN_MODE_IN1, INPUT_PULLUP);
#endif
  g_pixel.begin();
  g_pixel.setBrightness(LED_BRIGHTNESS_MAX);
  led_off();
  print_sep();
  Serial.print(F("  Firmware v"));
  Serial.println(F(FIRMWARE_VERSION));
  DeviceMode m = mode_read();
  switch (m) {
    case MODE_LOCK:
      Serial.println(F("  Makita OMEGA LOCK Utility - Types 0 / 2 / 3 only"));
      Serial.println(F("  GPIO2-GPIO3 bridged -> OMEGA LOCK MODE (nybble 34)"));
      Serial.println(F("  Remove bridge to switch to scan/unlock mode."));
    default:
      Serial.println(F("  Makita Monitor - Scan / Unlock Mode"));
      Serial.println(F("  's' = rescan | auto-detects connect/disconnect"));
      Serial.println(F("  Bridge GPIO2-GPIO3 for Omega lock."));
  print_sep();
  Serial.println(F("Waiting for battery..."));
  g_last_mode = m;
  wdt_begin();
  wdt_kick();
  uint32_t now = millis();
  DeviceMode cur_mode = g_last_mode;
  // Mode-change detection (debounced, 4x50 ms ~= 200 ms)
  if (now - g_last_mode_poll >= MODE_DEBOUNCE_MS) {
    g_last_mode_poll = now;
    DeviceMode raw = mode_read();
    if (raw == g_last_mode) {
    } else if (++g_mode_debounce >= MODE_DEBOUNCE_COUNT) {
      g_last_mode = raw;
      cur_mode = raw;
      if (g_state == IDLE || g_state == WAIT_BATTERY || g_state == UNSUPPORTED) {
        led_off();
        print_sep();
        switch (cur_mode) {
          case MODE_LOCK:
            Serial.println(F("  Mode changed -> OMEGA LOCK MODE"));
            Serial.println(F("  GPIO2-GPIO3 bridged. Insert battery to lock."));
          default:
            Serial.println(F("  Mode changed -> SCAN / UNLOCK MODE"));
            Serial.println(F("  Bridge removed. Insert battery to scan."));
        print_sep();
  // Serial command (scan mode only)
  if (cur_mode == MODE_SCAN && Serial.available()) {
    char c = (char)Serial.read();
    if ((c == 's' || c == 'S') && g_state != SCAN_PENDING) {
      Serial.println(F("Manual rescan requested."));
      g_state = SCAN_PENDING;
  // Presence poll
  if (now - g_last_poll >= POLL_INTERVAL_MS) {
    g_last_poll = now;
    bool present = battery_present();
    if (g_state == WAIT_BATTERY && present) {
      print_sep();
      if (cur_mode == MODE_LOCK) Serial.println(F("  [Lock] Battery detected - omega locking..."));
      else Serial.println(F("  Battery detected - starting scan."));
      print_sep();
    } else if ((g_state == IDLE || g_state == UNSUPPORTED) && !present) {
      print_sep();
      if (cur_mode == MODE_LOCK) Serial.println(F("  [Lock] Battery removed. Waiting for next..."));
      else Serial.println(F("  Battery removed. Waiting..."));
      print_sep();
      led_off();
  // LED pulse — driven by Core 1 via g_pulse_active flag.
  if (g_state == WAIT_BATTERY) {
    g_pulse_scan_mode = (cur_mode == MODE_SCAN);
    g_pulse_active = true;
  // Execute pending action
  if (g_state == SCAN_PENDING) {
    bool ok;
    if (cur_mode == MODE_LOCK) ok = run_lock();
    else ok = run_scan();
    g_state = ok ? IDLE : UNSUPPORTED;
    if (!ok) Serial.println(F("  Remove battery and try again."));
IDE shows a bunch of errors, but first is:
Compilation error: 'VoltageReadResult' does not name a type
If I shortening the sketch to minimum, error will change to "defined but not used".
I have tried Arduino IDE 2 - same error. I don't undertand why.
The problem is described here: (Arduino IDE tries help so much, that it destroys already good programs)
is the same as GeneralMessageFunction mentioned there - type declared before used in function, but Arduino IDE secretly generate function header using the type before type declaration.
Thanks. marked as solution.
I have tryed to add TFT output but Platformio unable to compile.
this was added:
#include <TFT.h>
#include <SPI.h>
#define cs 8
#define dc 10
#define rst 9
TFT TFTscreen = TFT(cs, dc, rst);
error:
HardwareSerial0.cpp.o (symbol from plugin): In function `Serial':
(.text+0x0): multiple definition of `__vector_18'
serial.c.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `__vector_19'
wiring.c.o (symbol from plugin): In function `__vector_16':
(.text+0x0): multiple definition of `__vector_16'
stepper.c.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
*** [.pio\build\nanoatmega328new\firmware.elf] Error 1
Maybe you able to clarify it too?
That should be another question, about Platformio (which I do not know),
but basically it says, that something defined the vectors 16, 18, 19 which are interrupts for something,
BUT also something other declared this vectors and now there is conflict.
Probably there is something using Serial too and chatGPT suggest, that Platformio have something called platformio.ini where is probably framework = arduino
and it loads standard libraries, while the
#include <TFT.h>
indirectly loads them too somehow. I do not know, how the Platformio works, as I do not have one. But sometimes chatGPT may lead to some results in cases like this, so you may try his suggestion "with a grain of salt" and see what happens (and report in the new question, if you won and how, so other can search it)
ChatGPT sugest to look for Serial and SPI (and UDRE interrupt)
