I noticed that in Arduino UNO, Leonardo, and so on, in the lines D +, D- of the USB connector, an assembly of 22 Ohm resistors array is used. Why are 2 resistors (number 1, 4) of array used, but 2 resistors (number 2, 3) of array are not used? Could the assembly of resistors array be replaced with two single resistors SMD 0402/0201 22 Ohm?
First, two separate resistors are lower-lower cost than a resistors array. Secondly, two separate resistors will take up the same space on the PCB. Thirdly, the Arduino UNO Wi-Fi uses 2 separate 22 ohm resistors. What will be the assumptions?
Maybe they found a huge quantity of surplus resistor arrays for cheap and the cost to pick and place one part instead of two added up to a cost savings that made sense for a large quantity of boards.
You should ask someone at Arduino since they are the only ones likely to know for sure.
Edit:
A quick check of Mouser shows that at 10,000 quantity, the resistor array is actually cheaper than two 22Ohm resistors.
We'll never really know. Design decisions have so many possible inputs it boggles the mind. Perhaps the assembler has other devices that use a ton of these arrays.
When looking a the cost of a single part ; I was told some time ago that the part costs less than the "installation". i.e. purchasing, inventory, handling etc.
