WHY the label is not on the middle of the button
# include <Adafruit_GFX.h>
//# include <Adafruit_TFTLCD.h>
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSans12pt7b.h>
#include <Fonts/FreeSerif12pt7b.h>
# include <Fonts/FreeSansBold24pt7b.h>
# include <MCUFRIEND_kbv.h>
# include <TouchScreen.h>
//#define LCD_CS A3     // Chip select/ CS goes to analog 3
//#define LCD_RS A2     // Same as CD/ Register selection goes to analog 2
//#define LCD_WR A1     // LCD write and read goes to analog 1
//#define LCD_RD A0     // LCD Read goes to Analog 0
//#define LCD_RESET A4  // Can alternately just connect to Arduino's reset pin
// Assign human-readable names to some common 16-bit colour values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
// make an array for those color
int tftColours[] = {BLUE, RED, GREEN, CYAN, MAGENTA, YELLOW, WHITE};
// If SD card is not used, Pins 2,3,4,5 are free
//Adafruit_TFTLCD tft(LCD_CS, LCD_RS, LCD_WR, LCD_RD, LCD_RESET);
MCUFRIEND_kbv tft;
// Set up the touch screen element of the TFT screen
#define YP A3  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 9   // can be a digital pin
#define XP 8   // can be a digital pin
#define SENSITIVITY 300
#define MINPRESSURE 10
#define MAXPRESSURE 2000
#define TS_MINX 169
#define TS_MAXX 984
#define TS_MINY 179
#define TS_MAXY 966
boolean Start_touch_detector = true;
boolean MODE_touch_detector = true;
String MODE;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, SENSITIVITY);
// Define button array object
Adafruit_GFX_Button start_botton;
Adafruit_GFX_Button MODE_A;
Adafruit_GFX_Button MODE_B;
Adafruit_GFX_Button CUSTOMIZED_MODE;
  Serial.println("TFT LCD TEST");
  Serial.print("TFT size is ");
  Serial.print(tft.width());
  Serial.print("x");
  Serial.println(tft.height());
  tft.reset();
  uint16_t identifier = tft.readID();
  Serial.print("The Chip ID is : ox");
  Serial.println(identifier, HEX);
  tft.begin(identifier);
  tft.setRotation(1);
  start_botton.initButton(&tft,360,280,100,70,WHITE,BLUE,WHITE,"START",2);
  MODE_A.initButton(&tft,100,160,100,70,WHITE,RED,WHITE,"A",1);
  MODE_B.initButton(&tft,380,160,100,70,WHITE,GREEN,WHITE,"B",1);
  CUSTOMIZED_MODE.initButton(&tft,240,230,160,90,WHITE,YELLOW,WHITE,"CUS",1);
  start_botton.drawButton();
  //tft.fillScreen(BLACK);
  tft.fillRect(0,55,480,80,WHITE);
  tft.setTextColor(BLUE);
  tft.setFont(&FreeSansBold24pt7b);
  tft.setTextSize(0);
  tft.setCursor(10, 100);
  tft.print("Select a mode!");
  waitOneTouch();
  //tft.reset();
  //uint16_t identifier = tft.readID();
  //tft.begin(identifier);
  MODE = Mode_Selection();
TSPoint waitOneTouch() {
	// Get a touch in the required button area (or anywhere if flag set)
	TSPoint p;
	do {
		p = ts.getPoint();
		pinMode(XM, OUTPUT);  // Pins configures again for TFT control
		pinMode(YP, OUTPUT);
    } while (p.z < MINPRESSURE || p.z > MAXPRESSURE);
    Serial.print("MAPPING p.x: ");
    Serial.println(map(p.x, TS_MINX, TS_MAXX, 0, tft.height()));
    Serial.print("MAPPING p.y: ");
    Serial.println(map(p.y, TS_MINX, TS_MAXX, 0, tft.width()));
    int y = tft.height()-map(p.x, TS_MINX, TS_MAXX, 0, tft.height());
    int x = tft.width()-map(p.y, TS_MINY, TS_MAXY, 0, tft.width());
    Serial.print("Transformed x: ");
    Serial.println(x);
    Serial.print("Transformed y: ");
    Serial.println(y);
  while(Start_touch_detector)
    TSPoint p = ts.getPoint();
    pinMode(XM,OUTPUT);
    pinMode(YP,OUTPUT);
    if(p.z > MINPRESSURE && p.z < MAXPRESSURE)
      //Serial.println("entering");
      Serial.println(start_botton.contains(x,y));
      if(start_botton.contains(x,y))
        Serial.println(x);
        Serial.println(y);
        Start_touch_detector = false;
String Mode_Selection()
  String MODE_selection;
  MODE_A.drawButton();
  MODE_B.drawButton();
  CUSTOMIZED_MODE.drawButton();
  while(MODE_touch_detector)
    pinMode(XM,OUTPUT);
    pinMode(YP,OUTPUT);
      if(MODE_A.contains(x,y))
        MODE_selection = "MODE_A";
        MODE_touch_detector = false;
      }else if(MODE_B.contains(x,y))
        MODE_selection = "MODE_B";
      }else if(CUSTOMIZED_MODE.contains(x,y))
        MODE_selection = "CUSTOMIZED_MODE";
      if(!MODE_touch_detector)
        for (int cnt=0; cnt< 20; cnt++)
		      tft.setCursor(140, 100);
		      tft.setTextColor(getRandomColour());
		      tft.setTextSize(1);
		      tft.print(MODE_selection);
          tft.println(" is ACTIVATED");
unsigned int getRandomColour() {
	static unsigned int prevColour = 99;
	int colour;
	do {
		colour = random(0, sizeof tftColours / 2);
		} while (colour == prevColour);
	prevColour = colour;
	return tftColours[colour];
I am confused about Why A,B, and CUS does not shown up in the middle of the button ? can anyone explain that for me ?
A likely guess is that the label position coordinates are not optimal. What happens when you change them? Or change the label itself by adding blanks, centering the characters?
but for the first button, everything is good, so I am not sure about what happen.
Take a look at the library code to see how the label position is calculated.
The labels are not all the same sizes.
Maybe Adafruit does centering and MCUFRIEND does not?
