Why won't this code work
type or paste code here
#include <Wire.h>
#include
#include <Servo.h>
#include <EEPROM.h>
#include
int Button = 10; //Push Button
const byte numRows = 4; //number of rows on the keypad
const byte numCols = 4; //number of columns on the keypad
char keymap[numRows][numCols] =
{ '1', '2', '3', 'A' },
{'4', '5', '6', 'B'),
{'7', '8', '9', 'C'),
{'*', '0', '#', 'D'}
char keypressed; //Where the keys are stored it changes very often
char code[] = { '1', '2', '3', '4' }; //The default code, you can change it or make it a 'n' dig
char checkl[sizeof(code)]; //Where the new key is stored
Welcome to the forum
Your topic has been moved to the Programming category of the forum
Please post a complete sketch, using code tags when you do, and describe the problems that you have with it
how do I do that
#include <Wire.h>
#include <Keypad.h>
#include <Servo.h>
#include <EEPROM.h>
#include <LiquidCrystal I2C.h>
In the second line of the code, it says #include <Keypad.h> and when I try to upload it it says Compilation error: Keypad.h: No such file or directory
#include <Wire.h>
#include <Keypad.h>
#include <Servo.h>
#include <EEPROM.h>
Please post the complete code as already requested.
that is the complete code
No setup() function, no loop() function; no, sorry, that is not a complete sketch. All you have is includes and declarations, no actual code.
It's incomplete. It wouldn't compile even without the library problem. No setup() function. No loop() function.
Have you installed the Keypad library and, if so, please post the full path to where it is located on your PC
ok Thanks
These lines should have closing braces, not closing parentheses.
If you open a new and empty *.ino-file
This file isn't completely empty there will be
Which is the absolutely real bare-minimum each and every Arduino-IDE-code must have.
And these lines are missing in the code that you have posted.
Take a look into this tutorial:
Arduino Programming Course
It is easy to understand and has a good mixture between explaining important concepts and example-codes to get you going. So give it a try and report your opinion about this tutorial.
@cammycam32112 - Follow this tutorial to get a good start with good code and good advice...
