Wiegand reader - Led - XPR
hello All,
I'm trying to set up the following wiegand RFID reader with Arduino.
The wiegand part is ok, can read RFID cards. I do have a problem with LEDs, which i want to control.
When trying the LED- to Ground on Arduino : led is on.
When connecting to a Digital Out pin :
  • PIN set to low : led is on
  • PIN set to high : led is kind of "partial on", like dimmed.
i tried with or whitout a resistor 220 ohms.
Can someone help on that?
Thanks a lot !
Make sure you have used the pin mode call in the setup function to make this pin an output.
Never connect an LED to an Arduino output pin without a resistor, you will exceed the maximum current you are permitted to draw from a pin.
That link tells nothing about the LEDs, how have you wired them up?
