wifi shield code help
this code uplaods with no errors but it still doesnt seem to work
#include <Adafruit_CC3000.h>
#include <SPI.h>
#include "utility/debug.h"
#include "utility/socket.h"
#include <Servo.h>
int led = 4;
Servo microservo;
int pos = 0;
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ   3  // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
                                         SPI_CLOCK_DIVIDER); // you can change this clock speed
#define WLAN_SSID       "Wentworth"   // cannot be longer than 32 characters!
#define WLAN_PASS       "dawsonliam"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
#define LISTEN_PORT           80      // What TCP port to listen on for connections.
                                      // The HTTP protocol uses port 80 by default.
#define MAX_ACTION            10      // Maximum length of the HTTP action that can be parsed.
#define MAX_PATH              64      // Maximum length of the HTTP request path that can be parsed.
                                      // There isn't much memory available so keep this short!
#define BUFFER_SIZE           MAX_ACTION + MAX_PATH + 20  // Size of buffer for incoming request data.
                                                          // Since only the first line is parsed this
                                                          // needs to be as large as the maximum action
                                                          // and path plus a little for whitespace and
                                                          // HTTP version.
#define TIMEOUT_MS            500    // Amount of time in milliseconds to wait for
                                     // an incoming request to finish.  Don't set this
                                     // too high or your server could be slow to respond.
Adafruit_CC3000_Server httpServer(LISTEN_PORT);
byte mac[] = { 0x08, 0x00, 0x28, 0x57, 0xA1, 0x54 };   //physical mac address
byte ip[] = { 192, 168, 0, 6 };                      // ip in lan (that's what you need to use in your browser. ("192.168.1.178")
byte gateway[] = { 192, 168, 0, 1 };                   // internet access via router
byte subnet[] = { 255, 255, 255, 0 };                  //subnet mas
String readString;
  pinMode(led, OUTPUT);
  microservo.attach(7);
  // start the connection and the server:
  httpServer.begin();
  // Try to get a client which is connected.
  Adafruit_CC3000_ClientRef client = httpServer.available();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
         //if HTTP request has ended
         if (c == '\n') {
           Serial.println(readString); //print to serial monitor for debuging
           client.println("HTTP/1.1 200 OK"); //send new page
           client.println("Content-Type: text/html");
           client.println();
           client.println("<HTML>");
           client.println("<HEAD>");
           client.println("<meta name='apple-mobile-web-app-capable' content='yes' />");
           client.println("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
           client.println("<link rel='stylesheet' type='text/css' href='http://randomnerdtutorials.com/ethernetcss.css' />");
           client.println("<TITLE>Random Nerd Tutorials Project</TITLE>");
           client.println("</HEAD>");
           client.println("<BODY>");
           client.println("<H1>Random Nerd Tutorials Project</H1>");
           client.println("<hr />");
           client.println("
           client.println("<H2>Arduino with Ethernet Shield</H2>");
           client.println("
           client.println("<a href=\"/?button1on\"\">Turn On LED</a>");
           client.println("<a href=\"/?button1off\"\">Turn Off LED</a>
           client.println("
           client.println("
           client.println("<a href=\"/?button2on\"\">Rotate Left</a>");
           client.println("<a href=\"/?button2off\"\">Rotate Right</a>
           client.println("<p>Created by Rui Santos. Visit http://randomnerdtutorials.com for more projects!</p>");
           client.println("
           client.println("</BODY>");
           client.println("</HTML>");
           delay(1);
           //stopping client
           client.stop();
           //controls the Arduino if you press the buttons
           if (readString.indexOf("?button1on") >0){
               digitalWrite(led, HIGH);
           if (readString.indexOf("?button1off") >0){
               digitalWrite(led, LOW);
           if (readString.indexOf("?button2on") >0){
                for(pos = 0; pos < 180; pos += 3)  // goes from 0 degrees to 180 degrees
                {                                  // in steps of 1 degree
                  microservo.write(pos);              // tell servo to go to position in variable 'pos'
                  delay(15);                       // waits 15ms for the servo to reach the position
           if (readString.indexOf("?button2off") >0){
                for(pos = 180; pos>=1; pos-=3)     // goes from 180 degrees to 0 degrees
            //clearing string for next read
            readString="";
it supposed to act as a server to controll the led and servo
i have the code for ethernet thats works but i tried to convert it to wifi this is the ethernet code
 Visit: http://randomnerdtutorials.com for more arduino projects
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
int led = 4;
Servo microservo;
int pos = 0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };   //physical mac address
byte ip[] = { 192, 168, 1, 178 };                      // ip in lan (that's what you need to use in your browser. ("192.168.1.178")
byte gateway[] = { 192, 168, 1, 1 };                   // internet access via router
byte subnet[] = { 255, 255, 255, 0 };                  //subnet mask
EthernetServer server(80);                             //server port
String readString;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // Create a client connection
  if (client) {
          readString += c;
          //Serial.print(c);
         if (c == '\n') {
           client.println();
           client.println("
           client.println("
           client.println("
           client.println("
           client.println("
           delay(1);
           //stopping client
           client.stop();
            readString="";
well if you put the ip address in the browser a webpage to control the led and servo is supposed to appear.... al though this code for the wifi shield uploads with no errors it simply does nothing even in serial monitor
Which Arduino are you running that code on? How much available memory do you have?
http://playground.arduino.cc/Code/AvailableMemory
Why are you not using the F() macro?
client.println(F("HTTP/1.1 200 OK")); //send new page
Why are you NOT printing anything to the serial port in setup()? Why are you NOT printing what you get from the client?
i suppose idk...? im a noobie i dont understand but the original code didnt have this as well
i suppose idk...?
You suppose that you don't know which Arduino you have? That'll be a problem.
oh no i have the arduino uno sorry i was saying im not sure about the rest lol
Did you read the link about available memory? Did you test how much you have?
Did you take the hint about using the F() macro? Did that change the amount of available memory? (Of course it did, or would have).
Was that enough?
i tried using the f macro that i beleave was correct example.
.....client.println(F("HTTP/1.1 200 OK"));....
but it said something about F not being declaired or something.....
this is the most working code i have so far.......
*  Simple robot control with Arduino & the CC3000 WiFi chip
// Include required libraries
#include <Servo.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
String readString;
String result;
int motorCommand[4];
int led = 4;
Servo microservo;
int pos = 0;
// Define CC3000 chip pins
// Motor pins
int speed_motor1 = 6;
int speed_motor2 = 5;
int direction_motor1 = 7;
int direction_motor2 = 4;
const unsigned long
  dhcpTimeout     = 60L * 1000L, // Max time to wait for address from DHCP
  connectTimeout  = 15L * 1000L, // Max time to wait for server connection
  responseTimeout = 15L * 1000L; // Max time to wait for data from server
uint32_t t;
int resultLength;
// WiFi network (change with your settings !)
#define WLAN_SECURITY   WLAN_SEC_WPA2 // This can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
// Create CC3000 instances
                                         SPI_CLOCK_DIV2);
// Create server
Adafruit_CC3000_Server robotServer(LISTEN_PORT);
  result = "";
  for(int i=4;i<=7;i++)
    pinMode(i, OUTPUT);  //set pin 4,5,6,7 to output mode
  /* Initialise the module */
  Serial.println(F("\nInitializing..."));
  if (!cc3000.begin())
    Serial.println(F("Couldn't begin()! Check your wiring?"));
    while(1);
  if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    Serial.println(F("Failed!"));
    while(1);
  Serial.println(F("Connected!"));
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP())
    delay(100); // ToDo: Insert a DHCP timeout!
  // Start listening for connections
  robotServer.begin();
  Serial.println(F("Listening for connections..."));
  Adafruit_CC3000_ClientRef client = robotServer.available();
  if (client) {
     boolean currentLineIsBlank = true;
     // Check if there is data available to read.
     while (client.available()) {
       result = result + c;
       Serial.write(c);
       // Delete HTTP headers
      if(result.endsWith("Content-Type: text/html"))
        result="";
       if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Connection: close");
          client.println();
         if (c == '\n') {
           client.println();
           client.println("
           client.println("
           client.println("
           client.println("
           client.println("
           delay(1);
           //stopping client
           client.stop();
            readString="";
and i says im using 92% of th ememory
Global variables use 1,885 bytes (92%) of dynamic memory, leaving 163 bytes for local variables. Maximum is 2,048 bytes.
That's nowhere near enough.
I'm 100% certain that the compiler stated EXACTLY what was wrong, and the line on which the problem occurred.
i beleave t should look like this..
#include <Servo.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
String readString;
String result;
int led = 4;
Servo microservo;
int pos = 0;
// Motor pins
const unsigned long
uint32_t t;
int resultLength;
                                         SPI_CLOCK_DIV2);
// Create server
  result = "";
    while(1);
    while(1);
  if (client) {
       Serial.write(c);
        result="";
          client.println();
         if (c == '\n') {
           client.println(F("Content-Type: text/html"));
           client.println();
           client.println(F("<HTML>"));
           client.println(F("<HEAD>"));
           client.println(F("<meta name='apple-mobile-web-app-capable' content='yes' />"));
           client.println(F("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />"));
           client.println(F("<link rel='stylesheet' type='text/css' href='http://randomnerdtutorials.com/ethernetcss.css' />"));
           client.println(F("<TITLE>Random Nerd Tutorials Project</TITLE>"));
           client.println(F("</HEAD>"));
           client.println(F("<BODY>"));
           client.println(F("<H1>Random Nerd Tutorials Project</H1>"));
           client.println(F("<hr />"));
           client.println(F("
           client.println(F("<H2>Arduino with Ethernet Shield</H2>"));
           client.println(F("
           client.println(F("<a href=\"/?button1on\"\">Turn On LED</a>"));
           client.println(F("<a href=\"/?button1off\"\">Turn Off LED</a>
           client.println(F("
           client.println(F("
           client.println(F("<a href=\"/?button2on\"\">Rotate Left</a>"));
           client.println(F("<a href=\"/?button2off\"\">Rotate Right</a>
           client.println(F("<p>Created by Rui Santos. Visit http://randomnerdtutorials.com for more projects!</p>"));
           client.println(F("
           client.println(F("</BODY>"));
           client.println(F("</HTML>"));
           delay(1);
           //stopping client
           client.stop();
            readString="";
I don't think I've seen a successful server setup using the wifi shields.
this code is working although it seems to keep re initializing if you would like to try it
#include <Servo.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
String readString;
String result;
int led = 4;
Servo microservo;
int pos = 0;
// Motor pins
const unsigned long
uint32_t t;
int resultLength;
                                         SPI_CLOCK_DIV2);
// Create server
  result = "";
    while(1);
    while(1);
  if (client) {
       Serial.write(c);
        result="";
          client.println(F("Connection: close"));
          client.println();
         if (c == '\n') {
           client.println();
           client.println(F("
           client.println(F("
           client.println(F("
           client.println(F("
           client.println(F("
           delay(1);
           //stopping client
           client.stop();
            readString="";
