I have the arduino wifi shield and I was trying the example code from here(the WifiWebServer example in the IDE):http://arduino.cc/en/Tutorial/WiFiWebServer. But when I run it, it connects to the network but then when I try to connect to it from a browser, firefox says:
Unable to connect
Firefox can't establish a connection to the server at 192.168.1.46.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer's network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
Here is all that the arduino puts out on the serial monitor:
Attempting to connect to SSID: *****
SSID: *****
IP Address: 192.168.1.46
signal strength (RSSI):-55 dBm
Any ideas? All help is appreciated.
Thanks in advance,
Luketheduke
Have you upgraded the wifi shield firmware? Here is a way to check it.
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while(true);
Serial.print("Firmware version: ");
Serial.println(WiFi.firmwareVersion());
It should report 1.1.0 if upgraded, and 1.0.0 if not.
It says 1.0.0 I am trying to upgrade it now....
It outputted when I executed this command in command prompt(windows 7) from http://arduino.cc/en/Hacking/WiFiShieldFirmwareUpgrading Parsing ELF File ...... can't open input file "file location(shortened)\wifi_dnld.elf Any ideas? It seems like it has already erased the device so I guess I just crossed the Rubicon...
I got the same message. You should still be ok.
I moved both those files to my root directory instead of that long path. It worked from there.
I followed Ludgy's guide and it worked first try. Wifi shield pinging but not serving page - Networking, Protocols, and Devices - Arduino Forum Thanks for all your help SurferTim!
Thanks,
Luketheduke
