WiFi Shield
Hi ,
My WiFi shield is not working when I am using the code given in arduino guide following link
It is showing zero network scanned even when i have opened 3 hotspot networks around
please give me solution asap.
thanks
khushboo katta
Which WiFi shield do you have? You can post a link to where you bought it from if you got it online.
I have wifi shield R3
i have purchased from this link.
http://www.amazon.in/Arduino-Italy-ARD-A000058-Wifi-Shield/dp/B00CIP42IQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1472458919&sr=1-1&keywords=arduino+uno+wifi+shield
when i connect shield with arduino board .. then yellow light doesn't blink and it shows WiFi shield not present.
please tell an appropriate solution to it asap
I wanted to check if the shield you're using is compatible with the Arduino WiFi library and it looks like you are using the correct library.
i have tried with WiFi shield 101 library as well .. it still not working , according to you what could be the possible reasons ?
or is it that shield is not working or default in the shield???
