WifiManager error with Arduino UNO R4 WiFi
Hello, I have tried the basic code for the ibrary WiFI Manager, but I get the error: Compilation error: 'WiFiManager' was not declared in this scope
It's the basic code so it should work, here is the code
#include <WiFiManager.h> // https://github.com/tzapu/WiFiManager
    // WiFi.mode(WIFI_STA); // explicitly set mode, esp defaults to STA+AP
    // it is a good practice to make sure your code sets wifi mode how you want it.
    //WiFiManager, Local intialization. Once its business is done, there is no need to keep it around
    WiFiManager wm;
    // reset settings - wipe stored credentials for testing
    // these are stored by the esp library
    // wm.resetSettings();
    // Automatically connect using saved credentials,
    // if connection fails, it starts an access point with the specified name ( "AutoConnectAP"),
    // if empty will auto generate SSID, if password is blank it will be anonymous AP (wm.autoConnect())
    // then goes into a blocking loop awaiting configuration and will return success result
    bool res;
    // res = wm.autoConnect(); // auto generated AP name from chipid
     res = wm.autoConnect("AutoConnectAP"); // anonymous ap
    //res = wm.autoConnect("AutoConnectAP","password"); // password protected ap
    if(!res) {
        Serial.println("Failed to connect");
        // ESP.restart();
    else {
        //if you get here you have connected to the WiFi
        Serial.println("connected...yeey :)");
Uno R4 WiFi is not supported by that library
Do you know if there's any similar library that can be used instead of this one so I can request the wifi credentials? Thanks
I think the Arduino IoT Cloud supports WiFi provisioning
