I am trying to connect an Arduino UNO R4 WiFi to wifi and I am trying to use the example ScanNetworks scripts to see what wifi networks the Arduino can connect to. However, when I run the example, without changing anything, it breaks and throws the following error.
C:\Users\Omnibis\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp: In static member function 'static void SpiDrv::begin()':
C:\Users\Omnibis\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:103:15: error: 'NINA_GPIO0' was not declared in this scope
pinMode(NINA_GPIO0, OUTPUT);
C:\Users\Omnibis\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:103:15: note: suggested alternative: 'NINA_GPIOIRQ'
NINA_GPIOIRQ
C:\Users\Omnibis\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp: In static member function 'static int SpiDrv::available()':
C:\Users\Omnibis\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:66:25: error: 'NINA_GPIO0' was not declared in this scope
#define NINA_GPIOIRQ NINA_GPIO0
C:\Users\Omnibis\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:597:25: note: in expansion of macro 'NINA_GPIOIRQ'
return (digitalRead(NINA_GPIOIRQ) != LOW);
C:\Users\Omnibis\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:66:25: note: suggested alternative: 'NINA_GPIOIRQ'
^~~~~~~~~~~~exit status 1
Compilation error: exit status 1
Is there anything I am doing wrong? I have tried to run this script with an assortment of devices/computers, but it always breaks in the same way.
