Win 11 vs Win 10 IDE
I upload a Sketch to my target Arduino MKR-Zero based hardware, and it shows 86,624 bytes in my IDE 2.3.6 on my Windows 10 pc. The Sketch works fine in my MKR-Zero. But when I upload the same Sketch with the same libraries to the same target hardware from my Windows 11 pc with the same IDE version 2.3.6, it shows 97,792 bytes, and the Sketch fails to perform properly on my target box. I know you like to have the source code, but it's pretty big, and I just want to know if anyone can shed light on this apparent difference between Windows 10 and Windows 11. Thanks.
Although you say that you are using the same libraries are they the same version ? The same goes for the board files
Hi UKHeliBob, Yes, I tried very hard to get exactly the same version of each library file, and I verified it by closely examining the output of each compile. Good question because the version can certainly make a big difference! As for the board files, I'm not sure what you mean. Would those be the MKR-Zero board selection? Both compilations specify the MKR-Zero as the target board, but perhaps you can give me some insight as to where there might be some differences. Thanks!
In the IDE, if you open the Boards Manager in the left-hand panel and enter mkr-zero in the search box then you will see this
Check the version number on both machines. They are very likely the same but it is worth checking
Hi UKHeliBob, Many thanks for the incredibly fast responses! Per your suggestion, I checked the Board version in each IDE, and they are both 1.8.14.
I wonder if anyone out there has both a Windows 10 and a Windows 11 pc with the IDE installed and could compile one of their own Sketches on each and report the number of bytes used?
The OS version is a step or two removed from what would affect the build size. How about posting the full verbose compiler Output for each build? (At least there's an easy Copy All in the right-click menu.)
Be sure to post each separately as <CODE/> -- they are crazy long and wide. You can post them in separate messages; or if you want to be fancy, start a reply on one machine, close it and choose "Save draft for later", then on the other machine click My Posts (under Topics in the top left here) and complete the post.
The logs will contain your username, so if you want to redact that, do a search&replace in Notepad or whatever you have handy.
Hi kenb4,
Good idea, thanks! I have done a "diff" on the two outputs, but I don't understand the differences so an expert look at them would be a big plus. I have the Windows 10 IDE compiler output in a .txt file, so now I need to capture the output for the Windows 11. It may take just a bit more time.
Now it's getting even more strange. I now get a compiler error when trying to compile the Sketch on Windows 11, the same Sketch that compiles fine and uploads successfully on Windows 10. On the Windows 11 machine, the IDE says, "Compilation error: redefinition of 'TinyGPSPlus tinyGPS'
Stay tuned, I'll do some more troubleshooting including re-installing the IDE and the libraries...
OK, I deleted and re-installed the TinyGPSPlus library, and the compilation succeeds again (on both Windows 10 and Windows 11), but the Windows 11 takes 97,896 bytes while the Windows 10 takes 86,504 bytes. Now I'll try to upload the Sketch from the Windows 11 Arduino IDE, the process that worked but led to funky performance on the target MKR-Zero.
Nope, I'm back to where it no longer compiles on my Windows 11 machine. Same Sketch, same libraries, same version of IDE - compiles on my Windows 10 machine, fails on Windows 11 with this error:
exit status 1
Sorry, I now have a Sketch that compiles with no errors and uploads successfully from my Windows 11 machine as well as my Windows 10 machine. And now both are working on the target MKR-Zero-based hardware. But there's still the mystery of why the Windows 10 compile is 12% smaller than the Windows 11 compile. Sorry to drag you guys through all my mistakes and misdirections.
Well, the latest in this confusing saga: The Sketch that I upload from my Windows 11 machine does not run properly on the target MKR-Zero-based hardware but the same Sketch with the same libraries and the same version of the IDE runs fine when uploaded to that same hardware from my Windows 10 machine. Ideas?
FQBN: arduino:samd:mkrzero
Using board 'mkrzero' from platform in folder: C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14
Using core 'arduino' from platform in folder: C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14
Detecting libraries used...
C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Og -g3 -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\sketch\silkripRev4533_25017.ino.cpp -o nul
Alternatives for Adafruit_GPS.h: [Adafruit GPS Library@1.7.5]
ResolveLibrary(Adafruit_GPS.h)
  -> candidates: [Adafruit GPS Library@1.7.5]
C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Og -g3 -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -Ic:\Documents\Arduino\libraries\Adafruit_GPS_Library\src C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\sketch\silkripRev4533_25017.ino.cpp -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Og -g3 -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -Ic:\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\sketch\silkripRev4533_25017.ino.cpp -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Og -g3 -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -Ic:\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\sketch\silkripRev4533_25017.ino.cpp -o nul
Alternatives for NoiascaLedControl.h: [NoiascaLedControl@1.2.5]
ResolveLibrary(NoiascaLedControl.h)
  -> candidates: [NoiascaLedControl@1.2.5]
C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Og -g3 -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -Ic:\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire -Ic:\Documents\Arduino\libraries\NoiascaLedControl\src C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\sketch\silkripRev4533_25017.ino.cpp -o nul
Alternatives for SD.h: [SD@1.3.0]
ResolveLibrary(SD.h)
  -> candidates: [SD@1.3.0]
C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Og -g3 -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -Ic:\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire -Ic:\Documents\Arduino\libraries\NoiascaLedControl\src -Ic:\Documents\Arduino\libraries\SD\src C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\sketch\silkripRev4533_25017.ino.cpp -o nul
Alternatives for Timer5.h: [Timer5@1.0.0]
ResolveLibrary(Timer5.h)
  -> candidates: [Timer5@1.0.0]
C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Og -g3 -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -Ic:\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire -Ic:\Documents\Arduino\libraries\NoiascaLedControl\src -Ic:\Documents\Arduino\libraries\SD\src -Ic:\Documents\Arduino\libraries\Timer5\src C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\sketch\silkripRev4533_25017.ino.cpp -o nul
Alternatives for TinyGPS++.h: [TinyGPS++@1.0.2]
ResolveLibrary(TinyGPS++.h)
  -> candidates: [TinyGPS++@1.0.2]
C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Og -g3 -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -Ic:\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire -Ic:\Documents\Arduino\libraries\NoiascaLedControl\src -Ic:\Documents\Arduino\libraries\SD\src -Ic:\Documents\Arduino\libraries\Timer5\src -Ic:\Documents\Arduino\libraries\TinyGPS__\src C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\sketch\silkripRev4533_25017.ino.cpp -o nul
Using cached library dependencies for file: c:\Documents\Arduino\libraries\Adafruit_GPS_Library\src\Adafruit_GPS.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\Adafruit_GPS_Library\src\NMEA_build.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\Adafruit_GPS_Library\src\NMEA_data.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\Adafruit_GPS_Library\src\NMEA_parse.cpp
Using cached library dependencies for file: C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI\SPI.cpp
Using cached library dependencies for file: C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire\Wire.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\NoiascaLedControl\src\NoiascaLedControl.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\NoiascaLedControl\src\NoiascaLedControlCommon.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\NoiascaLedControl\src\NoiascaLedControlSpi.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\SD\src\File.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\SD\src\SD.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\SD\src\utility\Sd2Card.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\SD\src\utility\SdFile.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\SD\src\utility\SdVolume.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\Timer5\src\Timer5.cpp
Using cached library dependencies for file: c:\Documents\Arduino\libraries\TinyGPS__\src\TinyGPS++.cpp
Generating function prototypes...
C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Og -g3 -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -Ic:\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI -IC:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire -Ic:\Documents\Arduino\libraries\NoiascaLedControl\src -Ic:\Documents\Arduino\libraries\SD\src -Ic:\Documents\Arduino\libraries\Timer5\src -Ic:\Documents\Arduino\libraries\TinyGPS__\src C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\sketch\silkripRev4533_25017.ino.cpp -o C:\Users\tomki\AppData\Local\Temp\3914382887\sketch_merged.cpp
C:\Users\tomki\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\tomki\AppData\Local\Temp\3914382887\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Og -g3 -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKRZero\"" "-IC:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\cores\\arduino/api/deprecated" "-IC:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\cores\\arduino" "-IC:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\variants\\mkrzero" "-Ic:\\Documents\\Arduino\\libraries\\Adafruit_GPS_Library\\src" "-IC:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\libraries\\SPI" "-IC:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\libraries\\Wire" "-Ic:\\Documents\\Arduino\\libraries\\NoiascaLedControl\\src" "-Ic:\\Documents\\Arduino\\libraries\\SD\\src" "-Ic:\\Documents\\Arduino\\libraries\\Timer5\\src" "-Ic:\\Documents\\Arduino\\libraries\\TinyGPS__\\src" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\sketch\\silkripRev4533_25017.ino.cpp" -o "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\sketch\\silkripRev4533_25017.ino.cpp.o"
Compiling libraries...
Compiling library "Adafruit GPS Library"
C:\Documents\Arduino\silkripRev4533_25017\silkripRev4533_25017.ino: In function 'void setup()':
C:\Documents\Arduino\silkripRev4533_25017\silkripRev4533_25017.ino:387:55: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
           n = readField(&file, str, sizeof(str), ",\n");
C:\Documents\Arduino\silkripRev4533_25017\silkripRev4533_25017.ino:464:52: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
           n = readFld(&err, str, sizeof(str), ",\n");
C:\Documents\Arduino\silkripRev4533_25017\silkripRev4533_25017.ino:520:51: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
           n = readFld(&ts, str, sizeof(str), ",\n");
C:\Documents\Arduino\silkripRev4533_25017\silkripRev4533_25017.ino:571:52: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
           n = readFld(&ant, str, sizeof(str), ",\n");
C:\Documents\Arduino\silkripRev4533_25017\silkripRev4533_25017.ino:623:52: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
           n = readFld(&sim, str, sizeof(str), ",\n");
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\Adafruit_GPS_Library\Adafruit_GPS.cpp.o
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\Adafruit_GPS_Library\NMEA_build.cpp.o
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\Adafruit_GPS_Library\NMEA_data.cpp.o
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\Adafruit_GPS_Library\NMEA_parse.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\SPI\SPI.cpp.o
Compiling library "Wire"
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\Wire\Wire.cpp.o
Compiling library "NoiascaLedControl"
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\NoiascaLedControl\NoiascaLedControl.cpp.o
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\NoiascaLedControl\NoiascaLedControlSpi.cpp.o
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\NoiascaLedControl\NoiascaLedControlCommon.cpp.o
Compiling library "SD"
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\SD\File.cpp.o
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\SD\SD.cpp.o
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\SD\utility\SdFile.cpp.o
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\SD\utility\SdVolume.cpp.o
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\SD\utility\Sd2Card.cpp.o
Compiling library "Timer5"
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\Timer5\Timer5.cpp.o
Compiling library "TinyGPS++"
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\libraries\TinyGPS__\TinyGPS++.cpp.o
Compiling core...
Using previously compiled file: C:\Users\tomki\AppData\Local\arduino\sketches\74B2B0C5F930F6E03851C342684782C8\core\variant.cpp.o
Using precompiled core: C:\Users\tomki\AppData\Local\arduino\cores\arduino_samd_mkrzero_1b9819c31119d02fa08d393705adfed8\core.a
Linking everything together...
"C:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" "-LC:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8" -Og -g3 -Wl,--gc-sections -save-temps "-TC:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\variants\\mkrzero/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8/silkripRev4533_25017.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8/silkripRev4533_25017.ino.elf" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\sketch\\silkripRev4533_25017.ino.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\Adafruit_GPS_Library\\Adafruit_GPS.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\Adafruit_GPS_Library\\NMEA_build.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\Adafruit_GPS_Library\\NMEA_data.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\Adafruit_GPS_Library\\NMEA_parse.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\NoiascaLedControl\\NoiascaLedControl.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\NoiascaLedControl\\NoiascaLedControlCommon.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\NoiascaLedControl\\NoiascaLedControlSpi.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\SD\\File.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\SD\\SD.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\SD\\utility\\Sd2Card.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\SD\\utility\\SdFile.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\SD\\utility\\SdVolume.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\Timer5\\Timer5.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\libraries\\TinyGPS__\\TinyGPS++.cpp.o" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8/..\\..\\cores\\arduino_samd_mkrzero_1b9819c31119d02fa08d393705adfed8\\core.a" -Wl,--end-group
"C:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8/silkripRev4533_25017.ino.elf" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8/silkripRev4533_25017.ino.bin"
"C:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8/silkripRev4533_25017.ino.elf" "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8/silkripRev4533_25017.ino.hex"
Using library Adafruit GPS Library at version 1.7.5 in folder: C:\Documents\Arduino\libraries\Adafruit_GPS_Library
Using library SPI at version 1.0 in folder: C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Users\tomki\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire
Using library NoiascaLedControl at version 1.2.5 in folder: C:\Documents\Arduino\libraries\NoiascaLedControl
Using library SD at version 1.3.0 in folder: C:\Documents\Arduino\libraries\SD
Using library Timer5 at version 1.0.0 in folder: C:\Documents\Arduino\libraries\Timer5
Using library TinyGPS++ at version 1.0.2 in folder: C:\Documents\Arduino\libraries\TinyGPS__
"C:\\Users\\tomki\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\tomki\\AppData\\Local\\arduino\\sketches\\74B2B0C5F930F6E03851C342684782C8/silkripRev4533_25017.ino.elf"
Sketch uses 97896 bytes (37%) of program storage space. Maximum is 262144 bytes.
Global variables use 9648 bytes (29%) of dynamic memory, leaving 23120 bytes for local variables
Compiling sketch...
Compiling core...
Those two logs look identical, down to the temp directory that contains the merged-.ino file
which usually varies with each compile. Are you sure you pasted the right one(s)?
Yes, you're right, I screwed up and posted the Windows 11 compilation twice. I'll now post the Windows 10 compilation output in which you can see the difference in the number of bytes. Apologies and thanks for catching my dumb mistake.
Using board 'mkrzero' from platform in folder: C:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14
Using core 'arduino' from platform in folder: C:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14
C:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\sketch\MarkIVRev4533_250517.ino.cpp -o nul
C:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -IC:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library\src C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\sketch\MarkIVRev4533_250517.ino.cpp -o nul
C:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -IC:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\sketch\MarkIVRev4533_250517.ino.cpp -o nul
C:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -IC:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\sketch\MarkIVRev4533_250517.ino.cpp -o nul
Alternatives for NoiascaLedControl.h: [NoiascaLedControl@1.2.1]
  -> candidates: [NoiascaLedControl@1.2.1]
C:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -IC:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire -IC:\Users\info\Documents\Arduino\libraries\NoiascaLedControl\src C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\sketch\MarkIVRev4533_250517.ino.cpp -o nul
Alternatives for SD.h: [SD@1.2.4 SD@1.3.0]
  -> candidates: [SD@1.2.4 SD@1.3.0]
C:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -IC:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire -IC:\Users\info\Documents\Arduino\libraries\NoiascaLedControl\src -IC:\Users\info\Documents\Arduino\libraries\SD\src C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\sketch\MarkIVRev4533_250517.ino.cpp -o nul
C:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -IC:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire -IC:\Users\info\Documents\Arduino\libraries\NoiascaLedControl\src -IC:\Users\info\Documents\Arduino\libraries\SD\src -IC:\Users\info\Documents\Arduino\libraries\Timer5-master\src C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\sketch\MarkIVRev4533_250517.ino.cpp -o nul
C:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -IC:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire -IC:\Users\info\Documents\Arduino\libraries\NoiascaLedControl\src -IC:\Users\info\Documents\Arduino\libraries\SD\src -IC:\Users\info\Documents\Arduino\libraries\Timer5-master\src -IC:\Users\info\Documents\Arduino\libraries\TinyGPSPlus-1.0.2b\src C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\sketch\MarkIVRev4533_250517.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library\src\Adafruit_GPS.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library\src\NMEA_build.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library\src\NMEA_data.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library\src\NMEA_parse.cpp
Using cached library dependencies for file: C:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI\SPI.cpp
Using cached library dependencies for file: C:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire\Wire.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\NoiascaLedControl\src\NoiascaLedControl.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\NoiascaLedControl\src\NoiascaLedControlCommon.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\NoiascaLedControl\src\NoiascaLedControlSpi.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\SD\src\File.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\SD\src\SD.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\SD\src\utility\Sd2Card.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\SD\src\utility\SdFile.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\SD\src\utility\SdVolume.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\Timer5-master\src\Timer5.cpp
Using cached library dependencies for file: C:\Users\info\Documents\Arduino\libraries\TinyGPSPlus-1.0.2b\src\TinyGPS++.cpp
C:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON -DUSB_MANUFACTURER="Arduino LLC" -DUSB_PRODUCT="Arduino MKRZero" -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/ -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino/api/deprecated-avr-comp -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\cores\arduino -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\variants\mkrzero -IC:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library\src -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI -IC:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire -IC:\Users\info\Documents\Arduino\libraries\NoiascaLedControl\src -IC:\Users\info\Documents\Arduino\libraries\SD\src -IC:\Users\info\Documents\Arduino\libraries\Timer5-master\src -IC:\Users\info\Documents\Arduino\libraries\TinyGPSPlus-1.0.2b\src C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\sketch\MarkIVRev4533_250517.ino.cpp -o C:\Users\info\AppData\Local\Temp\1664974454\sketch_merged.cpp
C:\Users\info\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\info\AppData\Local\Temp\1664974454\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKRZero\"" "-IC:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\cores\\arduino/api/deprecated" "-IC:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\cores\\arduino" "-IC:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\variants\\mkrzero" "-IC:\\Users\\info\\Documents\\Arduino\\libraries\\Adafruit_GPS_Library\\src" "-IC:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\libraries\\SPI" "-IC:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\libraries\\Wire" "-IC:\\Users\\info\\Documents\\Arduino\\libraries\\NoiascaLedControl\\src" "-IC:\\Users\\info\\Documents\\Arduino\\libraries\\SD\\src" "-IC:\\Users\\info\\Documents\\Arduino\\libraries\\Timer5-master\\src" "-IC:\\Users\\info\\Documents\\Arduino\\libraries\\TinyGPSPlus-1.0.2b\\src" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\sketch\\MarkIVRev4533_250517.ino.cpp" -o "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\sketch\\MarkIVRev4533_250517.ino.cpp.o"
C:\Users\info\Documents\Arduino\MarkIVRev4533_250517\MarkIVRev4533_250517.ino: In function 'void setup()':
C:\Users\info\Documents\Arduino\MarkIVRev4533_250517\MarkIVRev4533_250517.ino:387:55: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\info\Documents\Arduino\MarkIVRev4533_250517\MarkIVRev4533_250517.ino:464:52: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\info\Documents\Arduino\MarkIVRev4533_250517\MarkIVRev4533_250517.ino:520:51: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\info\Documents\Arduino\MarkIVRev4533_250517\MarkIVRev4533_250517.ino:571:52: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\info\Documents\Arduino\MarkIVRev4533_250517\MarkIVRev4533_250517.ino:623:52: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\Adafruit_GPS_Library\NMEA_build.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\Adafruit_GPS_Library\Adafruit_GPS.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\Adafruit_GPS_Library\NMEA_parse.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\Adafruit_GPS_Library\NMEA_data.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\SPI\SPI.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\NoiascaLedControl\NoiascaLedControl.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\NoiascaLedControl\NoiascaLedControlSpi.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\NoiascaLedControl\NoiascaLedControlCommon.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\SD\utility\Sd2Card.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\SD\SD.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\SD\utility\SdFile.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\SD\File.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\SD\utility\SdVolume.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\Timer5-master\Timer5.cpp.o
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\libraries\TinyGPSPlus-1.0.2b\TinyGPS++.cpp.o
Compiling core...
Using previously compiled file: C:\Users\info\AppData\Local\arduino\sketches\077DD561C2F44B54442177DC62DC099D\core\variant.cpp.o
Using precompiled core: C:\Users\info\AppData\Local\arduino\cores\arduino_samd_mkrzero_5e098a42bd1cdf041bf5c0fd40292682\core.a
"C:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" "-LC:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.14\\variants\\mkrzero/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D/MarkIVRev4533_250517.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D/MarkIVRev4533_250517.ino.elf" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\sketch\\MarkIVRev4533_250517.ino.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\Adafruit_GPS_Library\\Adafruit_GPS.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\Adafruit_GPS_Library\\NMEA_build.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\Adafruit_GPS_Library\\NMEA_data.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\Adafruit_GPS_Library\\NMEA_parse.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\NoiascaLedControl\\NoiascaLedControl.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\NoiascaLedControl\\NoiascaLedControlCommon.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\NoiascaLedControl\\NoiascaLedControlSpi.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\SD\\File.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\SD\\SD.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\SD\\utility\\Sd2Card.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\SD\\utility\\SdFile.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\SD\\utility\\SdVolume.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\Timer5-master\\Timer5.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\libraries\\TinyGPSPlus-1.0.2b\\TinyGPS++.cpp.o" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D/..\\..\\cores\\arduino_samd_mkrzero_5e098a42bd1cdf041bf5c0fd40292682\\core.a" -Wl,--end-group
"C:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D/MarkIVRev4533_250517.ino.elf" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D/MarkIVRev4533_250517.ino.bin"
"C:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D/MarkIVRev4533_250517.ino.elf" "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D/MarkIVRev4533_250517.ino.hex"
Multiple libraries were found for "SD.h"
  Used: C:\Users\info\Documents\Arduino\libraries\SD
  Not used: C:\Users\info\AppData\Local\Arduino15\libraries\SD
Using library Adafruit GPS Library at version 1.7.5 in folder: C:\Users\info\Documents\Arduino\libraries\Adafruit_GPS_Library
Using library SPI at version 1.0 in folder: C:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Users\info\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.14\libraries\Wire
Using library NoiascaLedControl at version 1.2.1 in folder: C:\Users\info\Documents\Arduino\libraries\NoiascaLedControl
Using library SD at version 1.3.0 in folder: C:\Users\info\Documents\Arduino\libraries\SD
Using library Timer5 at version 1.0.0 in folder: C:\Users\info\Documents\Arduino\libraries\Timer5-master
Using library TinyGPS++ at version 1.0.2 in folder: C:\Users\info\Documents\Arduino\libraries\TinyGPSPlus-1.0.2b
"C:\\Users\\info\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\info\\AppData\\Local\\arduino\\sketches\\077DD561C2F44B54442177DC62DC099D/MarkIVRev4533_250517.ino.elf"
Sketch uses 86504 bytes (32%) of program storage space. Maximum is 262144 bytes.
Global variables use 9548 bytes (29%) of dynamic memory, leaving 23220 bytes for local variables. Maximum is 32768 bytes.
One difference I can see.
WIN11
Win10
Good catch, I'll try to rationalize those by changing the Windows 11 library to the older version. Thanks!
Must try harder !
