Hi Guys,
I am trying to get wind direction from a Wind Vane from the Rainwise MK-III Weather Station in Arduino Uno. The wind vane is based on reed switch.
After figuring what all the 8 pin does what I got the following:
Pin 7 and 8 - Anenometer
Pin 1 to 7 - Wind Vane
Rotating the Wind Vane and doing continuity test using my multi meter I got the following Data (Also see image for table):
Pin 6 Pin 7 Pin 1 Pin 2 Pin 3 Pin 4 Direction
0 1 1 0 0 0 N
0 1 0 1 0 0 NNE
0 1 0 0 1 0 NE
0 1 0 0 0 1 ENE
1 0 1 0 0 0 E
1 0 0 1 0 0 ESE
1 0 0 0 1 0 SE
1 0 0 0 0 1 SSE
1 1 1 0 0 0 S
1 1 0 1 0 0 SSW
1 1 0 0 1 0 SW
1 1 0 0 0 1 WSW
1 1 1 1 0 0 W
1 1 0 1 1 0 WNW
1 1 0 0 1 1 NW
1 1 1 0 0 1 NNW
For getting N,NNE,NE and ENE i figured that I had to make Pin 5 LOW and Pin 6 HIGH and scan on pin 1,2,3 and 4 to see which is gives HIGH. And same for E to SSE. However I am very confused and apprently stuck when both Pin 6 and Pin 7 are HIGH.
I am only able to get 8 directions so far. Can you please help me figure out how I can solve this or an example code similar to my problem.
I am new with arduino, however here is what i have written so far:
#define pin1 10 //O
#define pin2 9 //OW
#define pin3 11 //BNW
#define pin4 12 //B
#define pin6 6 //BLW
#define pin7 7 //G
pinMode(pin1, INPUT);
pinMode(pin2, INPUT);
pinMode(pin3, INPUT);
pinMode(pin4, INPUT);
pinMode(pin5, INPUT); // reserve pin
pinMode(pin6, OUTPUT);
pinMode(pin7, OUTPUT);
digitalWrite(pin6, HIGH);
digitalWrite(pin7, LOW);
if ((digitalRead(pin1)== HIGH)&&(digitalRead(pin2)== LOW)&&(digitalRead(pin3)== LOW)&&(digitalRead(pin4)== LOW))
Serial.println("1");
else if ((digitalRead(pin1)== LOW)&&(digitalRead(pin2)== HIGH)&&(digitalRead(pin3)== LOW)&&(digitalRead(pin4)== LOW))
Serial.println("2");
else if ((digitalRead(pin1)== LOW)&&(digitalRead(pin2)== LOW)&&(digitalRead(pin3)== HIGH)&&(digitalRead(pin4)== LOW))
Serial.println("3");
else if ((digitalRead(pin1)== LOW)&&(digitalRead(pin2)== LOW)&&(digitalRead(pin3)== LOW)&&(digitalRead(pin4)== HIGH))
Serial.println("4");
digitalWrite(pin6, LOW);
digitalWrite(pin7, HIGH);
Serial.println("5");
Serial.println("6");
Serial.println("7");
Serial.println("8");
Serial.println("9");
Serial.println("10");
Serial.println("11");
Serial.println("12");
else if ((digitalRead(pin1)== HIGH)&&(digitalRead(pin2)== HIGH)&&(digitalRead(pin3)== LOW)&&(digitalRead(pin4)== LOW))
Serial.println("13");
else if ((digitalRead(pin1)== LOW)&&(digitalRead(pin2)== HIGH)&&(digitalRead(pin3)== HIGH)&&(digitalRead(pin4)== LOW))
Serial.println("14");
else if ((digitalRead(pin1)== LOW)&&(digitalRead(pin2)== LOW)&&(digitalRead(pin3)== HIGH)&&(digitalRead(pin4)== HIGH))
Serial.println("15");
else if ((digitalRead(pin1)== HIGH)&&(digitalRead(pin2)== LOW)&&(digitalRead(pin3)== LOW)&&(digitalRead(pin4)== HIGH))
Thank you for your time and help.
Kind Regards
Vishal.
