#include <Arduino.h>
#include "BasicStepperDriver.h"
#define Feed_step 200
#define Bend_step 200
#define Feed_RPM 80
#define Bend_RPM 30
#define MICROSTEPS 16
#define FEEDSTEPS 8
int Delay = 50;
#define Feed_DIR 6 // Y‑DIR on shield
#define Feed_STEP 3 // Y‑STEP
#define Bend_DIR 5 // X‑DIR
#define Bend_STEP 2 // X‑STEP
#define ENABLE_PIN 8 // common EN on the shield
int val = 0;
int data = 0;
int a = 0;
int b = 0;
int c = 0;
BasicStepperDriver Feed_stepper(Feed_step, Feed_DIR, Feed_STEP, ENABLE_PIN);
BasicStepperDriver Bend_stepper(Bend_step, Bend_DIR, Bend_STEP, ENABLE_PIN);
Feed_stepper.begin(Feed_RPM, MICROSTEPS);
Bend_stepper.begin(Bend_RPM, MICROSTEPS);
Feed_stepper.setEnableActiveState(LOW);
Bend_stepper.setEnableActiveState(LOW);
Feed_stepper.enable(); // keep the drivers enabled
Bend_stepper.enable();
Serial.println("For Triangle enter (1,Side Length) ");
Serial.println("For Square enter (2,Side Length) ");
Serial.println("For Rectangle enter (3,Height,Length) ");
Serial.println("For Hexagon enter (4,Side Length) ");
Serial.println("For Spring enter (5,Spring Length) ");
Serial.println("**Note Enter value without bracket ");
if (Serial.available() > 0)
a = Serial.parseInt();
b = Serial.parseInt();
c = Serial.parseInt();
if (a == 1)
Serial.println(" ");
Serial.print("Making Triangle of side Length ");
Serial.print(b);
Serial.println("mm");
for (int x = 0; x < 3; x++)
Serial.println("..");
Feed_stepper.move(FEEDSTEPS * b * MICROSTEPS);
delay(Delay);
Bend_stepper.rotate(95);
delay(Delay);
Bend_stepper.rotate(-95);
Feed_stepper.move(FEEDSTEPS * 15 * MICROSTEPS);
Serial.println("Finish ");
a = 0;
b = 0;
if (a == 2)
Serial.print("Making Square of side Length ");
Serial.print(b);
for (int x = 0; x < 4; x++)
delay(Delay);
Bend_stepper.rotate(75);
delay(Delay);
Bend_stepper.rotate(-75);
a = 0;
b = 0;
if (a == 3)
Serial.print("Making Rectangle of Length & Height ");
Serial.print(b);
Serial.print(" & ");
Serial.print(c);
Serial.println(" mm");
for (int x = 0; x < 2; x++)
delay(Delay);
delay(Delay);
delay(Delay);
Feed_stepper.move(FEEDSTEPS * c * MICROSTEPS);
delay(Delay);
delay(Delay);
a = 0;
b = 0;
if (a == 4)
Serial.print("Making Hexagon of Side Length ");
Serial.print(b);
for (int x = 0; x < 5; x++)
delay(Delay);
Bend_stepper.rotate(70);
delay(Delay);
Bend_stepper.rotate(-70);
a = 0;
b = 0;
if (a == 5)
Serial.println(" a==5 ");
Serial.print("Making Spring of Length ");
Serial.print(b);
for (int x = 0; x < b * 5; x++)
Feed_stepper.move(360);
delay(Delay);
Bend_stepper.rotate(60);
delay(Delay);
Bend_stepper.rotate(-60);
a = 0;
b = 0;
}`Use code tags to format code for the forum`
Problem solved. Thank you everyone for your quick responses. It is appreciated. The polarity is switched the external drivers only respond when the Arduino drives the STEP/DIR pins as open-drain (sinking to GND)
