yuknowhoitiz:
Hello
I am planning on designing an automatic wire cutter and stripper. Its intended purpose is to cut the wire to a specified length and strip a specified length as well.
From what I have read the best way to feed the wire for a specified length is using a stepper motor. I dont understand mechanically how the stepper motor will feed the wire though. Do I need to attach a roller to the shaft. Where would I buy a roller from? Also would I be able to control a series of rollers using one stepper motor.
Secondly for the cutting mechanism, I plan on using a servo motor to move the blade up and down.
Lastly, for the wire stripping I have not put much thought on how I would do this but I assume you would rotate a blade around the wire
Please advise how I would feed the wire and any other suggestions for cutting and stripping are appreciated.
Note: The wire will be roughly between 20-30 AWG and will be feed from a spool.
Thanks
My suggestion is to split the two operations, since you seem to have no machine shop capability.
Let me describe the wire measuring and cutting machine I purchased years ago on Ebay. It does, indeed have a stepper motor and a microcontroller. A keypad is used to enter then length of the cut wire.
There are two fairly hard rubber tired wheels that pull the wire through the machine. Both are fairly hard rubber. One wheel is on the stepper shaft the other is spring loaded to pinch the wire against the stepper motor wheel.
The wire proceeds from the wheels through a guide hole and to the cutting station. The cutter is a solenoid driven blade that actually makes the cut. The solenoid is powered by a large capacitor with a fairly high voltage. Don't recall how high. That gives a very quick and powerful cut to the wire. If you use another stepper to drive a cutter, you will have to stop the wire feed while it is being cut.
I have had to replace the original pinching wheel because the rubber tire wore out. I turned a new wheel out of hard rubber using a lathe. Close size was good enough because it was not a measuring wheel.
There are two types of insulation stripping. One leaves the insulation on the wire, the other pulls it completely off. My strippers are air driven with a foot switch. The position of the insulation cut and how far to pull the insulation are both hand adjustable. I think the actual insulation cutting is done by a blade made of multiple very fine, sharpened wires. They go through insulation, but not the wire.
Paul
