<Wire.h> library refusing to work on tinkercad
I'm confused as to what the problem is, it gives me an invalid header file error the moment I put Wire.begin(); in the setup
#include <LiquidCrystal.h>
#include <IRremote.h>
#include <Wire.h>
#define IR_RECEIVE_PIN 7
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
struct easyQuestions {
    String prompt;
    String answer;
    char removedLetters[2];
    int removedIndices[2];
struct mediumQuestions {
    String prompt;
    String answer;
    char removedLetters[3];
    int removedIndices[3];
easyQuestions easyquestions[10];
mediumQuestions mediumquestions[10];
char sprite = 'o';
int xval = 0;
int yval = 0;
int value;
int difficulty = 1;
bool difficultySet = false;
bool gameStarted = false;
int questionNumber = 0;
int score = 0;
char letter;
bool questionPresented = false;
int missingLetters = 0;
byte x = 0;
bool hearts = false;
int heartcount = 3;
void setupQuestions() {
    easyquestions[0].prompt = "US capital?";
    easyquestions[0].answer = "WAS_INGT_N";
    easyquestions[0].removedLetters[0] = 'H';
    easyquestions[0].removedLetters[1] = 'O';
    easyquestions[0].removedIndices[0] = 3;  // Reduced by 1
    easyquestions[0].removedIndices[1] = 8;  // Reduced by 1
    easyquestions[1].prompt = "Canada capital?";
    easyquestions[1].answer = "_ELH_";
    easyquestions[1].removedLetters[0] = 'D';
    easyquestions[1].removedLetters[1] = 'I';
    easyquestions[1].removedIndices[0] = 0;  // Reduced by 1
    easyquestions[1].removedIndices[1] = 4;  // Reduced by 1
    easyquestions[2].prompt = "France capital?";
    easyquestions[2].answer = "_ARI_";
    easyquestions[2].removedLetters[0] = 'S';
    easyquestions[2].removedLetters[1] = 'P';
    easyquestions[2].removedIndices[0] = 0;  // Reduced by 1
    easyquestions[2].removedIndices[1] = 4;  // Reduced by 1
    easyquestions[3].prompt = "Russia capital?";
    easyquestions[3].answer = "M_SCO_";
    easyquestions[3].removedLetters[0] = 'O';
    easyquestions[3].removedLetters[1] = 'W';
    easyquestions[3].removedIndices[0] = 1;  // Reduced by 1
    easyquestions[3].removedIndices[1] = 5;  // Reduced by 1
    easyquestions[4].prompt = "Italy capital?";
    easyquestions[4].answer = "_O_E";
    easyquestions[4].removedLetters[0] = 'R';
    easyquestions[4].removedLetters[1] = 'M';
    easyquestions[4].removedIndices[0] = 0;  // Reduced by 1
    easyquestions[4].removedIndices[1] = 2;  // Reduced by 1
    easyquestions[5].prompt = "Spain capital?";
    easyquestions[5].answer = "M_D_ID";
    easyquestions[5].removedLetters[0] = 'A';
    easyquestions[5].removedLetters[1] = 'R';
    easyquestions[5].removedIndices[0] = 1;  // Reduced by 1
    easyquestions[5].removedIndices[1] = 3;  // Reduced by 1
    easyquestions[6].prompt = "China capital?";
    easyquestions[6].answer = "BE_IN_";
    easyquestions[6].removedLetters[0] = 'I';
    easyquestions[6].removedLetters[1] = 'J';
    easyquestions[6].removedIndices[0] = 2;
    easyquestions[6].removedIndices[1] = 5;
    easyquestions[7].prompt = "Japan capital?";
    easyquestions[7].answer = "TO__O";
    easyquestions[7].removedLetters[0] = 'K';
    easyquestions[7].removedLetters[1] = 'Y';
    easyquestions[7].removedIndices[0] = 2;
    easyquestions[7].removedIndices[1] = 3;
    easyquestions[8].prompt = "Australia capital?";
    easyquestions[8].answer = "CANB_R_A";
    easyquestions[8].removedLetters[0] = 'E';
    easyquestions[8].removedLetters[1] = 'R';
    easyquestions[8].removedIndices[0] = 4;
    easyquestions[8].removedIndices[1] = 6;
    //medium prompts should have something not related to capitals
    lcd.begin(16, 2);
    lcd.setCursor(3, 1);
    IrReceiver.begin(IR_RECEIVE_PIN);
    randomSeed(0);
    setupQuestions();
    Wire.begin(4);
bool gameEnded = false;
    if (IrReceiver.decode()) {
        IrReceiver.resume();
        value = IrReceiver.decodedIRData.command;
    lcd.clear();
    lcd.setCursor(0, 0);
    while (!difficultySet){
        lcd.print("Diff");
      	lcd.setCursor(0,1);
      	lcd.print("(1:E,2:M,3:H)");
        if (value == 16){
            difficulty = 1;
            difficultySet = true;
          	Serial.println(difficulty);
        else if (value == 17){
            difficulty = 2;
        else if (value == 18){
            difficulty = 3;
        }else{
            difficulty = 1;
    if (!hearts){
        hearts = true;
        heartcount = 3;
    game(difficulty, value);
void game(int difficulty, int value) {
    gameEnded = false;
    if (difficulty == 1){
        lcd.clear();
        lcd.print(easyquestions[questionNumber].prompt);
        delay(5000);
        while (!gameEnded){
            while (!questionPresented){
              printanswer(questionNumber, difficulty);
              value = 0;
            if (missingLetters == 2){
                lcd.clear();
                lcd.print("Ur pretty good");
              	xval = 0;
                questionNumber++;
                missingLetters = 0;
                lcd.clear();
                delay(2500);
            switch(value){
              case 16:
                if (xval != 16){
                  lcd.setCursor(xval,1);
                  lcd.print(" ");
                  xval++;
                }else if (xval == 16){
                  lcd.print(" ");
                  xval = 0;
                lcd.setCursor(xval, 1);
                lcd.print(sprite);
              case 17:
                if (xval != 0){
                  lcd.print(" ");
                  xval--;
                }else if (xval == 0){
                  Serial.println("You cant go back further dawg");
                lcd.print(sprite);
              case 18:
                changeball(xval);
              case 20:
                addletter(questionNumber, xval, sprite,2);
			value = 0;
//changeball function
void changeball(int xval) {
    while (true) {
        Serial.println("Enter a letter to change the ball to");
        while (Serial.available() == 0) {
            // Wait for user input
        // Read the user input
        String userInput = Serial.readString();
        // Check if the input is a single uppercase letter
        if (userInput.length() == 1 && isUpperCase(userInput[0])) {
            char letter = userInput[0];
            // Print the letter on the LCD screen at the specified position
            sprite = letter;
            lcd.print(sprite);
            break; // Exit the loop if a valid input is provided
            Serial.println("Please enter a single uppercase letter");
void printanswer(int questionNumber, int difficulty){
        lcd.clear();
        lcd.print(easyquestions[questionNumber].answer);
      	lcd.setCursor(0,1);
      	lcd.print(sprite);
        questionPresented = true;
//function to add the letter to the word with missing letter and print it on the lcd screen
void addletter(int questionNumber, int xval, char sprite, int missingLetters){
    for (int i = 0; i < missingLetters;i++){
        if (sprite == easyquestions[questionNumber].removedLetters[i]&& xval == easyquestions[questionNumber].removedIndices[i])
          lcd.setCursor(xval,0);
          lcd.print(easyquestions[questionNumber].removedLetters[i]);
          easyquestions[questionNumber].removedLetters[i] = ' ';
          missingLetters++;
          Serial.println("Correct");
        }else{
          if (heartcount == 0){
            lcd.clear();
            lcd.setCursor(3,0);
            lcd.print("Game Over");
            delay(3000);
            gameEnded = true;
            hearts = false;
```#include <LiquidCrystal.h>
#include <Wire.h>
byte heart[8] = {
0b01010,
0b11111,
0b11111,
0b01110,
0b00100,
0b00000,
0b00000,
0b00000
int x = 0;
    lcd.begin(16, 2);
    Wire.begin(4);
    Wire.onReceive(receiveEvent);
    lcd.createChar(0, heart);
void receiveEvent(int howMany)
  while(1 < Wire.available()) // loop through all but the last
    char c = Wire.read(); // receive byte as a character
    Serial.print(c);         // print the character
  	x = Wire.read();    // receive byte as an integer
    Serial.println(x);         // print the integer
int hearts = 3;
void loop(){
    if (x==1){
        lcd.setCursor(1,0);
        lcd.write(byte(0));
        lcd.write(byte(0));
        lcd.write(byte(0));
    if (x==2){
        if (hearts == 0){
            Wire.beginTransmission(4);
            x = 5;
            Wire.write(x);
            Wire.endTransmission();
        }else {
            lcd.setCursor(hearts,0);
            lcd.write(" ");
Welcome to the forum. Thank you for the code between code tags and the picture.
Can you show the two sketches separated ?
I think you can edit your post.
Each sketch between a line with three backslash single quotes, and some empty space between them.
Your first sketch
one or more empty lines
Your second sketch
Tinkercad can make a project public and then you can give a link to it, so others can copy your project and tinker with it.
Be careful not to "share" your project. Because then you get a link that everyone can use to change your project.
Here I made it public. Thank you for the help.
I'm very sorry, but I can not make it work. I think it is a bug in Tinkercad.
The same problem with Tinkercad here: https://forum.arduino.cc/t/invalid-header-file-wire-h/1188513
The Wire library can be used in Tinkercad, but your upper Arduino board has a combination of libraries and code that causes a problem with the Wire library.
It might have to do with the combination of the Wire library and this code:
easyquestions[questionNumber].removedLetters[i];
However, I assume it is a bug. If you change that code, then the bug will probably pop up somewhere else.
