Wire.h with Mega2560 -> Uno Rev 3 problem
Is there any reason that I should not be able to use the Mega2560 as the master and the Uno Rev3 as the slave using the Wire.h library and the example sketches (master_writer on the Mega2560 and slave_receiver on the Uno). They are wired ....
Mega GND -> Uno GND
Mega SDA (pin 20) -> Uno SDA (pin A4)
Mega SCL (pin 21) -> Uno SCL (pin A5)
Seems to hang on endTransmission on the master with no activity ever on the slave
On the Mega (some serial output added for debugging) ....
// Wire Master Writer
// by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Writes data to an I2C/TWI slave device
// Refer to the "Wire Slave Receiver" example for use with this
// Created 29 March 2006
// This example code is in the public domain.
#include <Wire.h>
  Wire.begin(); // join i2c bus (address optional for master)
byte x = 0;
  Serial.println("starting transmission");
  Wire.beginTransmission(4); // transmit to device #4
  Serial.println("write value");
  Wire.write("x is ");        // sends five bytes
  Wire.write(x);              // sends one byte
  Serial.println("end transmission");
  Wire.endTransmission();    // stop transmitting
  Serial.println("increment value");
  x++;
  Serial.println(x);
On the Uno
// Wire Slave Receiver
// Receives data as an I2C/TWI slave device
// Refer to the "Wire Master Writer" example for use with this
#include <Wire.h>
  Wire.begin(4);                // join i2c bus with address #4
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);  // start serial for output
  Serial.println("waiting...");
  delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
  while(1 < Wire.available()) // loop through all but the last
    char c = Wire.read(); // receive byte as a character
    Serial.print(c);         // print the character
  int x = Wire.read();    // receive byte as an integer
  Serial.println(x);         // print the integer
I tried it with and without a pullup on the Uno pins A4 and A5
Worked fine for me, with no pull-up.
x is 68
x is 69
x is 70
x is 71
x is 72
x is 73
x is 74
x is 75
x is 76
x is 77
x is 78
x is 79
x is 80
x is 81
x is 82
x is 83
x is 84
x is 85
x is 86
x is 87
x is 88
x is 89
x is 90
x is 91
x is 92
x is 93
No, there isn't.
Are both boards powered? You should see the green power LED on both of them.
Thank you very much for confirming that it should work.
I have separate power to both and both are lit up.
The mega, unfortunately is a counterfeit (Says Arduino Mega 2560, cost the same, but turned out to be a knock off). I don't completely trust that it is not the problem.
I will swap master and slave and see what happens. If still no go, I will breadboard an atmega328 with the uno and try it that way.
I have taken this apart and put it together many times, so I am very confident that what I described is what I am doing so I have to think something is not behaving right.
Thank you again.
