Design Criteria
20 solenoid-valve controlled drip irrigation tubes
24-7 programable control
Indoor Enclosure for control circuits
I have little arduino experience (built 1 robot kit)
- What do I need ? (what kind of power supply circuit?
- Do I need relays to control the solenoids or should I use Mosfets ? (and if so, which ones?)
- What kind of solenoids should I use ?
- Do I need fuses ?
- What additional modules do I need for the time control of the solenoids ?
- Should I use Terminal blocks ? and if so which ones do you recommend ?
Thank you in advance for your guidance.
