Hi there.
I am building a line-follow robot, and I have a few questions:
- I am trying to figure how to combine the arduino + motor control + xbee.
I have this xbee board: XBee adapter - Simple wireless communication.
This motor control board: http://www.amazon.com/Motor-control-shield-KIT-Arduino/dp/B002VH9APQ.
As you can see, nor the xbee or the motor control has an input pins (I can stack shield on top of shield).
How can I connect them? if you have a link with pictures/explanations/videos, that will be fantastic!
- i'm attaching the code I wrote to my robot (It got 4 sensors - two on the front and two rear once), my idea is that the robot will be able to take turns (like the maze solve robot 3pi), so far so good,
my question is - how to control the arduino using the xbee? (how to transfer data from my pc to the arduino using xbee?)..
code:
// analog sensors
int FrontSensorR = 0;
int FrontSensorL = 0;
int BackSensorR = 0;
int BackSensorL = 0;
//motors
int RMotorDir = 12; // Direction pin for motor B is Digital 12
int LMotorDir =12;// Direction pin for motor A is Digital 12
int VelMotorR = 9; // Speed pin for motor B is Digital 9 (PWM)
int VelMotorL = 10; // Speed pin for motor B is Digital 9 (PWM)
int speed = 50;
int OutLine=250,OnLine=300;
int sf=0,delay1=600,timeflag=0,code=0,checking=0,k1=0,sum=0,Asum=0;
int flag1=1,AR=1,ActiveSensor=0;
int q=2,q1=0;// Junction Number
pinMode(RMotorDir, OUTPUT);
pinMode(LMotorDir, OUTPUT);
pinMode(0, INPUT); // digital sensor is on digital pin 0
pinMode(1, INPUT); // digital sensor is on digital pin 1
pinMode(2, INPUT); // digital sensor is on digital pin 2
pinMode(3, INPUT); // digital sensor is on digital pin 3
checking=q1;
FrontSensorL = analogRead(0);
FrontSensorR = analogRead(1);
BackSensorL = analogRead(2);
BackSensorR= analogRead(3);
// send sensor values for printig
Serial.print(FrontSensorL, DEC);
Serial.print(",");
Serial.print(FrontSensorR, DEC);
Serial.print(",");
Serial.print( BackSensorL, DEC);
Serial.print(",");
Serial.print( BackSensorR, DEC);
Serial.print(",AR=");
Serial.print( AR, DEC);
Serial.print(",checking=");
Serial.println( checking );
delay(50);
if (AR==1) //Active Regime 1,Follow Line
code=0;
ActiveSensor=BackSensorR;
if (FrontSensorR < OutLine && FrontSensorL < OutLine )// Correction to Left
digitalWrite(RMotorDir, 12); // set direction
analogWrite(VelMotorR, speed); // set speed (PWM)
digitalWrite(LMotorDir, 12); // set direction
analogWrite(VelMotorL, speed); // set speed (PWM)
sf=0;
if(FrontSensorL < OutLine && FrontSensorR > OnLine)// Correction to Right
analogWrite(VelMotorR, speed-sf); // set speed (PWM)
analogWrite(VelMotorL, speed+sf); // set speed (PWM)
sf=+10;
if(FrontSensorR < OutLine && FrontSensorL > OnLine)
analogWrite(VelMotorL, speed-sf); // set speed (PWM)
sf=+10;
if(BackSensorR > OnLine && BackSensorL < OnLine)
if(AR==2)// Active Regime 2: Turn Left on Junction
ActiveSensor=FrontSensorR;
if(code==1)
AR=1;
digitalWrite(RMotorDir, 0); // set direction
if(AR==3)// Active Regime 2: Turn Left on Junction
ActiveSensor=FrontSensorL;
if(code==1)
AR=1;
analogWrite(VelMotorL, 30); // set speed (PWM)
if(FrontSensorL > OnLine && FrontSensorR > OnLine && q1==q )
AR=2;//go to new Active Regime
//GetCode
if ( ActiveSensor > OnLine && k1==0 ) //
extern volatile unsigned long timer0_millis;
timer0_millis = 0;
timeflag=millis();
k1=1;
Asum=0;
if (millis()<timeflag+delay1)// Scanning Time
flag1++; // Scanning Number kamut srikot
sum=sum+ActiveSensor;//
if (millis()>timeflag+delay1)// Scanning Result
Asum=sum/flag1;
flag1=1;
sum=0;
if(ActiveSensor < OutLine)
k1=0;
if (Asum > OnLine)
if(millis()>timeflag+delay1 && ActiveSensor==BackSensorR && BackSensorL < OutLine)
q1++;// placing code
code++; // service code
