I am using one of THESE at one end, with a S1 2.4G Xbee, and at the other end, I am using one of THESE, with another Xbee. both Xbees communicate fine at 9600 Baud, but fail to communicate at 115200, that is needed for DCC++.
DCC++ works fine via direct serial, and the Xbee modules have been tested to work at 9600.
Just change the 115200 to 9600 in the controller and the base station sketches. The comment says "up to 115200", so you can pick whatever baud rate you want.
So what talks to JMRI? Because serial is point-to-point, a third thing needs a network or another serial port to join the party. I still don't know why the JMRI speed is imposed on the Xbee.
This is why we like a system diagram or the code when you ask a question... Without the whole picture, I guessed the wrong thing.
travis_farmer:
with a few configuration changes, and an Ethernet shield connected to my WiFi router, I can now connect wirelessly through my WiFi I can control my locomotive with my computer (and JMRI) from anywhere in the house. very cool 8)
~Travis
Hi Travis, I am in the same project as you but instead of Zigbee I use a 868MHz board called HC-12 to communicate between the DCCpp_UNO on the Arduino and a handheld controller: DCC++ Throttle
This unit communicates at 115200 baud rate.
However for power savings purposes I intend lowering the baud rate; that is why I would like to know:
did you manage to get JMRI to communicate at lower rates then 115200?
how you set up the ethernetshield hardware and software on the Arduino with the DCCpp_UNO program.
no, i never did. turns out the Xbee is unstable at 115200, and JMRI can only communicate with DCC++ at 115200.
if i recall, my DCC++ system was an Arduino MEGA2560, with a (unknown brand) Ethernet shield (W5100 chipset?) stacked on top of it. i then connected a pair of BTS7960 based "IBT_2" motor drivers from eBay. i think the Eagle CAD diagram (very basic) is still on my GITHUB, as is my last running copy of the DCC++ code. i hope that helps, if even a little bit
~Travis
Travis, thanks for replying. I found your contributions in Trainnoard forum; there is a reply by UK Steve (DCC++ Software - JMRI | Page 6 | TrainBoard.com - The Internet's Original stating that the baudrate for JMRI comms is set in the Arduino sketch (DCCpp I presume). However you contradict him?
I found your drawing with 2x BTS7960, I use those too; very interesting contribution, I will experiment with your setup (the ethernetcard I have one lying here too).
