Hi all,
Recently, I decided to design my first PCB using Atmega328p-AU, I knew it would be challenging but I am enjoying the learning journey.
As a reference, I used Arduino Nano schematics to mimic the same set up, however, as I tried to use my Arduino UNO as ISP to burn a bootloader to a Atmega328p-AU, it unfortuantely throws an error regarding the signature, "Invalid device signature".
I read the numerous post in the forum regarding this, throubleshooted the wires to ensure its correctly set up, also checked that the options selected in Arduino IDE matches the chip i am using.
I suspect has something to do with my oscillator ( i ordered an oscilloscope, waiting for its arrival), I am not sure if the oscillator i chose is causing the issue: https://datasheet.lcsc.com/szlcsc/1912111436_Yangxing-Tech-X503216MSD4SC_C70680.pdf but any help or debugging suggestions would be greatly appreciated!
My connections are essentially following the ones in Arduino page with a slight variation on the way power is delivered :
- MOSI:11
- MISO:12
- SCK: 13
- 5V and GND are independently power source (to ensure there is enough power)
My Schematics:
Below is the logs when I am trying to burn a bootloader:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM12
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Error while burning bootloader.
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
