Hi Guys,
Last time I fried my Arduino Uno. I don't want to repeat it as I can't keep on buying new Arduino and it also delays the project.
So, basically, I am trying to run 4 DC Motors ---
One 12V - 600RPM
One 12V -201 RPM(has torque gear box)
One 12V - No Info but I guess its also 600RPM
One 5V - regular motor
To connect all 4 motors, I am using Arduino shield. I am running motors in both directions.
Last time I was using 12V 1A adapter and I had connected it with the shield not Arduino, I also left the small jumper on shield connected. I am not sure what did I do wrong here that my Arduino got fried (not recognized by PC anymore).
I have new Arduino now along with n new power adapter (12V 60W) and I have 2 questions mainly.
What should I do to avoid any damage to Arduino this time??
The only thing I could think about that might have fried bord is that I was using external 12V power and also connecting it with PC to upload code at the same time. I am not sure what version of motor driver Shield is it.
This is the diagram oh my setup
Can you please post some pictures of your project?
Does you UNO have a metal USB socket?
If so check that it is not shorting on the bottom of the shield when you have it plugged in.
Thanks for your reply,
I have already bought new Arduino and I want to avoid any damage this time. my concern is -
Can I use 12v 60w power adapter with L293D motor shield and Arduino ? 2) Do I need to connect the jumper on L293D (as in screenshot above comment) or should I take it off ?
