17HS4401 Stepping motor + DRV8825 not running after programing
Hello everyone,
I recently had to rebuild a stepper motor/board for a research project that I am working on. I am attaching the schmatic i used and the coding i am using as well. Once it was programmed, The motor is not showing any response. I can't tell if power is flowing or if there was something wrong with the coding to not run at all. Any assistance is greatly appreciated!
#include <AccelStepper.h>
#include <IRremote.hpp>
int receiver = 13; // Signal Pin of IR receiver to Arduino Digital Pin 6
enum
stepper_Motor {
  FUNCTION = 0, DRIVER = 1, FULL2WIRE = 2, FULL3WIRE = 3,
  FULL4WIRE = 4, HALF3WIRE = 6, HALF4WIRE = 8
#define sleep_pwr 4
AccelStepper stepper_Motor(DRIVER, 3, 2); //stepper(driver, step, dir)
IRrecv irrecv(receiver);    // create instance of 'irrecv'
decode_results results;     // create instance of 'decode_results'
int stepsPerRev = 200; // Stepper motors are often 200 steps per revolution
int gearRatio = 4; // number of motor rotations required to rotate the drum one full revolution (e.g. motor pulley has 20 teeth, and the drum pulley has 80, so 4:1 ratio)
int microSteps = 16; // this can be manually specified using the "mode" pins on the DRV8825 board:
//         M0   M1    M2          RESOLUTION
//        LOW   LOW   LOW        FULL  STEP   1 Revolution  200  steps
//        HIGH  LOW   LOW        HALF  STEP   1 Revolution  400  steps
//        LOW   HIGH  LOW        1/4   STEP   1 Rrevolution  800  steps
//        HIGH  HIGH  LOW        1/8   STEP   1 Rrevolution  1600 steps
//        LOW   LOW   HIGH       1/16  STEP   1 Revolution  3200 steps
//        HIGH  LOW   HIGH       1/32  STEP   1 Revolution  6400 steps
float speedRPM = 1.0; // the speed of rotation. Optomotor experiments often use around 2-4 RPM
float timeRot = 45.0; // number of seconds to rotate in each direction
int nRot = 3; // the number of rotations in each direction
float stepperAccell = 5000; // acceleration and deceleration of stepper motor
int dir = -1; // initial direction: -1 = clockwise, 1 = anticlockwise
int nRem = 0;
//int nDec = 256; // number of decelleration steps when halt/reverse occurs
  Serial.println("Initialised");
  irrecv.enableIRIn(); // Start the receiver
  pinMode(sleep_pwr, OUTPUT);
  digitalWrite(sleep_pwr,LOW);
  stepper_Motor.setCurrentPosition(0);
  if (irrecv.decode(&results)){ // have we received an IR signal?
    Serial.println(results.value);
    switch(results.value){
      case 0xFFA25D: // power - stop everything!
         //stepper_Motor.moveTo(stepper_Motor.currentPosition() + (nDec*dir));
         nRem = 0;
      case 0xFF02FD: // play/pause - switch direction manually
         nRem = nRem+1;
      case 0xFF906F: // up
         nRem = nRot;
         dir = -1;
      case 0xFFE01F: // down
         nRem = nRot;
         dir = 1;
      case 0xFF30CF: // 1
         speedRPM = 1.0;
      case 0xFF18E7: // 2
         speedRPM = 2.0;
      case 0xFF7A85: // 3
         speedRPM = 3.0;
      case 0xFF10EF: // 4
         speedRPM = 4.0;
      case 0xFF38C7: // 5
         speedRPM = 5.0;
      case 0xFF5AA5: // 6
         speedRPM = 6.0;
      case 0xFF42BD: // 7
         speedRPM = 7.0;
      case 0xFF4AB5: // 8
         speedRPM = 8.0;
      case 0xFF52AD: // 9
         speedRPM = 9.0;
      case 0xFF6897: // 0
         speedRPM = 10.0;
      irrecv.resume(); // receive the next value
  if(stepper_Motor.distanceToGo()==0)  {
    if(nRem > 0){
      nRem = nRem-1;
      dir = dir*-1;
      long nSteps = round(stepsPerRev * gearRatio * microSteps * (speedRPM/60) * timeRot * dir);
      float stepperSpeed = nSteps/timeRot;
      stepper_Motor.setMaxSpeed(stepperSpeed);
      stepper_Motor.setAcceleration(stepperAccell);
      stepper_Motor.moveTo(nSteps);
      Serial.println((String)"nSteps = " + (nSteps));
      Serial.println((String)"stepperSpeed = " + (stepperSpeed));
      digitalWrite(sleep_pwr,HIGH);
  stepper_Motor.run();
Vin is not a power output. Power the stepper directly from the 12V. Look at the Uno schematic to see why.
Did you properly set the coil current limit on the DRV8825? It is important that it is done. Refer to the Pololu ERV8825 page for a procedure.
That's not what schematics should look like. It's a colourful bird nest.
did you determine coils of your motor? some producer twist middle two(on diagram yellow and green).
Hello thank you for the response! I am not electrical savvy at all and only followed a video that used the exact parts
I had the main power supply unplugged in the photo (it connects to the board, but not to the motor directly)
I will look at setting the coil limit!
This will sounds very simple and maybe dumb, but how to do you determine the coils? is that by placement?
i short(cross/connect) two wires together and trying to rotate the motor shaft. it it stuck (stall/hard to rotate) - i found two wires of same coil.
I checked the coils and tried combine two that could be the same and made no progress. The board, receiver, both seem to have power. The motor itself is still just silent, i swapped it for another new one and still nothing.
you found out which pair of wires are coils and make sure to connect them like this
