2 stepper motors on 1 axis?
Hi there!
I am making a CNC router for a school project and I have run into an issue. I need hook up 2 motors to the X-axis driver, and also make them spin in the opposite direction. So basically, I need to mirror the output of the X-axis and use that for another motor. The CNC shield I use has space for 4 stepper drivers but I don't know how to control the fourth one named 'A'.
I am using an Arduino UNO with a CNC shield extension, 4 A4988 stepper motor drivers and 4 NEMA 17 stepper motors. I use GRBL on my Arduino and universal G-code sender to control the motors.
I have thought about Soldering two sets of cables together in an opposite and parallel way but some people told me I will short out the circuit doing that.
Some help would be Greatly Appreciated!
may be this will help
Do the math. Two motors will require twice the current from your driver. How many amps for one motor winding? Each motor has two windings, so for both motors, together, you need 4 time the current for one winding. The controller DOES NOT CARE which direction a motor turns.
Once you have a powerful enough driver, you are good to go.
That CNC shield already has the features you are looking for built in. The bottom right driver labeled as "A" I think can mirror any of the other three axis by setting the push pins above the power jacks and you can select direction with those jumpers also.
Yes that’s described in the link I posted
