I wasted two weeks trying to get a KEM brand two wire transmitter , assuming ( stupidly ) that it is the same as the other two wire transmitters that we use. But then it was by sheer accident that I read the manual and found that it required the mA on the High side !! Its now working fine .
Just wanted to know the pros and cons of either of these methods - most Danfoss transmitters have the low side burden logic.
Reading the manual should be the very first thing you do if you start to work with a new kind of device. Totally regardless if this device is a smartphone, a radio, a washing-machine or a microcontroller or any kind of electronic sensor or electronic module
This part of your picture
looks like a current-meter for measuring milliamperes (1 milliampere = 0,001 ampere)
But somehow I got the feeling that you mean something different.
What the heck is a "2 wire transmitter"
"2" and "wire" are so universally generalised terms that I have no idea what the specifications of your particular "2-wire"-transmitter is.
4-20 mA interface?
0-10V interface?
GND and some kind of bus-line?
AFAIK a "2 wire transmitter" is a device that only needs 2 wires to connect.
The number of wires does not define the communication standard.
4-20mA is a common standard - but there are others.
