24LC256 write int
Hello, hopefully someone can give me some advice where my logic is not right.
Ive taken the page write code http://www.hobbytronics.co.uk/eeprom-page-write
Im trying to write my own basic class that will write basic datatypes to the eeprom. I can successfully write bool and bytes, but the problem starts when i try and write a int or long. Ive attached the int code which then calls the writeEEPROM code the handle paging.
The problem is this i write 128 to the eeprom (atleast thats what im thinking is beeing written, and then when i do a read i get 511
i then try and write 255 and i get 511
  int testIntA = 128;
  writeInt(2,testIntA);
  int testIntB = readInt(2);
  Serial.print("int test A:");
  Serial.print(testIntA);
  Serial.print(" ");
  Serial.println(testIntB);
  testIntA = 255;
  Serial.print("int test B:");
  Serial.print(" ");
int readInt(unsigned int _eeaddress)
	int rdata = 0;
	byte dataTemp[2];
	readEEPROM(_eeaddress, dataTemp, sizeof(dataTemp));
	rdata = (unsigned int)(dataTemp[1] << 8) | dataTemp[0];
	return rdata;
void writeInt(unsigned int _eeaddress, int _data)
	writeEEPROM(_eeaddress, (byte*)(&_data), sizeof(_data));
void writeEEPROM(unsigned int eeaddress, byte *data, unsigned int data_len)
  // Uses Page Write for 24LC256
  // Allows for 64 byte page boundary
  // Splits string into max 16 byte writes
  byte i=0;
  byte counter=0;
  unsigned int  address;
  unsigned int  page_space;
  unsigned int  page=0;
  unsigned int  num_writes;
  //unsigned int  data_len=0;
  byte first_write_size=0;
  byte last_write_size=0;
  byte write_size=0;
  // Calculate length of data
  //do{ data_len++; } while(data[data_len]);
  // Calculate space available in first page
  page_space = int(((eeaddress/64) + 1)*64)-eeaddress;
  // Calculate first write size
  if (page_space>16){
     first_write_size=page_space-((page_space/16)*16);
     if (first_write_size==0) first_write_size=16;
     first_write_size=page_space;
  // calculate size of last write
  if (data_len>first_write_size)
     last_write_size = (data_len-first_write_size)%16;
  // Calculate how many writes we need
     num_writes = ((data_len-first_write_size)/16)+2;
     num_writes = 1;
  i=0;
  address=eeaddress;
  for(page=0;page<num_writes;page++)
     if(page==0) write_size=first_write_size;
     else if(page==(num_writes-1)) write_size=last_write_size;
     else write_size=16;
     Wire.beginTransmission(deviceaddress);
     Wire.write((int)((address) >> 8));   // MSB
     Wire.write((int)((address) & 0xFF)); // LSB
     counter=0;
     do{
        Wire.write((byte) data[i]);
        i++;
        counter++;
     } while((data[i]) && (counter<write_size));
     Wire.endTransmission();
     address+=write_size;   // Increment address for next write
     delay(6);  // needs 5ms for page write
void readEEPROM(unsigned int eeaddress, byte *data, unsigned int data_len)
	Wire.write((int)(eeaddress >> 8));   // MSB
	Wire.write((int)(eeaddress & 0xFF)); // LSB
	Wire.requestFrom(deviceaddress,data_len);
	byte i = 0;
	while(Wire.available()){
		data[i++] = Wire.read();
Im sure im doing something very dumb but i cannot see where ive gone wrong.
Regards
Trev
do {
      i++;
      counter++;
    } while((data[i]) && (counter < write_size));
You are encountering situations where the value of data[]==0 and you are breaking from the while loop.
Try
while ((i < data_len) && (counter < write_size));
This works for the integer situation
#include <Wire.h>
int deviceaddress = 0x50;
  Wire.begin();
  int testIntA = 128;
  writeInt(2, testIntA);
  Serial.print(" ");
  // testIntA = 255;
  //testIntA = 512;
  testIntA = 12345;
  Serial.print(" ");
void loop() {}
  int rdata = 0;
  byte dataTemp[2];
  return rdata;
  byte i = 0;
  byte counter = 0;
  unsigned int  page = 0;
  byte first_write_size = 0;
  byte last_write_size = 0;
  byte write_size = 0;
  page_space = int(((eeaddress / 64) + 1) * 64) - eeaddress;
  if (page_space > 16) {
    first_write_size = page_space - ((page_space / 16) * 16);
    if (first_write_size == 0) first_write_size = 16;
    first_write_size = page_space;
  if (data_len > first_write_size)
    last_write_size = (data_len - first_write_size) % 16;
    num_writes = ((data_len - first_write_size) / 16) + 2;
    num_writes = 1;
  i = 0;
  address = eeaddress;
  for (page = 0; page < num_writes; page++)
    if (page == 0) write_size = first_write_size;
    else if (page == (num_writes - 1)) write_size = last_write_size;
    else write_size = 16;
    counter = 0;
    do {
      i++;
      counter++;
    } //while((data[i]) && (counter < write_size));
    address += write_size; // Increment address for next write
  Wire.requestFrom(deviceaddress, data_len);
  byte i = 0;
  while (Wire.available()) {
I would recommend that you use Jack Christensens library extEEPROM.h available through the library manager. It handles the page boundaries and block writes.
Thank you loads for the quick reply. I tried your change and it works well. Ive also took your advice and used extEEPROM class and added a wrapper to do bool byte int and longs so far.
Thank you again
Trev
