Hello all,
I request the help from the Arduino community for a robotic project. I would like to turn ON everytime a 3-phase brushless motor with the BLDC driver ref MPQ6541-AEC1 and an Arduino ATmega2560.
The MPQ6541-AEC1 is a 3-phase brushless DC (BLDC) motor driver with 3 integrated half-bridges. The 3 half-bridges consist of 6 N-channel power mosfets. The MPQ6541-AEC1 also integrates 6 pre-drivers, 2 gate driver power supplies, and 3 current-sense amplifiers.
Are you able to explain me better how this 3-phase brushless DC (BLDC) motor driver works and improve my code to get something good ?
Pictures :
Code test_3.ino
#include "pinDefinition.h"
#include "BentiXMotor.h"
#define REMOTE Serial1
BentiXMotor motor1(M1_FAULT_PIN, M1_WAKE_PIN, M1_PWMAL_PIN, M1_PWMBL_PIN, M1_PWMCL_PIN, M1_PWMAH_PIN, M1_PWMBH_PIN, M1_PWMCH_PIN, M1_OUT1_PIN, M1_OUT2_PIN, M1_OUT3_PIN, 255, 0);
BentiXMotor motor2(M2_FAULT_PIN, M2_WAKE_PIN, M2_PWMAL_PIN, M2_PWMBL_PIN, M2_PWMCL_PIN, M2_PWMAH_PIN, M2_PWMBH_PIN, M2_PWMCH_PIN, M2_OUT1_PIN, M2_OUT2_PIN, M2_OUT3_PIN, 255, 0);
BentiXMotor motor3(M3_FAULT_PIN, M3_WAKE_PIN, M3_PWMAL_PIN, M3_PWMBL_PIN, M3_PWMCL_PIN, M3_PWMAH_PIN, M3_PWMBH_PIN, M3_PWMCH_PIN, M3_OUT1_PIN, M3_OUT2_PIN, M3_OUT3_PIN, 255, 0);
BentiXMotor motor4(M4_FAULT_PIN, M4_WAKE_PIN, M4_PWMAL_PIN, M4_PWMBL_PIN, M4_PWMCL_PIN, M4_PWMAH_PIN, M4_PWMBH_PIN, M4_PWMCH_PIN, M4_OUT1_PIN, M4_OUT2_PIN, M4_OUT3_PIN, 255, 0);
long timer;
Serial.println("Start Drone");
// Initializing motors
motor1.initialize();
motor2.initialize();
motor3.initialize();
motor4.initialize();
// Start Motors
motor1.setSpeed(255);
motor2.setSpeed(255);
motor3.setSpeed(255);
motor4.setSpeed(255);
timer = millis();
if (millis() - timer > 10000) {
motor1.setSpeed(0);
motor2.setSpeed(0);
motor3.setSpeed(0);
motor4.setSpeed(0);
// currentSense(); // uncomment this line to check current
checkAndResetFaults();
checkAndInitializeMotors();
void currentSense() {
int currentSenseA1 = motor1.readCurrentSenseA();
int currentSenseB1 = motor1.readCurrentSenseB();
int currentSenseC1 = motor1.readCurrentSenseC();
int currentSenseA2 = motor2.readCurrentSenseA();
int currentSenseB2 = motor2.readCurrentSenseB();
int currentSenseC2 = motor2.readCurrentSenseC();
int currentSenseA3 = motor3.readCurrentSenseA();
int currentSenseB3 = motor3.readCurrentSenseB();
int currentSenseC3 = motor3.readCurrentSenseC();
int currentSenseA4 = motor4.readCurrentSenseA();
int currentSenseB4 = motor4.readCurrentSenseB();
int currentSenseC4 = motor4.readCurrentSenseC();
Serial.println("Motor 1 Current Sense:");
Serial.print("Phase A: ");
Serial.println(currentSenseA1);
Serial.print("Phase B: ");
Serial.println(currentSenseB1);
Serial.print("Phase C: ");
Serial.println(currentSenseC1);
Serial.println("Motor 2 Current Sense:");
Serial.println(currentSenseA2);
Serial.println(currentSenseB2);
Serial.println(currentSenseC2);
Serial.println("Motor 3 Current Sense:");
Serial.println(currentSenseA3);
Serial.println(currentSenseB3);
Serial.println(currentSenseC3);
Serial.println("Motor 4 Current Sense:");
Serial.println(currentSenseA4);
Serial.println(currentSenseB4);
Serial.println(currentSenseC4);
void checkAndResetFaults() {
if (motor1.checkFault()) {
Serial.println("Motor 1 fault detected. Resetting...");
motor1.reset();
if (motor2.checkFault()) {
Serial.println("Motor 2 fault detected. Resetting...");
motor2.reset();
if (motor3.checkFault()) {
Serial.println("Motor 3 fault detected. Resetting...");
motor3.reset();
if (motor4.checkFault()) {
Serial.println("Motor 4 fault detected. Resetting...");
motor4.reset();
void checkAndInitializeMotors() {
if (motor1.checkWake()) {
Serial.println("Motor 1 woke up. Initializing...");
if (motor2.checkWake()) {
Serial.println("Motor 2 woke up. Initializing...");
if (motor3.checkWake()) {
Serial.println("Motor 3 woke up. Initializing...");
if (motor4.checkWake()) {
Serial.println("Motor 4 woke up. Initializing...");
Code BentiXMotor.cpp
BentiXMotor::BentiXMotor(int faultPin, int wakePin, int pwmALPin, int pwmBLPin, int pwmCLPin, int pwmAHPin, int pwmBHPin, int pwmCHPin, int out1Pin, int out2Pin, int out3Pin, int maxSpeed, int minSpeed) {
M_FAULT = faultPin;
M_WAKE = wakePin;
M_PWMAL = pwmALPin;
M_PWMBL = pwmBLPin;
M_PWMCL = pwmCLPin;
M_PWMAH = pwmAHPin;
M_PWMBH = pwmBHPin;
M_PWMCH = pwmCHPin;
M_OUT1 = out1Pin;
M_OUT2 = out2Pin;
M_OUT3 = out3Pin;
MAX_SPEED = maxSpeed;
MIN_SPEED = minSpeed;
// Set pin modes
pinMode(M_FAULT, INPUT_PULLUP); // Fault pin
pinMode(M_WAKE, OUTPUT); // Wake pin
pinMode(M_PWMAL, OUTPUT); // Phase A enable pin
pinMode(M_PWMBL, OUTPUT); // Phase B enable pin
pinMode(M_PWMCL, OUTPUT); // Phase C enable pin
pinMode(M_PWMAH, OUTPUT); // Phase A PWM pin
pinMode(M_PWMBH, OUTPUT); // Phase B PWM pin
pinMode(M_PWMCH, OUTPUT); // Phase C PWM pin
pinMode(M_OUT1, INPUT); // Current sense output for Phase A
pinMode(M_OUT2, INPUT); // Current sense output for Phase B
pinMode(M_OUT3, INPUT); // Current sense output for Phase C
// Set initial states
digitalWrite(M_WAKE, HIGH); // Normal operation
digitalWrite(M_PWMAL, HIGH); // Enable Phase A
digitalWrite(M_PWMBL, HIGH); // Enable Phase B
digitalWrite(M_PWMCL, HIGH); // Enable Phase C
void BentiXMotor::setSpeed(int speed) {
int mappedSpeed = map(speed, 0, 255, MIN_SPEED, MAX_SPEED);
analogWrite(M_PWMAH, mappedSpeed);
analogWrite(M_PWMBH, mappedSpeed);
analogWrite(M_PWMCH, mappedSpeed);
void BentiXMotor::stop() {
setSpeed(MIN_SPEED);
void BentiXMotor::start() {
setSpeed(MAX_SPEED);
void BentiXMotor::sleep(bool enableSleep) {
digitalWrite(M_WAKE, enableSleep ? LOW : HIGH);
void BentiXMotor::enablePhaseA(bool enable) {
digitalWrite(M_PWMAL, enable ? HIGH : LOW);
void BentiXMotor::enablePhaseB(bool enable) {
digitalWrite(M_PWMBL, enable ? HIGH : LOW);
void BentiXMotor::enablePhaseC(bool enable) {
digitalWrite(M_PWMCL, enable ? HIGH : LOW);
int BentiXMotor::readCurrentSenseA() {
return analogRead(M_OUT1);
int BentiXMotor::readCurrentSenseB() {
return analogRead(M_OUT2);
int BentiXMotor::readCurrentSenseC() {
return analogRead(M_OUT3);
int BentiXMotor::max_speed() {
return MAX_SPEED;
int BentiXMotor::min_speed(){
return MIN_SPEED;
bool BentiXMotor::checkFault() {
return !digitalRead(M_FAULT);
void BentiXMotor::reset() {
digitalWrite(M_WAKE, LOW);
delay(100);
bool BentiXMotor::checkWake() {
return digitalRead(M_WAKE);
void BentiXMotor::initialize() {
digitalWrite(M_PWMAH, HIGH);
digitalWrite(M_PWMBH, HIGH);
digitalWrite(M_PWMCH, HIGH);
analogWrite(M_PWMAL, 128);
analogWrite(M_PWMBL, 128);
analogWrite(M_PWMCL, 128);
Code BentiXMotor.h
#ifndef BENTIX_MOTOR_H
#define BENTIX_MOTOR_H
#include <Arduino.h>
class BentiXMotor {
private:
// Pin declarations
int M_FAULT;
int M_WAKE;
int M_PWMAL;
int M_PWMBL;
int M_PWMCL;
int M_PWMAH;
int M_PWMBH;
int M_PWMCH;
int M_OUT1;
int M_OUT2;
int M_OUT3;
// Motor control parameters
int MAX_SPEED;
int MIN_SPEED;
public:
// Constructor
BentiXMotor(int faultPin, int wakePin, int pwmALPin, int pwmBLPin, int pwmCLPin, int pwmAHPin, int pwmBHPin, int pwmCHPin, int out1Pin, int out2Pin, int out3Pin, int maxSpeed, int minSpeed);
// Function to set motor speed
void setSpeed(int speed);
// Function to stop the motor
void stop();
// Function to start the motor at maximum speed
void start();
// Function to enter or exit sleep mode
void sleep(bool enableSleep);
// Function to enable or disable Phase A
void enablePhaseA(bool enable);
// Function to enable or disable Phase B
void enablePhaseB(bool enable);
// Function to enable or disable Phase C
void enablePhaseC(bool enable);
// Function to read current sense value for Phase A
int readCurrentSenseA();
// Function to read current sense value for Phase B
int readCurrentSenseB();
// Function to read current sense value for Phase C
int readCurrentSenseC();
// Function to get max speed
int max_speed();
// Function to get min speed
int min_speed();
bool checkFault();
void reset();
bool checkWake();
void initialize();
#endif
Code pinDefinition.h
// LEDS
#define LED_1 32 //PC5
#define LED_2 31 //PC6
#define LED_3 30 //PC7
// MOTOR 1
#define M1_FAULT_PIN 49 //PL0
#define M1_WAKE_PIN 48 //PL1
#define M1_PWMAL_PIN 47 //PL2
#define M1_PWMAH_PIN 46 //PL3
#define M1_PWMBL_PIN 43 //PL6
#define M1_PWMBH_PIN 44 //PL5
#define M1_PWMCL_PIN 42 //PL7
#define M1_PWMCH_PIN 45 //PL4
#define M1_OUT1_PIN A3 //PF3
#define M1_OUT2_PIN A4 //PF4
#define M1_OUT3_PIN A5 //PF5
// MOTOR 2
#define M2_FAULT_PIN 33 //PC4
#define M2_WAKE_PIN 34 //PC3
#define M2_PWMAL_PIN 35 //PC2
#define M2_PWMBL_PIN 36 //PC1
#define M2_PWMCL_PIN 37 //PC0
#define M2_PWMAH_PIN 12 //PB6
#define M2_PWMBH_PIN 11 //PB5
#define M2_PWMCH_PIN 10 //PB4
#define M2_OUT1_PIN A0 //PF0
#define M2_OUT2_PIN A1 //PF1
#define M2_OUT3_PIN A2 //PF2
// MOTOR 3
#define M3_FAULT_PIN 53 //PB0
#define M3_WAKE_PIN 39 //PG2
#define M3_PWMAL_PIN 6 //PH3
#define M3_PWMBL_PIN 16 //PH1
#define M3_PWMCL_PIN 17 //PH0
#define M3_PWMAH_PIN 9 //PH6
#define M3_PWMBH_PIN 8 //PH5
#define M3_PWMCH_PIN 7 //PH4
#define M3_OUT1_PIN A8 //PK0
#define M3_OUT2_PIN A7 //PF7
#define M3_OUT3_PIN A6 //PF6
// MOTOR 4
#define M4_FAULT_PIN 15 //PJ0
#define M4_WAKE_PIN 14 //PJ1
#define M4_PWMAL_PIN 26 //PA4
#define M4_PWMBL_PIN 27 //PA5
#define M4_PWMCL_PIN 28 //PA6
#define M4_PWMAH_PIN 5 //PE3
#define M4_PWMBH_PIN 2 //PE4
#define M4_PWMCH_PIN 3 //PE5
#define M4_OUT1_PIN A9 //PK1
#define M4_OUT2_PIN A10 //PK2
#define M4_OUT3_PIN A11 //PK3
Thanks again for your action.
