Hi Everyone,
I am at a total loss as to what I must be missing in my code. I am using a nano and have 8 pots for inputs on A0-A7 and 6 mA gauges on D3, D5, D6, D9, D10, D11. Neopixel strip data on D2.
Everything works great other than D3, D5, D6 are ticking up and down. D3 and D6 slowly decrease hit the max and return to 0 and track back up again. D5 rises slowly hits the max goes back to zero.
I have tested the outputs and inputs and everything looks as expected even after the mapping. I have added an external power supply no change. The issue hits at the analogwrite step. When I check the outputs via the serial monitor after this step they are ticking up and down and the gauges match this behavior. If I move the pot mapped to D3 and D6 to zero and the output stays at zero, pot on D5 full and it stays close to 255. The pot seems to define the start point of the drifting. The drift is in increments of 1 and takes about 24-25 seconds from 0 or 255 to the opposite side, when it hits 0 or 255 it will then immediately kick back over to its starting position. If I move D3 to a different gauge the problem moves to the new gauge so it does look like the pin is the issue. Again D9-11 are working perfectly fine.
3 hours in and just can not figure this one out, any help would be appreciated.
//Guage Puzzle June 4
// INCLUDES
#include <FastLED.h>
// CONSTANTS
#define NUM_LEDS 6
#define DATA_PIN 2
int numOutputs = 8;
int numInputs = 8;
int brightness = 255;
CRGB leds[NUM_LEDS];
const byte meterPins[] = {3, 5, 6, 9, 10, 11};
const byte sliderPins[] = {A0, A1, A2, A3, A4, A5, A6, A7};
// Win condition const byte relayPin = 2;
const int targetValues[] = {128, 128, 128, 128, 128, 128, 128, 128};
const int tolerance = 4;
int y = 0;
const byte smoothInterval = 40;
struct Timer {
CRGB targetColor;
uint32_t previousMillis;
byte counter = 0;
bool isBlending = false;
timer[NUM_LEDS];
// GLOBALS
// 10-bit input values from the ADC have values in the range (0-1023)
int inputValues[8] = {};
// 8-bit output values to pass to AnalogWrite PWM output have values in the range (0-255)
int outputValues[8] = {};
bool isSolved = false;
//Sequence for LED blend
void update(byte currentLed){
uint32_t currentMillis = millis();
if (millis() - timer[currentLed].previousMillis > smoothInterval)
timer[currentLed].previousMillis = currentMillis;
if (timer[currentLed].counter < 255 && timer[currentLed].isBlending == true)
timer[currentLed].counter++;
CRGB tempColor = blend( leds[currentLed], timer[currentLed].targetColor, timer[currentLed].counter );
//Serial.print(timer[currentLed].counter);
//Serial.print("\ttempColor:"); Serial.print(tempColor.r); Serial.print(" "); Serial.print(tempColor.g); Serial.print(" "); Serial.println(tempColor.b);
leds[currentLed] = tempColor;
FastLED.show(); // needed removed from loop
if (leds[currentLed] == timer[currentLed].targetColor)
//Serial.print("target reached LED "); Serial.println(currentLed);
timer[currentLed].counter = 0;
timer[currentLed].isBlending = false;
//Set up LEDs to start colors
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
for(int i=0; i<NUM_LEDS; i++){
leds[NUM_LEDS] = CRGB::Red;
FastLED.show();
// Initialise the output pins
for(int i=0; i<6; i++) {
pinMode(meterPins[i], OUTPUT);
for(int i=0; i<numInputs; i++){
// Clear ADC
for(int x=0; x<2; x++) {
analogRead(sliderPins[i]);
delay(5);
inputValues[i] = analogRead(sliderPins[i]);
// Quick set for outputs
for(int i=0; i<numOutputs; i++){
outputValues[i] = inputValues[i];
//Testing Inputs, note floating pin produces variable results START
//Output and input values correct
//Serial.print(i);
//Serial.print("-");
//Serial.print(outputValues[i]);
//Serial.print(",");
//if(i>(numOutputs-2)){
//Serial.println("");
//END
//Setting up custom paramters/relationships
//outputValues[0] = (inputValues[0] + inputValues[1]/ 5.5);
//outputValues[1] = (inputValues[1] - inputValues[2]);
//outputValues[2] = (inputValues[2]);
//outputValues[3] = (inputValues[3]);
//outputValues[4] = (inputValues[4]);
//outputValues[5] = (inputValues[5]);
// Check outputs vs targets
bool allMetersCorrect = true;
// Loop over each output
outputValues[i] = map(outputValues[i], 0, 1000, 0, 255);
outputValues[i] = constrain(outputValues[i], 0, 255);
//output values correct
if(abs(outputValues[i] - targetValues[i]) > tolerance) {
allMetersCorrect = false;
// Turn incorrect matches to red
timer[i].targetColor = CRGB::Red;
timer[i].isBlending = true;
else {
// Turn LED Green when input is correct
timer[i].targetColor = CRGB::Green;
update(i);
//Write to the meters
for (int i=0; i<6; i++){
//Failure on output 1-3
analogWrite(meterPins[i], outputValues[i]);
//Output values wrong
Serial.print(i);
Serial.print("-");
Serial.print(",");
if(i>(4)){
Serial.println("");
//END
if(allMetersCorrect && !isSolved) {
//Serial.println("Solved!");
isSolved = true;
//Wipe gauges on solve need to add delay on return to stop gauge bounce
//y = y+20;
//if(y >= 850){
//y=0;
//for(int i=0; i<6; i++){
//outputValues[i] = y;
// If the puzzle had been solved, but now the meters are no longer correct
else if(isSolved && !allMetersCorrect) {
//Serial.println("Unsolved!");
isSolved = false;
//Display Inputs
//for(int i=0; i<8; i++) {
// Serial.print(inputValues[i]);
// Serial.print(",");
// if(i>6) { Serial.println(""); }
//Display Outputs
//Serial.print("OUTPUT ");
//for(int i=0; i<numInputs; i++) {
//Serial.print(i);
//if(i>6) {
