I just received my kit about 2 weeks ago and just got sent a new 4 digit 7 segment display. I am new so I am wondering if this code is just suppose to display solid 8's? It appears to be a cathode anode display according to the code and the number on it is SH5461AS. I thought this code would count or something. As you can see I am new to Arduino and all of this! Hey at least I figured out how to light up all the segments as they did not all work at first because of some wiring issues by me!
I hooked it up exactly like the tutorial image! All I have lit up is all solid 8's, on all 4 digit's!
//set the cathode interface
int a = 1;
int b = 2;
int c = 3;
int d = 4;
int e = 5;
int f = 6;
int g = 7;
int p = 8;
// set the anode interface
int d4 = 9;
int d3 = 10;
int d2 = 11;
int d1 = 12;
//set variable
long n = 0;
int x = 100;
int del = 55; //fine-tuning value for clock
pinMode(d1, OUTPUT);
pinMode(d2, OUTPUT);
pinMode(d3, OUTPUT);
pinMode(d4, OUTPUT);
pinMode(a, OUTPUT);
pinMode(b, OUTPUT);
pinMode(c, OUTPUT);
pinMode(d, OUTPUT);
pinMode(e, OUTPUT);
pinMode(f, OUTPUT);
pinMode(g, OUTPUT);
pinMode(p, OUTPUT);
clearLEDs();
pickDigit(1);
pickNumber((n/x/1000)%10);
delayMicroseconds(del);
clearLEDs();
pickDigit(2);
pickNumber((n/x/100)%10);
clearLEDs();
pickDigit(3);
dispDec(3);
pickNumber((n/x/10)%10);
clearLEDs();
pickDigit(4);
pickNumber(n/x%10);
n++;
if (digitalRead(13) == HIGH)
n = 0;
void pickDigit(int x) //define pickDigit(x),to open dx port
digitalWrite(d1, LOW);
digitalWrite(d2, LOW);
digitalWrite(d3, LOW);
digitalWrite(d4, LOW);
switch(x)
case 1:
digitalWrite(d1, HIGH);
case 2:
digitalWrite(d2, HIGH);
case 3:
digitalWrite(d3, HIGH);
default:
digitalWrite(d4, HIGH);
void pickNumber(int x) //define pickNumber(x)to display number x
switch(x)
default:
zero();
case 1:
one();
case 2:
two();
case 3:
three();
case 4:
four();
case 5:
five();
case 6:
six();
case 7:
seven();
case 8:
eight();
case 9:
nine();
void dispDec(int x) //set to start the decimal point
digitalWrite(p, LOW);
void clearLEDs() //clear contents
digitalWrite(a, HIGH);
digitalWrite(b, HIGH);
digitalWrite(c, HIGH);
digitalWrite(d, HIGH);
digitalWrite(e, HIGH);
digitalWrite(f, HIGH);
digitalWrite(g, HIGH);
digitalWrite(p, HIGH);
void zero() //define 0 as cathode pin switch
digitalWrite(a, LOW);
digitalWrite(b, LOW);
digitalWrite(c, LOW);
digitalWrite(d, LOW);
digitalWrite(e, LOW);
digitalWrite(f, LOW);
void one() // define 1 as cathode pin switch
void two() // define 2 as cathode pin switch
digitalWrite(g, LOW);
void three() // define 3 as cathode pin switch
void four() // define 4 as cathode pin switch
void five() // define 5 as cathode pin switch
void six() // define 6 as cathode pin switch
void seven() // define 7 as cathode pin switch
void eight() // define 8 as cathode pin switch
void nine() // define 9 as cathode pin switch
