4 stepper and 2 servo with CNC shield
No I'm powering with external 5V
[code]
#include <MobaTools.h>
#include <Servo.h>
// Define servo motor
Servo Servo1;
Servo Servo2;
int ang1 = 90;
int ang2 = 90;
int val;
long steps = 20;
const byte enablePin = 8;  // for my CNC shield stepper enable
//Define stepper motor
MoToStepper StepperX(steps,  STEPDIR);
MoToStepper StepperY(steps,  STEPDIR);
MoToStepper StepperZ(steps,  STEPDIR);
MoToStepper StepperA(steps,  STEPDIR);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(14, OUTPUT);
  pinMode(15, OUTPUT);
  Servo1.attach(14);
  Servo2.attach(15);
  Servo1.write(ang1);
  Servo2.write(ang2);
  StepperX.attach(2, 5);
  StepperY.attach(3, 6);
  StepperZ.attach(4, 7);
  StepperA.attach(12, 13);
  StepperX.setSpeed(200);
  StepperY.setSpeed(200);
  StepperZ.setSpeed(200);
  StepperA.setSpeed(200);
  StepperX.setRampLen(1);
  StepperY.setRampLen(1);
  StepperZ.setRampLen(1);
  StepperA.setRampLen(1);
  if (Serial.available())
    val = Serial.read();
    if (val == 'y') {
      ang1 += 3;
      Servo1.write(ang1);
    if (val == 'h') {
      ang1 -= 3;
      Servo1.write(ang1);
    if (val == 't') {
      ang2 += 3;
      Servo2.write(ang2);
    if (val == 'g') {
      ang2 -= 3;
      Servo2.write(ang2);
    //Adding stepper motor comad
    //Stepper 4 (arm3)a
    if (val == 'r') {
      StepperA.doSteps(steps);
    if (val == 'f') {
      StepperA.doSteps(-steps);
    //Stepper 3 (arm2)z
    if (val == 'e') {
      StepperZ.doSteps(steps);
    if (val == 'd') {
      StepperZ.doSteps(-steps);
    //Stepper 2 (arm1)y
    if (val == 'w') {
      StepperY.doSteps(steps);
    if (val == 's') {
      StepperY.doSteps(-steps);
    //Stepper 1 (base)x
    if (val == 'q') {
      StepperX.doSteps(steps);
    if (val == 'a') {
      StepperX.doSteps(-steps);
[/code]
This code work with keyboard and Tera Term but unfortunately motor not have the strenght to work correctly on the arm.
Code work very well. Now I'll try your code with serial monitor.
Sorry, with my code driver with A doesn't work, why? How can I enable it?
I'm sorry if I disturb you again, code work very good but A stepper doesn't work ,I've write pin 12 and 13 it's correct. Have I to do something before run code, maybe on cnc shield??
Did you do the jumpers for A:
When creating the object, 'steps' must be the steps/revolution. Otherwise 'setSpeed' will not work correctly ( it defines the speed in rev/min ). I cannot imagine, that your stepper only needs 20 steps per rev.
Did you succeed in getting stepperA to work by the advice of DaveX?
Thanks I've already fixed that.
Not yet, I know stepper motor work and also Driver, I've connected pins but nothing change. Maybe the code could be wrong? Can my code doesn't power on my motor?
