Hi Dinky.
I have used that same code and it works well once you understand how to get it to do what you want. I do not know how you ended up with a copy of it with those "B"s at the end
'B0000B' was not declared in this scope
but I have attached a copy of this code that does compile so see how you go with it.
All the best Pedro.
#include <avr/pgmspace.h> // alHIGHs use of PROGMEM to store patterns in flash
#define CUBESIZE 4
#define PLANESIZE CUBESIZE*CUBESIZE
#define PLANETIME 3333 // time each plane is displayed in us -> 100 Hz refresh
#define TIMECONST 100 // multiplies DisplayTime to get ms - why not =100?
// LED Pattern Table in PROGMEM - last column is display time in 100ms units
// TODO this could be a lot more compact but not with binary pattern representation
prog_uchar PROGMEM PatternTable[] = {
// blink on and off
// Common anode, so we send plane pin high, and column pin low to light.
// 1= off, 0=on
// First group of each block is the right plane
// first 4 groups of 4 character blocks is bottom plane second is second layer, ...
// first character in segment is front plane
//Collumn spin Clockwise 360
B0111,B1011,B1101,B1110,B0111,B1011,B1101,B1110,B0111,B1011,B1101,B1110,B0111,B1011,B1101,B1110,01,
B1111,B0011,B1100,B1111,B1111,B0011,B1100,B1111,B1111,B0011,B1100,B1111,B1111,B0011,B1100,B1111,01,
B1111,B1100,B0011,B1111,B1111,B1100,B0011,B1111,B1111,B1100,B0011,B1111,B1111,B1100,B0011,B1111,01,
B1110,B1101,B1011,B0111,B1110,B1101,B1011,B0111,B1110,B1101,B1011,B0111,B1110,B1101,B1011,B0111,01,
B1101,B1101,B1011,B1011,B1101,B1101,B1011,B1011,B1101,B1101,B1011,B1011,B1101,B1101,B1011,B1011,01,
B1011,B1011,B1101,B1101,B1011,B1011,B1101,B1101,B1011,B1011,B1101,B1101,B1011,B1011,B1101,B1101,01,
// this is a dummy element for end of table (duration=0) aka !!!DO NOT TOUCH!!!
B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, B0000, 0
** Defining pins in array makes it easier to rearrange how cube is wired
** Adjust numbers here until LEDs flash in order - L to R, T to B
** Note that analog inputs 0-5 are also digital outputs 14-19!
** Pin DigitalOut0 (serial RX) and AnalogIn5 are left open for future apps
int LEDPin[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15};
int PlanePin[] = {11, 10, 9, 6};
int dataPin = 7; //Data I added these for Shift Register
int clockPin = 12; // Clock
int latchPin = 13; // Latch
// initialization
int pin; // loop counter
// set up LED pins as output (active LOW)
//for (pin=0; pin<PLANESIZE; pin++) {
// pinMode( LEDPin[pin], OUTPUT ); Edited out because we dont use them pins
// setup Shift Register pins instead of 16 arduino pins.
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
// set up plane pins as outputs (active HIGH)
for (pin=0; pin<CUBESIZE; pin++) {
pinMode( PlanePin[pin], OUTPUT );
// display pattern in table until DisplayTime is zero (then repeat)
// declare variables
byte PatternBuf[PLANESIZE]; // saves current pattern from PatternTable
int PatternIdx;
byte DisplayTime; // time*100ms to display pattern
unsigned long EndTime;
int plane; // loop counter for cube refresh
int patbufidx; // indexes which byte from pattern buffer
int ledrow; // counts LEDs in refresh loop
int ledcol; // counts LEDs in refresh loop
int ledpin; // counts LEDs in refresh loop
int pinState;
// Initialize PatternIdx to beginning of pattern table
PatternIdx = 0;
// loop over entries in pattern table - while DisplayTime>0
do {
// read pattern from PROGMEM and save in array
memcpy_P( PatternBuf, PatternTable+PatternIdx, PLANESIZE );
PatternIdx += PLANESIZE;
// read DisplayTime from PROGMEM and increment index
DisplayTime = pgm_read_byte_near( PatternTable + PatternIdx++ );
// compute EndTime from current time (ms) and DisplayTime
EndTime = millis() + ((unsigned long) DisplayTime) * TIMECONST;
// loop while DisplayTime>0 and current time < EndTime
while ( millis() < EndTime ) {
patbufidx = 0; // reset index counter to beginning of buffer
// loop over planes
for (plane=0; plane<CUBESIZE; plane++) {
// turn previous plane off
if (plane==0) {
digitalWrite( PlanePin[CUBESIZE-1], LOW );
digitalWrite( PlanePin[plane-1], LOW );
// load current plane pattern data into ports
// Plane pins are taken care of above, this routine handles the 16
// LED pins(columns), originally 16 pins are now going to 2 shift registers
// using dataPin, clockPin, latchPin.
// Original code
//ledpin = 0;
//for (ledrow=0; ledrow<CUBESIZE; ledrow++) {
//for (ledcol=0; ledcol<CUBESIZE; ledcol++) {
//digitalWrite( LEDPin[ledpin++], PatternBuf[patbufidx] & (1 << ledcol) );
//patbufidx++;
// I used code from shiftout, to redo this to serialize the plane data
digitalWrite(latchPin, 0);
//move 'em out
ledpin = 0;
digitalWrite(clockPin, 0);
// digitalWrite( dataPin, PatternBuf[patbufidx] & (1 << ledcol) );
if (PatternBuf[patbufidx] & (1 << ledcol))
pinState= 1; // Inverted for common anode
pinState= 0; // Inverted for common anode
//Sets the pin to HIGH or LOW depending on pinState
digitalWrite(dataPin, pinState); // this is where data is sent to the shift register.
//register shifts bits on upstroke of clock pin
digitalWrite(clockPin, 1);
ledpin++;
patbufidx++;
digitalWrite(latchPin, 1);
// turn current plane on HIGH in my case of common anode.
digitalWrite( PlanePin[plane], HIGH );
// delay PLANETIME us
delayMicroseconds( PLANETIME );
} // for plane
} // while <EndTime
} while (DisplayTime > 0); // read patterns until time=0 which signals end
