64x32 LED matrix
What's the transformer voltage and maximum current? If there is a label with parameters on it, please take a photo
5v 10 amps
And what is your connection? Please draw it ( just on paper and take a photo will be ok)and insert to the forum
There are markings near the terminals. Maybe you can make a photo from such an angle that we can see the markings...
Here you go:
Here’s the top side:
But I will draw a whole diagram of my power supply to my matrix
We need a picture from the front. Where the terminals come out of the housing...
Sorry bout that. Here you go
I think that’s it?
Yes. N should be further in (like L).
For your safety!
Add an automatic 8A fuse in the red line. That will protect you, your supply and your housemates. 50W is sufficient to start a fire...
And add a pictture of where the gray cable is connected to the board. There are markings there. And i expect one of them is ground.
Hey thanks for that. Makes sense haha. But is this the gray cable your talking bout?
Also here the vcc and the gnd:
Tell me if that’s what you want…
As you see, the grey cable has 3 gnd terminals. Follow one of those through the grey cable. Connect other end to arduino gnd.
@ardruinomega
Use the GND in the lower right corner of the connector - this is the main one.
Thank you. That is indeed what I did. All 3 gnd pins are connected accordingly and the main one is correct. I think.
Great. I am not that familiar with mega board. Now I see there is also gnd on the other side...
So this has been right all along...
So it might be your code...
I will look into that...
Hey thanks for helping. And yeah I was confused on what you guys meant about the gnd stuff. But yes it is most likely the code.
Thank you!
Did you read the adafruit documentation???
https://www.adafruit.com/product/420
It says that ArduinoMega does not have sufficient RAM to run this thing...
Apparently it did compile. So it may be a runtime memory shortage that causes your mega to reboot...
To check for reboots, you may add a three times blink of LED_BUILTIN in setup(), or a Serial.println("Booting");
Your terminals that carry 220V~ should be connected with things like this:
Your current way of connection is bound to get loose or get damaged and may cause a shortage or may cause you or someone else to get a 220V~ shock (no fun I can assure).
But I have mega 2560. With around 8kb sram
I’m not sure what to do. I’ve bought 2 boards for this and I’ve been told the mega should work? But I will get those things to protect me haha, thanks for that and trust me I know it sucks to get shocked…
Maybe it is not the memory...
Why not do the test....
How many 64x32 panels you are going to use? The Mega definitely has enough memory for one such panel, and might be for a two, but not more.
