Why doesn't this work? Shouldn't the display constatly switch between zero and one? It displays zero and does nothing else. Newbie here.
// C++ code
digitalWrite(a,HIGH);
digitalWrite(b,HIGH);
digitalWrite(c,HIGH);
digitalWrite(d,HIGH);
digitalWrite(e,HIGH);
digitalWrite(f,HIGH);
Where in your code do you write any of the segments low?
xfpd
January 6, 2024, 3:11am
3
sketmen2:
You must configure the pins you use, for example;
int a = 2;
or maybe
#define b 3
Then you must define the pin direction (input or output), for example;
pinMode(c, OUTPUT);
Without a setup() function and no definitions/declarations of a, b, c, d, e or f, I don't see how that sketch can even compile, let alone run. Could you please explain how you got that to work even partially?
sketmen2:
Try this skethc:
//--- insert codes to assign DPins for the segments: a - g
//insert codes to set directions of IO lines with which segments (a - g) are connected
void loop() //for CC-type 7-segment display devices
digitalWrite(a, HIGH);
digitalWrite(b, HIGH);
digitalWrite(c, HIGH);
digitalWrite(d, HIGH);
digitalWrite(e, HIGH);
digitalWrite(f, HIGH);
digitalWrite(g, HIGH);
digitalWrite(a, LOW);
digitalWrite(d, LOW);
digitalWrite(e, LOW);
digitalWrite(f, LOW);
digitalWrite(g, LOW);
system
Closed
July 6, 2024, 5:21pm
7
