Hi there! Super newbie here! Appreciate any input please!
I am trying to use a potentiometer with a 4 digit 7 segment display. My understanding is that potentiometers should go up to 1023, my readout for some reason only goes to 910. Any advice on how to make it go to 9999, and increase value as I turn clockwise (currently moving in the opposite direction)?
Also, is there a way to turn down the brightness of the digits? I have searched and tried a few different codes, but I am struggling to relate it to what I have in my code already. Thanks so much!
Here is the code I used:
int time = 5;
int pinA = 2;
int pinB = 3;
int pinC = 4;
int pinD = 5;
int pinE = 6;
int pinF = 7;
int pinG = 8;
int DIG1 = 9;
int DIG2 = 10;
int DIG3 = 11;
int DIG4 = 12;
void choose_digit(char num) {
switch(num) {
default:
// 0 default value
digitalWrite(pinA, HIGH);
digitalWrite(pinB, HIGH);
digitalWrite(pinC, HIGH);
digitalWrite(pinD, HIGH);
digitalWrite(pinE, HIGH);
digitalWrite(pinF, HIGH);
digitalWrite(pinG, LOW);
case 1:
digitalWrite(pinA, LOW);
digitalWrite(pinD, LOW);
digitalWrite(pinE, LOW);
digitalWrite(pinF, LOW);
case 2:
digitalWrite(pinC, LOW);
digitalWrite(pinG, HIGH);
case 3:
case 4:
case 5:
digitalWrite(pinB, LOW);
case 6:
case 7:
case 8:
case 9:
pinMode(DIG1, OUTPUT);
pinMode(DIG2, OUTPUT);
pinMode(DIG3, OUTPUT);
pinMode(DIG4, OUTPUT);
pinMode(pinA, OUTPUT);
pinMode(pinB, OUTPUT);
pinMode(pinC, OUTPUT);
pinMode(pinD, OUTPUT);
pinMode(pinE, OUTPUT);
pinMode(pinF, OUTPUT);
pinMode(pinG, OUTPUT);
void pick_digit(int digit) {
digitalWrite(DIG1, HIGH);
digitalWrite(DIG2, HIGH);
digitalWrite(DIG3, HIGH);
digitalWrite(DIG4, HIGH);
switch(digit) {
case 1: digitalWrite(DIG1, LOW); break;
case 2: digitalWrite(DIG2, LOW); break;
case 3: digitalWrite(DIG3, LOW); break;
default:digitalWrite(DIG4, LOW); break;
void seven_segment(int number) {
unsigned char thousands = int (number/1000);
unsigned char hundreds = int ((number/100)%10);
unsigned char tens = int ((number/10)%10);
unsigned char ones = int (number%10);
//1234
choose_digit(thousands);
pick_digit(1);
delay(time);
choose_digit(hundreds);
pick_digit(2);
delay(time);
choose_digit(tens);
pick_digit (3);
delay(time);
choose_digit(ones);
pick_digit(4);
delay(time);
int sensor_value = analogRead(A0);
Serial.println(sensor_value);
seven_segment(sensor_value);
delay(1);
