Hi all! I am currently making a 8x8 matrix snake game for a gift and it is completely inverted from what i want. Please help! The code is not mine, ( i have minimal knowledge) i am using 2 74HC595s with no transistors, the first is driving the Cathode's with 2K resisters and the 2nd is on the Anode. Thank you for your time, picture below to be clear.
I am wanting what is on to be off and what is off to be on. Thank you!!!
// SNAKE GAME on 8x8 LED matrix
// using Arduino and 2 74HC595 shift register.
// Pin connected to Pin 12 of 74HC595 (Latch)
int latchPin = 11;
// Pin connected to Pin 11 of 74HC595 (Clock)
int clockPin = 10;
// Pin connected to Pin 14 of 74HC595 (Data)
int dataPin = 12;
// Screen
byte led[8];
// button pin
int btn_up = 3;
int btn_down = 4;
int btn_left = 5;
int btn_right = 6;
// game variables
typedef struct Link {
int x;
int y;
struct Link * next;
} Link;
Link * pHead = NULL;
Link * pTail = NULL;
int curDirection = 4;
int newDirection = 4;
int appleX = 5;
int appleY = 5;
unsigned long oldTimer, curTimer;
boolean dead = 0;
// Seed Random Generator with noise from analog pin 0
randomSeed(analogRead(0));
// set pins to output
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
// set button pins to input
pinMode(btn_up, INPUT_PULLUP);
pinMode(btn_down, INPUT_PULLUP);
pinMode(btn_left, INPUT_PULLUP);
pinMode(btn_right, INPUT_PULLUP);
// clear screen
clrscr();
snakeInit();
screenUpdate();
oldTimer = millis();
curTimer = millis();
while(!dead) {
setDirection();
if(curTimer-oldTimer >= 320) {
curDirection = newDirection;
moveSnake(curDirection);
screenUpdate();
// update screen
screenDisplay();
int count = 0;
while(count<8) {
if(curTimer-oldTimer >= 100) {
led[count]=B11111111;
count++;
screenDisplay();
clrscr();
while(1) {
if(curTimer-oldTimer >= 700) {
for(int i=0; i<8; i++) {
led[i]=~led[i];
screenDisplay();
void
addHead(int x, int y)
Link *temp;
temp = (Link*) malloc (sizeof(Link));
// create new head
temp->x = x;
temp->y = y;
temp->next = NULL;
if(pHead!=NULL)
pHead->next = temp;
// point to new head
pHead = temp;
void snakeInit() {
int x = 3;
int y = 3;
for (int i=0; i<2; i++, x++) {
addHead(x,y);
if (i == 0)
pTail = pHead;
void setDirection() {
if(digitalRead(btn_up) == LOW) {
if(curDirection!=2)
newDirection = 1;
if(digitalRead(btn_down) == LOW) {
if(curDirection!=1)
newDirection = 2;
if(digitalRead(btn_left) == LOW) {
if(curDirection!=4)
newDirection = 3;
if(digitalRead(btn_right) == LOW) {
if(curDirection!=3)
newDirection = 4;
void moveSnake(int direction)
int newX = pHead->x;
int newY = pHead->y;
if(direction==1)
newY--;
if(direction==2)
newY++;
if(direction==3)
newX--;
if(direction==4)
newX++;
if(newX > 8)
newX=1;
if(newX < 1)
newX=8;
if(newY > 8)
newY=1;
if(newY < 1)
newY=8;
dead |= check(newX, newY);
if(!dead) {
if(newX==appleX && newY==appleY) {
addHead(newX, newY);
newApple();
else {
Link *temp = pTail;
// point to new tail
pTail = pTail->next;
// new head
pHead->next = temp;
pHead = temp;
pHead->x = newX;
pHead->y = newY;
pHead->next = NULL;
void newApple() {
boolean check = 0;
Link * ptr = pTail;
do {
check = 0;
appleX = random(7) + 1;
appleY = random(7) + 1;
Serial.println(appleX);
while(ptr!=NULL) {
if(appleX==(ptr->x) && appleY==(ptr->y)) {
check = 1;
ptr = ptr->next;
} while (check == 1);
boolean check(int x, int y) {
Link *ptr;
ptr = pTail;
while(ptr!=NULL)
if(x==ptr->x && y==ptr->y)
return 1;
ptr=ptr->next;
return 0;
// display driver
void screenUpdate() {
Link * ptr;
ptr = pTail;
clrscr();
while(ptr!=NULL) {
led[ptr->y-1] = led[ptr->y-1] | (1<<(8-ptr->x));
ptr = ptr->next;
led[appleY-1] = led[appleY-1] | (1<<(8-appleX));
void screenDisplay() {
byte row = B10000000;
for (byte k = 0; k < 8; k++) {
// Open up the latch ready to receive data
digitalWrite(latchPin, LOW);
shiftData(row); // if use PNP transitors
// shiftData(row);
shiftData(led[k]);
// Close the latch, sending the data in the registers out to the matrix
digitalWrite(latchPin, HIGH);
row = row >> 1;
void clrscr()
led[i] = B00000000;
void shiftData(byte data) {
// Shift out 8 bits LSB first,
// on rising edge of clock
boolean pinState;
//clear shift register read for sending data
digitalWrite(dataPin, LOW);
// for each bit in dataOut send out a bit
for (int i=0; i<8; i++)
//set clockPin to LOW prior to sending bit
digitalWrite(clockPin, LOW);
// if the value of data and (logical AND) a bitmask
// are true, set pinState to 1 (HIGH)
if (data & (1<<i))
pinState = HIGH;
pinState = LOW;
//sets dataPin to HIGH or LOW depending on pinState
digitalWrite(dataPin, pinState);
//send bit out on rising edge of clock
digitalWrite(clockPin, HIGH);
//stop shifting
